    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Do not disturb
    5 Posts 3 Posters 525 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • T Offline
      tomahawk5000
      Hi, is it ok that once watch turn on do not disturb profil then screen never go sleep? I saw that once watch is on the table for several minutes screen turn off any info (all black) but once do not disturb is on then screen never go sleep. Is it right?
      Tomek
      Kind regards,
      Tomek
      Suunto 9 baro -> Vertical 2
      • isaziI Online
        isazi Moderator
        I do remember the screen turning off when the watch is not moving also with DND, but I’m not 100% sure.
        Blog: isazi's home
        • T Offline
          tomahawk5000
          Would you be so kind and check please?
          Kind regards,
          Tomek
          inkognitoI 1 Reply Last reply Reply Quote 0
          • inkognitoI Offline
            inkognito Platinum Member @tomahawk5000
            @tomahawk5000 I checked it right now and the screen turns off in DND mode. You might try to soft-reset your watch by pressing the top right button for 12 seconds.
            Edit: “top button” is enough 😄 I’m still used to my old Spartan Trainer which has buttons both on the right and on the left 😄
            SV: fingers crossed :D
            S9 (non-baro): died after 2 months, replaced, holding strong since 03/20
            Spartan Trainer: casing broke after 23 months, repaired, lost watertightness 5 months later, died
            Despite some pretty bad luck, I still love Suunto!
            • T Offline
              tomahawk5000
              Hi yes after reset all is good. Thank you
              Kind regards,
              Tomek
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
