    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ambit 3 peak issues
    Scheduled Pinned Locked Moved Ambit
    15 Posts 6 Posters 1.5k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MarynM Offline
      Maryn Silver Members
      I have correct setup hr zones in MC web.
      When I made a sync via MC app or “MC cable” to SA (enabled sportracker sync in MC web) zones are correctly displayed in SA app.
      If I made a sync to SA via SA app zones are not correctly displayed. SA displays default zones (60%-70%-80%-90%-100%).
      MC web:
      SA correct zones:
      SA not correct zones:
      Is that what it looks like for everyone ambit user ? If yes, then at this point, using SA synchronization seems pointless. Better solution is sync to SA via MC using ST account.
      Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Maryn
        @Maryn
        did you only sync to SA before?
        Because I noticed that for S9B it takes some time until the HR zones adjust correctly.
        Sync and immediately check the results will show wrong zones for me.
        living sideways
        MarynM 1 Reply Last reply Reply Quote 0
        • MarynM Offline
          Maryn Silver Members @freeheeler
          @TELE-HO in the past I had synced with MC to SA.
          A few days ago, I decided to check how sync works directly through SA. After the first synchronization, doubles appeared (because all the workouts from the diary were synced together). I removed the doubles and since then I’ve been doing synchronization on a regular basis.
          • MarynM Offline
            Another example that synchronization by SA isn’t good for Ambit user
            If you make a sync via Suunto App you lose the hr zone graphs in quantified-self.io :
            Sync via MC->ST, hr zones graph is available.
            • MarynM Offline
              The same activity :
              Laps view.
              Sync via MC
              Sync via SA
              Which looks better ? 🙂
                freeheeler @Maryn
                @Maryn
                but Suunto would not supply any advice or recommendation… all Suunto recommendet months and months ago also for ambut users was to jump onto the great and fancy SA… it is indeed a bit questionable.
                at this moment it seems like every single Suunto user is trying to find his own way… and all the different ways might lead to different results and quality of the data 🙄
                living sideways
                ? MarynM 2 Replies Last reply Reply Quote 4
                • ? Offline
                  A Former User @freeheeler
                  @TELE-HO Yeah, let’s hope when Ambits will be transition from Moveslink2 to Suuntolink that will transfer moves to SA platform, there will be a proper transfer regarding HR zones. Movescount has HR zones setting, but last time a checked Suunto App there was no option to change my HR zones or even activity class for my Ambit.
                  • MarynM Offline
                    @TELE-HO said in Ambit 3 peak sync issues:
                    @Maryn
                    It’s a little strange because Ambit 3 P is still on sale (and still in production, basing on SN number) . I think a lot of users discouraged by these problems may not decide to buy new Suunto models but go another way.
                    If I encounter any other problems, I will keep this thread updated.
                    • MarynM Offline
                      SuuntoLink/SA sync to QS comparing to MC.
                      1. HR zone graph is missing in QS.
                      2. Lap view is practily not usable.
                      In general SuuntoApp/Suntolink sync for QS user is a step back.
                      • MarynM Offline
                        Dear Suunto employees, when will be the profile view for route designer will be fixed?
                        Without this, the altitude profile navigation does not work.
                        sartoricS M 2 Replies Last reply Reply Quote 1
                        • sartoricS Offline
                          sartoric Moderator @Maryn
                          @Marcin-Byrtek
                          If you want to get in touch with Suunto employes you should contact them via Suunto Support.
                          SVTS - 2.50.28
                          SSSWHR BARO Amber - 2.8.32
                          Samsung A5 2016 - Android 7.0
                          Suunto App Android 6.7.12 beta
                          Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
                          • mlakisM Offline
                            mlakis Bronze Member
                            @Marcin-Byrtek, if you contacted, please update with a comment if you can, thanks.
                            • M Offline
                              margusl @Maryn
                              @Marcin-Byrtek said in Ambit 3 peak issues:
                              In your case and for that exact route, alt. profile should be fine once loaded to watch - all those waypoints on your screenshot still have elevation data, from that I assume it’s some previous route and this works fine. If you happened to change existing route, I’m afraid new sections are flat now and set to 0-altitude.
                              MarynM 1 Reply Last reply Reply Quote 1
                              • MarynM Offline
                                Maryn Silver Members @margusl
                                @margusl this is the route which I have made in ploataroute. I will test it in weekend. I hope elevation profile will be visibile in watch during nav.
                                • M Offline
                                  margusl @Maryn
                                  @Marcin-Byrtek , it will be fine, I just used a fresh route from plotaroute over the weekend with A3P. And you can test yours right after syncing to the watch:
                                  Navigation > Routes > … > View > Next
                                  This bug affects new routes that are built with MC route builder. It’s beyond me why there’s a problem providing an elevation graph for something that already has elev. data set.
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
