    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Saving exercise....
    63 Posts 21 Posters 9.2k Views 24 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      nseslija Bronze Member
      Hi,
      does anyone had the problem with saving finished exercise on the watch…?
      I finished my bike ride 60 min ago and Suunto 9 baro is still saving the exercise…
      I have noticed that saving previous exercises took longer then usual, but it was still under the 2 minutes…
      Ambit 2S
      Ambit 3 Peak
      Suunto 9 baro
      Suunto Vertical Ti Solar
      ? G 2 Replies Last reply Reply Quote 1
      • isaziI Offline
        isazi Moderator
        I remember someone on the forum had similar issues, but maybe it was with one of the Spartans and not S9.
        Blog: isazi's home
        N 1 Reply Last reply Reply Quote 0
          Dimitrios Kanellopoulos Community Manager
          I have seen this issue a couple of times and have tried to get data to be solved.
          I would assume you have OH1 or Tickr ?
          As a quick perhaps workarround use the feeling screen for that sport mode.
          Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
          N 3 Replies Last reply Reply Quote 1
          • N Offline
            nseslija Bronze Member @isazi
            @isazi I didn’t find it at the beginning, but i found it now…
            12 sec reboot solved the problem, the exercise is lost…
            Ambit 2S
            Ambit 3 Peak
            Suunto 9 baro
              and do you have a custom sport mode ?
              • ? Offline
                A Former User @nseslija
                @nseslija Had exact same issue and still have it any time WHOOP 3.0 strap is used for heart rate. Sometimes saving takes upward of 3-5 minutes. Once the watch crashed.
                Also get this screen (not sure what’s there to sync since watch had been connected to a sensor at all times and displayed valid HR throughout the exercise, with no drops):
                • N Offline
                  nseslija Bronze Member @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos if you ask about external sensors only HR strap, H10… and yes custom sport mode…
                  Ambit 2S
                  Ambit 3 Peak
                  Suunto 9 baro
                  • N Offline
                    @Dimitrios-Kanellopoulos I have cadence and speed sensor on another bike, another sport mode…
                    Ambit 2S
                    Ambit 3 Peak
                    Suunto 9 baro
                    • N Offline
                      nseslija Bronze Member @Guest
                      @NickK I’ve seen that screen… but as you sad for couple of minutes…
                      Ambit 2S
                      Ambit 3 Peak
                      Suunto 9 baro
                      • ? Offline
                        @nseslija said in Saving exercise....:
                        Sadly, it doesn’t. After a little while, the problem starts again. At least, that’s been the case with WHOOP 3.0 HR broadcast and H10, which S9 seems to hate in particular. It would show it as connected on the activity start screen, then the heart rate would freeze during actual activity. You can literally see a flatline in HR graph screen if you add it to your sports mode.
                        N 1 Reply Last reply Reply Quote 1
                        • N Offline
                          @NickK This last for two hours… so I had to reboot the watch… sadly the exercise is lost… I think that i have H10 for almost a year now, and this never happend before…
                          Ambit 2S
                          Ambit 3 Peak
                          Suunto 9 baro
                          ? 1 Reply Last reply Reply Quote 1
                          • N Offline
                            @Dimitrios-Kanellopoulos I enabled feeling screen on all my custom sport modes now, I hope that will help…
                            Ambit 2S
                            Ambit 3 Peak
                            Suunto 9 baro
                            • ? Offline
                              @nseslija My H10 started glitching after WHOOP connectivity issues and that strange “syncing HR” screen. The weird thing is: first couple of workouts with WHOOP are fine, then this screen pops up on a third or fourth workout, then “saving” starts taking progressively longer, and then all sorts of HR weirdness starts happening. Rebooting the watch helps, but only temporarily. As does removing pairing and pairing another sensor. But the only thing I found that fixes it for good is a complete firmware flash.
                              It’s as if something was being corrupted.
                              And H10… I don’t know. I did a comparison 8 mile run, S7 vs S9/H10 about a month ago. Three quarters into the run, H10 started behaving weirdly. The HR would freeze, then it simply dropped to 60-70 closer to the end when I was pushing 150-160 during strides (by the feel and S7 OHR). When I synced it to the app, most of the HR in the last quarter was like 60-70. So, the values displayed by S9 during run… Not sure where they were coming from or went.
                              • N Offline
                                @NickK I had all kind of problems with Suunto smart sensor, with H10 none… so far 🙂
                                Ambit 2S
                                Ambit 3 Peak
                                Suunto 9 baro
                                ? 1 Reply Last reply Reply Quote 2
                                • ? Offline
                                  @nseslija Good to know S9 is at least consistent
                                  • M Offline
                                    Mi_chael Bronze Member
                                    Great news if Suunto add HR synch with 3 party hr belt…
                                    @Dimitrios-Kanellopoulos Some news?
                                    • jsr184J Offline
                                      jsr184 Bronze Member
                                      I have this issue with SSWHRBaro occassionally. It just gets stuck like this. If I reboot (holding button) it goes back to normal and activity is fully synced so no data is lost. It happens really rarely though and only for longer activities. I use OH1 sensor.
                                        Hi can you guide and help me here.
                                        Is it a specific activity type ?
                                        Does the watch disconnected ffrom the belt for this to happen ?
                                        Something else ?
                                        N ? 2 Replies Last reply Reply Quote 0
                                        • N Offline
                                          @Dimitrios-Kanellopoulos hi, it is cycling custom sport mode, everything was normal during the exercise,
                                          I think is not related to HR strap…only my opinion…
                                          Ambit 2S
                                          Ambit 3 Peak
                                          Suunto 9 baro
                                          • ? Offline
                                            A Former User @Dimitrios Kanellopoulos
                                            @Dimitrios-Kanellopoulos Multiple activity types (martial arts, crossfit, indoor bike) for the extra long saving issue and this weird “hr sync” screen. Running for strange drops in H10 that otherwise seems to be fine (battery is reported as full, the strap is relatively new, about 12-14 months and not used heavily). One thing that’s the same among others – all sports mode in question were custom.
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
