    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Syncing HR data
    Scheduled Pinned Locked Moved Spartan
    17 Posts 8 Posters 1.6k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • pauljanssensP Offline
      pauljanssens
      A few times now, the Spartan Ultra watch (not the wrist hr) is ‘hanging’ on Syncing HR data after ending the exercice. Any solution except hard reset ?
      isaziI Mff73M 2 Replies Last reply Reply Quote 0
      • isaziI Offline
        isazi Moderator @pauljanssens
        @pauljanssens there are similar posts in the forum. A search will help you greatly.
        Blog: isazi's home
        pauljanssensP 1 Reply Last reply Reply Quote 0
        • Mff73M Offline
          Mff73 @pauljanssens
          @pauljanssens
          and if search is too hard :), please toggle feeling setting to on for your sportmode settings in your watch
          Suunto Spartan Ultra (since 2016) FW: 2.8.24 (retired)
          Suunto Vertical all black
          Wife : S9PP
          SA: Always the latest beta :)
          Android 13, Galaxy S205G
          pauljanssensP 1 Reply Last reply Reply Quote 1
            pauljanssens @Mff73
            @Mff73
            Feeling is set to “on”. Did you mean toggle to “off”?
            Mff73M 1 Reply Last reply Reply Quote 0
              pauljanssens @isazi
              @isazi
              Sorry not found. In the meantime, I have done a soft reset and unlike what is stated in the user handbook, the activity is not in the logbook
              • Mff73M Offline
                Mff73 @pauljanssens
                @pauljanssens
                Ah, no i meant to be set to ON.
                So if it doesn’t work…
                Wife : S9PP
                • ? Offline
                  A Former User @pauljanssens
                  @pauljanssens Look for saving activity or search for anything HR related in my posts. I was the one who brought up the syncing HR issue recently. Having Feeling enabled kind of, sort of helps. What helps even more is a soft reset (12 sec up button press). I haven’t yet accounted this issue with the latest firmware, but then it usually happens after a while.
                    pauljanssens @Guest
                    @NickK thanks, I have done the soft reset. Strangely the soft reset deleted the activity
                    • B Offline
                      bbx100 Bronze Member
                      Today I had the same problem. Spartan Baro was hanging while syncing HR data. Soft reset helped, but deleted activity. Feeling was ‘on’. What to do in that situation? I lost really important activity?
                      paataP 1 Reply Last reply Reply Quote 0
                      • paataP Online
                        paata Bronze Member @bbx100
                        @bbx100 I have the same problem sometimes and my trick to preserve the activity is: keep the circle spin for a long time (sometimes half an hour) and the watch will reset itself. If not, after the long time of spinning connect watch to pc and watch will reset and activity will be preserved. Don’t reset watch with pressing button for 12sec, activity will be deleted. Let watch to reset itself is crucial.
                        B 1 Reply Last reply Reply Quote 0
                        • B Offline
                          bbx100 Bronze Member @paata
                          @paata Thx. This is good advice 🙂
                          • ? Offline
                            A Former User @bbx100
                            @bbx100 I did soft reset and it never deleted activities, but then maybe I was lucky. I think the advice above is good: wait until the spinning stops and/or watch resets itself. I noticed this spinning thing happens with one specific HR sensor and only when there were dropouts in heart rate. Also, the spinning duration seems to be proportional to the length of the workout: the longer you went the longer it spins.
                            pilleusP B 2 Replies Last reply Reply Quote 0
                            • pilleusP Offline
                              pilleus @Guest
                              @NickK said in Syncing HR data:
                              Which one?
                              I never had any problems with the Polar H10. 🤔
                              https://www.instagram.com/moves.are.life/
                              Suunto Vertical Black Lime
                              Suunto 9 Peak Pro Black
                              Suunto Spartan Ultra Stealth Titanium
                              • B Offline
                                bbx100 Bronze Member @Guest
                                I could be the case as I forgot to stop the activitiy and removed belt to wash it. Then I saw the activity is still going on so I stopped it. Than it hanged. Also in my case the battery was also on 3% which I didn’t noticed. I left watch for some 15min to sync, but that didn’t happen so I soft reset the watch. Then I lost activity.
                                • ? Offline
                                  A Former User @pilleus
                                  @pilleus HR broadcast via BLE from WHOOP band
                                  • P Offline
                                    paul870
                                    So I’m glad that this thread exists… I have been having problems with my watch ‘Syncing HR data’ for my warm ups, not such a problem… then when I have done a run after NO problems it just saves with feeling ‘OFF’
                                    Today I did not bother recording a warm up, mainly due to have to do a soft reset if it crashes… so went straight to run… guess what, its now stuck on ‘saving’ I really do not want to loose my run as it’s part of my training plan, the good news is that I have a Stryd on so I will get the run no matter what, but sadly no HR for the Stryd.
                                    Given this thread it seems to me that there has been a but developed over the last couple of weeks for my Suunto Spartan sport watch.
                                    I’m just waiting now to see if the watch will reset itself as mentioned above, if not I’m then going to connect it to moveslink and see if either of these will preserve the run data.
                                    When will I HAVE to use SA for my Spartan sport? currently I’m still using movescount.
                                    Paul
                                    SSS
                                    Ambit3 sport
                                    • P Offline
                                      paul870
                                      Well, as my previous post says I tried all ways now and it’s no good, the run is just LOST cannot save the poor thing.
                                      Sadly this is now becoming very annoying as due COVID I’m doing a challenge with friends and this will now NOT appear on Strava.
                                      SSS
                                      Ambit3 sport
                                      • First post
                                        Last post
                                      Suunto Terms | Privacy Policy
