    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Ambit 3 Peak/ Movescount Sync issue on Android
    Scheduled Pinned Locked Moved Ambit
    ambit3sync problemmovescount
    5 Posts 5 Posters 1.2k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      neptunejason
      I did an ultra event this weekend and when I synced the watch to the Movescount app it failed to transfer the data. I have done 2 exercise sessions since and both of those have successfully synced. Is there a way to push that missing event over… or will it eventually be picked up? If I have to manually enter that data I am not going to be a happy camper. By the time the newer Suunto App has fully integrated the Ambit 3 that data will be pushed off the watch.
      freeheelerF M M 3 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @neptunejason
        @neptunejason
        did you try sync thru the cable?
        My wife’s A3R sometimes had this problem with MC app sync. The cable solved it.
        Did you also sync to SA meanwhile? I did not get that clearly
        living sideways
        • M Offline
          margusl @neptunejason
          @neptunejason , if you install Suunto App, there’s a good chance it will be able get those activities from the watch, you don’t need to stick with SA or abandon Movescount for this. Though 2 apps on the same phone can be bit tricky and you have to make sure those are not running / trying to connect to Ambit at the same time.
          Probably more straightforward way would be using a cable syncing with Moveslink2 on a PC, most likely you first need to clear sync flags for those two activities, but there’s a 3rd party tool for this - https://forums.watchuseek.com/f233/data-logbook-ambit3-but-cannot-export-movescount-4159434-2.html#post47842291 . Has been working for many, but still - use it at your own risk. And read that whole linked thread and salogbook readme.
          1 Reply Last reply Reply Quote 3
          • Jay Smith-HaywardJ Offline
            Jay Smith-Hayward
            Heyo — any workarounds for a Spartan on that app? Doesn’t recognize the watch.
            • M Offline
              marcrie Bronze Member @neptunejason
              @neptunejason I had a similar Problem. Here is my solution: https://forum.suunto.com/topic/4533/movescount-app-crashes-after-move-sync
              The lesson I learned is, that for big moves (>5h) I use the cable to sync the moves.
              Register Login
              • First post
                Last post
              Suunto Terms | Privacy Policy
