    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Saving exercise....
    63 Posts 21 Posters 10.9k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Saketo NemoS Offline
      Saketo Nemo Moderator
      The only time that has happened to me is just when I inadvertently turned off the feelings.
      What band are you using?
      Have you already tried with a soft or hard reset?
      • paataP Offline
        paata Bronze Member
        I’m using Polar OH1. Soft reset was done after each freezing. Hard reset about two weeks ago so I will see if it will help.
        • J Offline
          JonasJkp @Saketo Nemo
          @Saketo-Nemo yes i Have.
          Bit sometimes the watch seems to change settings such as pool leangth etc. it may also change feelings but I’m not sure.
          However the response from Suunto is not too notch anymore.
          • zadowZ Offline
            zadow
            Dears, any update on this? I was reporting logs few times for this issue. Today it happens to me again. Unfortunately, today everything went wrong and my activity was lost.
            Yes, I have feeling enabled
            Yes, I entered feeling when activity finishes.
            Yes, I did turn off belt (Wahoo TICKR FIT) before actually ending the activity (this is recommended way as I learnt previously)
            When it happens previously, usually, watch restarted themselves after few minutes and activity was saved and I was happy. Today, watch were saving for more than 3 hours. I restarted them by myself and activity was lost.
            Today it was just easy run, but if I would lost some of my races or key training, that would really hurt me… 😞
            Watch - SSHWR Baro
            Belt - Wahoo Tickr FIT
            So, any (good?) news, please?
            Thanks and have a good time!
            P.S.
            It’s a pity that this topic is discussed in about 4 or 5 threads, it’s hard to decide which is the right one then…mentioning this just to be on the safe side, because - yes, I did search the forum…
            Suunto Race
            Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
            Suunto Smart Sensor
            Wahoo Tickr FIT
            Hammerhead Karoo 2
            Swim Ride Run Rest Repeat
            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
            • G Offline
              grantdoug @nseslija
              @nseslija There is some kind of bug regarding HRM straps. My bug was a different bug, but it seems related. When I use a Suunto HRM Movesense strap on my Suunto 9, and I manually turn off the watch HRM while recording an exercise, the activity will not sync to the Suunto app. It turns out that I have to leave the watch HRM set to ‘on’ and it will sync. The watch software automatically turns off the watch HRM if an external strap HRM is paired. So I am just guessing your error is in the same ‘family’ as the error I experienced - the watch software / app is not able to accommodate certain patterns in HRM data.
              Dimitrios KanellopoulosD N 2 Replies Last reply Reply Quote 0
                Dimitrios Kanellopoulos Community Manager @grantdoug
                @grantdoug what platform ? IOS / Android ?
                Can you tell me the steps to reproduce this one with the latest software ? Thanks.
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                  Dimitrios Kanellopoulos Community Manager @zadow
                  @zadow I understand
                  • N Offline
                    nseslija Bronze Member @grantdoug
                    @grantdoug Maybe, but after enabling feeling in all my custom sport modes I never experienced the issue…
                    Ambit 2S
                    Ambit 3 Peak
                    Suunto 9 baro
                    Suunto Vertical Ti Solar
                    • aroo7A Offline
                      aroo7 Bronze Member
                      In my case (Spartan Ultra), enabling feeling screen doesn’t solve the problem. I used to custom sport mode and H10. In the last month, I have had several such cases.
                      paataP Mff73M 2 Replies Last reply Reply Quote 0
                      • paataP Offline
                        paata Bronze Member @aroo7
                        @aroo7 It is never ending story and big lottery, if it will be saved correctly without stuck. However, leave it spin for very long time helps in most cases (SSU).
                        • Mff73M Offline
                          Mff73 @aroo7
                          @aroo7
                          could it be a corrupted custom sport mode issue ? (not sure, just idea)
                          could worth the try to delete your sportsmode and recreate it.
                          SSU (retired), SV1, SV2
                          Wife : S9PP
                          SA: Always the latest beta :)
                          Android + Galaxy S205G
                          • aroo7A Offline
                            aroo7 Bronze Member
                            thanks for reply @paata & @Mff73
                            @paata last time this error appeared I left my watch for 4 hours but it didn’t help but once in a long time this loop is actually over. It looks a big lottery as you wrote.
