    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    intervals summary not showing after workout - suunto 9 baro
    6 Posts 3 Posters 567 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      loopylou72
      Usually when I use the interval function I see a summary showing the average pace for the intervals in suunto app/movescount and strava Yesterday nothing showed up - the interval session was completed fully. The interval function was used in a custom setting in trail running but this has not been a problem in the past on my old suunto 9. Has this summary been removed in the latest update? thanks
      • sartoricS Offline
        sartoric Moderator
        It still there afaik
        Do you have the interval screen in your custom sport mode ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        Brad_OlwinB L 2 Replies Last reply Reply Quote 0
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @sartoric
          @sartoric I don’t think the OP has this issue, it is the intervals showing on SA, which should show. I assume the OP has been using this feature.
          Vector/T6c/Vertical 2 Ti
          sartoricS 1 Reply Last reply Reply Quote 0
          • sartoricS Offline
            sartoric Moderator @Brad_Olwin
            @Brad_Olwin
            Sure but, you know, I’ve learned to always double check even the obvious 😁
            SVTS - 2.50.28
            • L Offline
              loopylou72 @sartoric
              @sartoric yes I do
                Brad_Olwin Moderator @loopylou72
                @loopylou72 j This should probably be moved to the appropriate OS, are you on iOS or Android? Could you try this on a stock sport mode? I will check with my watch today too.
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
