    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9B battery drain during long activity pause
    16 Posts 9 Posters 1.5k Views 9 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • C Offline
      chrisc92 Bronze Member
      When pausing an activity for long, for example 1 hour or more (lunch break during a bike ride) I was surprised by the battery drain going to 5% per hour. I suspect the OHR to be constantly flashing and causing that drain, I don’t understand why, because the activity is paused, and nothing should be recorded, the display shows the elapsed time, the GPS should be paused and also the OHR.
      I choosed this watch for power saving management but it is frustrating yo have to charge the watch so often.
      Also the watch is proposing to change from performance to endurance only at 10 % battery so only when you have 1 h activity record left.
      And if you change to endurance, too bad you will encounter synchro problems with strava
      so I don’t understand the energy power saving strategy during activity. Could the OHR be deactivated, when the watch is on the bike ?
      • sartoricS Offline
        sartoric Moderator
        There is a very long discussion about battery drain. Maybe you can find some answer there
        https://forum.suunto.com/topic/3477/s9-or-s5-expected-battery-life-on-2-9-42
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.8.9 beta
        • isaziI Offline
          isazi Moderator
          Also, I believe that during a break your watch is simply not recording, but all’s working, GPS and heart rate included.
          Blog: isazi's home
          1 Reply Last reply Reply Quote 4
          • EgikaE Offline
            Egika Platinum Member
            You can switch off GPS in the settings during a pause. Just long press the middle button and change the GPS to off in the battery settings.
            OHR I don’t know if it can be disabled…
            • MarynM Offline
              Maryn Silver Members
              We need a function to stop the activity and the possibility to resume it. Something like that has long been available in Garmin. Coros has also introduced something like that. A very cool feature during long all-day activities.
              @Dimitrios-Kanellopoulos what do you think?
              Suunto Vertical, Suunto Race, Edge 530, Vantage V, Suunto Wings, Polar H10&Verity Sense
              Dimitrios KanellopoulosD isaziI BulkanB 3 Replies Last reply Reply Quote 12
                Dimitrios Kanellopoulos Community Manager @Maryn
                @Maryn yes
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                • isaziI Offline
                  isazi Moderator @Maryn
                  @Maryn absolutely. Although I have seen Fusedalti kick in during a break and improve the altitude readings.
                  Blog: isazi's home
                  • BulkanB Offline
                    Bulkan Moderator @Maryn
                    @Maryn +1
                    Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                    • Tim4cT Offline
                      Tim4c Silver Members
                      Hey,
                      I dream of this feature “resume later” for a while now!
                      I have found a way to save battery by switching the GPS setting to Off or OK during long breaks. It helps a lot.
                      Suunto Spartan WHRB, iPhone XR, Suunto App beta, almost always on the last update.
                      freeheelerF C 2 Replies Last reply Reply Quote 4
                      • freeheelerF Offline
                        freeheeler @Tim4c
                        @Tim4c
                        in this “pause” mode I’m sometimes a bit scared that accidential button press ends or resumes the activity…
                        …but I think I’m eccentric as I’m always afraid of unwanted button press… also in watch mode or during an activity when I would like to benefit from the touch function to swipe left and right to switch screens
                        living sideways
                        Tim4cT EgikaE 2 Replies Last reply Reply Quote 1
                        • Tim4cT Offline
                          Tim4c Silver Members @freeheeler
                          @TELE-HO
                          It happened to me several times and i hate that.
                          Another trick is to keep the watch on setting screen!
                          • EgikaE Offline
                            Egika Platinum Member @freeheeler
                            @TELE-HO You can still lock the buttons even in pause mode. Just press long enough to not end the activity ☝
                            …or is exactly this what you are scared of? 😉
                            Tim4cT freeheelerF 2 Replies Last reply Reply Quote 3
                            • Tim4cT Offline
                              Tim4c Silver Members @Egika
                              @Egika
                              Yep i tried this option, it works!
                              But, yes there is a but, I don’t remember exactly but it was extremely painful to unlock buttons with auto-pause or pause and rainy condition.
                              Edit: perhaps, i forgot the long press to the lower button…
                                freeheeler @Egika
                                @Egika
                                thanks, yes I haven’t had the opportunity to try or when I’ve had it I did not remember 😉
                                I’ll do it next time, thank you for the hint! 👍
                                living sideways
                                • C Offline
                                  chrisc92 Bronze Member @Tim4c
                                  @Tim4c
                                  I think that a watch that is aware of battery drain should propose after 5 or 10 minutes to continue the activity later or not…
                                  And resume it later
                                  It’s not safe to keep that pause mode for a long Time , nor it not safe to lock
                                  Also an option to stop that unuseful OHR that permanently flashes even during a pause or when the watch if off your wrist…
                                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                    Dimitrios Kanellopoulos Community Manager @chrisc92
                                    @chrisc92 OHR / HR is helpfull for calories even during a pause. Among others also for 24/7 HR that is a no go if the user doens’t explicitly turn it off.
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