                            @Mff73 I will try to recreate the sportsmode
                            zadowZ 1 Reply Last reply Reply Quote 0
                            • zadowZ Offline
                              zadow @aroo7
                              @aroo7 the only 100% solution what worked for me on my Spartans, was to turn off external HR BEFORE ending the activity. So I pressed the pause, turned off HR belt and then saved the activity. That worked well.
                              On S9 I havent experienced this problem yet. But I have my S9 first week only, so it is too soon to evaluate…
                              Suunto Race
                              Suunto Smart Sensor
                              Wahoo Tickr FIT
                              Hammerhead Karoo 2
                              • CHRGBRC Offline
                                CHRGBR @CHRGBR
                                @CHRGBR said in Saving exercise....:
                                Hi, same problem for me. It happened twice, after a custom activity, with Polar hr belt. Feeling was on and I indicated it. The second time, I wait for 2 or 3 hours but it didn’t help. I had to reboot and loose the activity.
                                Did it happened to someone with a standard activity ? I can come back to basic activities while waiting for a fix…
                                Never experienced this issue since march … until today 😞
                                Custom activity, wrist hr. After an hour, I needed to reboot.
                                Race 2
                                Previously : 9 baro, Spartan sport, Ambit 3
                                F 1 Reply Last reply Reply Quote 1
                                • F Offline
                                  Frederic Bronze Member @CHRGBR
                                  Had this issue for the first time today 😞
                                  Has anyone tried to wait until the saving is finished ? If yes, did that get resolved by itself ? How long did it take ?
                                  I only waited 1h but maybe I should have waited 10h+ to see ? Curious to see if anyone has any experience. Hoping it was just a one-off issue.
                                  Suunto Vertical
                                  My Suunto Workflow
                                  MyTourbook - First Steps
                                  Questions or bugs ?
                                  paataP F 2 Replies Last reply Reply Quote 0
                                  • paataP Offline
                                    paata Bronze Member @Frederic
                                    @frederic
                                    I had this issue very often with my SSU. If feeling on or off it doesn’t matter. Actually the one thing that helps is turn off the ohr before ending activity. In case of watch stuck sometimes help leave it for long time, more than one hour, but not everytime.
                                    However, I thought that S9 doesn’t have this bug.
                                    F 1 Reply Last reply Reply Quote 0
                                    • F Offline
                                      Frederic Bronze Member @paata
                                      @paata said in Saving exercise....:
                                      @frederic
                                      Actually, I didn’t use OHR and never use it but thanks for the tip.
                                      I wish S9 didn’t have this bug but unfortunately I had to experience that today… really bummed 😞
                                      Suunto Vertical
                                      My Suunto Workflow
                                      Questions or bugs ?
                                      F BulkanB 2 Replies Last reply Reply Quote 0
                                      • F Offline
                                        Frederic Bronze Member @Frederic
                                        Today, after this issue I updated to the latest firmware just released so maybe that was fixed in this new v 2.14.12 ? To be continued…
                                        Suunto Vertical
                                        My Suunto Workflow
                                        Questions or bugs ?
                                        sealion.hrS 1 Reply Last reply Reply Quote 0
                                        • sealion.hrS Offline
                                          sealion.hr Bronze Member @Frederic
                                          @frederic This issue was fixed in previous firmware update already (2.13.xx). I never experienced it again
                                          S9b titanium - latest FW
                                          Realme X2 - Android 11.0
                                          Suunto App latest beta
                                          Footpod: Stryd v4
                                          HR: Scosche Rhythm 24
                                          • F Offline
                                            Frederic Bronze Member @sealion.hr
                                            @sealion-hr said in Saving exercise....:
                                            I wish you would be right but my watch was actually using the 2.13.18 firmware so I don’t think that issue was fixed unfortunately.
                                            Unless you have an official source/documentation that shows otherwise ?
                                            Suunto Vertical
                                            My Suunto Workflow
                                            Questions or bugs ?
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
