    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    How to use QZSS on S9B
    22 Posts 6 Posters 2.1k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Takeshi KakedaT Offline
      Takeshi Kakeda
      返信: 2.8.24 Update
      I use S9 in Japan, but S9B doesn’t show QZSS in the selection of navigation systems.
      It shows only GPS, GPS+GLONASS and GPS+GALILEO.
      How do I use QZSS on S9B?
      firmware version: 2.10.26
      hardware: 3835C3
      freeheelerF zhang965Z Luís PintoL 4 Replies Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @Takeshi Kakeda
        @Takeshi-Kakeda
        S9B is basically made with GPS, GPS+GLONASS and GPS+Galileo… rumors say that GPS+Beidou is on the way… never heard of rumors about GPS+QZSS
        for me GPS is doing its job, I don’t need the combination of any other system at the moment
        living sideways
        • zhang965Z Offline
          zhang965 @Takeshi Kakeda
          @Takeshi-Kakeda said in How to use QZSS on S9B:
          返信: 2.8.24 Update
          hardware: 3835C3
          こんにちは
          Although the gps chipset from Sony should support QZSS , sadly S9 has no possibility to Activate it now.
          And of course there is no any suunto announcement to show us when it will be available.
          So my answer is
          No you cannot use QZSS in suunto9 , and if you just bought your s9 for using QZSS, return it.
          Winners Wear Winners
          • Luís PintoL Offline
            Luís Pinto Platinum Member @Takeshi Kakeda
            @Takeshi-Kakeda QZSS is integrated on Navstar system. You don’t have to do anything to use regional Japan system. It means that if you use Navstar alone (GPS) is nav+QZSS, if you use nav+gal you real use in Japan Nav+QZSS+Gal.
            SR
            Site (gr7vel spin): https://youtube.com/channel/UCfHM0mXWS8S61h70Rzj9mfA
            Takeshi KakedaT 1 Reply Last reply Reply Quote 4
              @Takeshi-Kakeda try to use GPS Test APP to see systems on your country and sats if your smartphone have a chipset to support all constellations: https://github.com/barbeau/gpstest
              You just have two regional systems QZSS (Japan) integrated on American system and IRNSS (Índia) not integrated. Índia plan to do a global system in future. GB after brexit also have plans to do their own system.
              You should be able to see in app for example this:
              SR
                Dimitrios Kanellopoulos Community Manager
                Hi what @Luís-Pinto said.
                Qzss is enabled always on all S series watches
                You don’t need Todo anything about it and it doesn’t consume any extra battery
                Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                Takeshi KakedaT 1 Reply Last reply Reply Quote 3
                • isaziI Offline
                  isazi Moderator
                  Because QZSS is designed to improve GPS, while the other systems (in theory) could be complete replacement.
                  Blog: isazi's home
                  Luís PintoL 1 Reply Last reply Reply Quote 2
                    Luís Pinto Platinum Member @isazi
                    @isazi QZSS is a regional system in Japan and others are global, and yes can be work without Navstar.
                    I’ve be testing galileo (just) with smarphone with a external antenna and a specific app from that brand that allows to choose a constellation and results are amazing (both static and moving, without dual frequency - my phone don’t have that possibility), better than nav+gal! But in my zone, in Asia can be worst. Next will test bds.
                    SR
                    Dimitrios KanellopoulosD isaziI 2 Replies Last reply Reply Quote 0
                      Dimitrios Kanellopoulos Community Manager @Luís Pinto
                      @Luís-Pinto how ? (Do you test) eager to learn
                      Luís PintoL 1 Reply Last reply Reply Quote 0
                      • zhang965Z Offline
                        zhang965
                        List of products that support the Quasi-Zenith Satellite System (QZSS)
                        https://qzss.go.jp/en/usage/products/list.html#outdoor-digital-cameras-clocks
                        Suunto has only one device listed , Suunto7
                        Luís PintoL Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 0
                          Luís Pinto Platinum Member @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos it’s a APP included when you buy a external antenna. This antenna, is connected via ble. You can select constelation that you want, or select dual/triple constellations. Later can inform details: https://geospatial.trimble.com/products-and-solutions/trimble-r1
                          https://www.seilergeo.com/2015/07/29/overview-of-trimble-gnss-status-app-on-an-android-device-connected-to-a-trimble-r1-gnss-receiver/
                          Even u-blox antennas there is software to choose systems and single or dualfrequency:GNSS SEL.png
                          SR
                            Luís Pinto Platinum Member @zhang965
                            @zhang965 S5 and S9 have QZSS.
                            SR
                            zhang965Z 1 Reply Last reply Reply Quote 0
                            • zhang965Z Offline
                              zhang965 @Luís Pinto
                              @Luís-Pinto
                              Yes, I know S9 has the QZSS,
                              But i just don’t think it can work only with the Gps
                              Option, and GZSS will be a complete system as well.
                                Dimitrios Kanellopoulos Community Manager @zhang965
                                @zhang965 said in How to use QZSS on S9B:
                                that is a bit outdated list. Vantage has also QZSS and others.
                                • zhang965Z Offline
                                  zhang965 @Dimitrios Kanellopoulos
                                  @Dimitrios-Kanellopoulos said in How to use QZSS on S9B:
                                  Yes vantage is in the list so does suunto7
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                                    @zhang965 ok
                                      Again to make it clear for the OP the QZSS is always on
                                      For the specs of the watch see details on Suunto .com https://www.suunto.com/en-gb/Products/sports-watches/suunto-9-baro/suunto-9-baro-black/
                                      • isaziI Offline
                                        isazi Moderator @Luís Pinto
                                        @Luís-Pinto alright, but with 4 satellites it is not global.
                                        I just read they’re planning to extend it to make it standalone, but it’s future work.
                                        Blog: isazi's home
                                          @isazi i Said before qzss is regional.
                                          SR
                                            Takeshi Kakeda @Dimitrios Kanellopoulos
                                            Hi, thanks for all comments.
                                            Wao! it’s so wonderful for me.
                                            I wondered if S9B specs told possibility of QZSS, but I couldn’t use it
                                            So I can tell my friends that suunto S series watches support QZSS like garmin watches ✌ .
                                            Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
