    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Problems with GPS(GNSS) and with synchronization with watch
    Scheduled Pinned Locked Moved Spartan
    5 Posts 5 Posters 620 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Mitja VidmarM Offline
      Mitja Vidmar
      Maybe someone knowe what is the problems, than on my wacth when someone is calling it shows unknown caller. Everything else works ok, everthing is enable. GPS and i have always also Glonass enable is very inaccurate and my times on segments shows diferent inaccurate path (not very accurate distance, its vary…,like i would run 50m or more right or left and straight lines). I done few times factory reset and the situation is the same. I also update regulary. This problems accurs almost one year.
      Thanks
      sartoricS Brad_OlwinB 2 Replies Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator @Mitja Vidmar
        @Mitja-Vidmar
        Have you tried without glonass ?
        Using glonass is not always suggested as you can see from search result
        https://forum.suunto.com/search?term=glonass&in=titlesposts
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.11.12 beta
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Mitja Vidmar
          @Mitja-Vidmar Which watch do you have? What type of terrain are you running in? For me GPS is quite good without any other systems.
          Vector/T6c/Vertical 2 Ti
          M 1 Reply Last reply Reply Quote 0
          • Łukasz SzmigielŁ Offline
            Łukasz Szmigiel
            GPS mixed with other GNSS will be better if there are sufficient satellites visible and the constellation is good. I had bad experience in difficult terrain with GPS + Galileo as the signal was poor and watch was struggling with fix and was getting mixed data from GPS and Galileo. If there’s no need for extra GNSS, stick to GPS. Otherwise - use the system with most satellites available during your workout (check https://www.gnssplanning.com/).
            S9PP 2.50.28
            • M Offline
              Mi_chael Bronze Member @Brad_Olwin
              @Brad_Olwin
              Me to. GPS only
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
