    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Tips and tricks, apps and watch faces
    Scheduled Pinned Locked Moved Suunto 7
    296 Posts 37 Posters 99.9k Views 41 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • giulioG Offline
      giulio @pilleus
      @pilleus
      Hi,
      How can set in locus ,…maps none and dark mode?
      I can’t see how
      pilleusP 1 Reply Last reply Reply Quote 0
      • giulioG Offline
        giulio @JANTIKAINEN
        @JANTIKAINEN
        I dont have Strava…i can’t help you
        • pilleusP Offline
          pilleus @giulio
          @giulio said in Suunto 7 - Tips and tricks, apps and watch faces:
          @pilleus
          Hi,
          I can’t see how
          Open Locus - menu (three lines at the left side on top of the screen) - maps (online or offline, what you are using) - menu (three dots at the right side on top of the screen) - empty map and dark mode
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          • pilleusP Offline
            pilleus @JANTIKAINEN
            @JANTIKAINEN said in Suunto 7 - Tips and tricks, apps and watch faces:
            Have anybody been successful with that?
            Yes. Add Ghost - Strava routes - routes are listed in a new screen called Add ghost - click the route - the route is shown on the next screen (you can change the name or cut the route from both ends) - click Add ghost and the route is listed in Ghosts
            JANTIKAINENJ 1 Reply Last reply Reply Quote 0
            • JANTIKAINENJ Offline
              JANTIKAINEN Bronze Member @pilleus
              @pilleus said in Suunto 7 - Tips and tricks, apps and watch faces:
              I have created only 1 route in Strava.
              For me it stops to this point, Add Ghost - Strava routes.
              Just never ending green circle and no list of routes appear.
              Samsung Galaxy S24
              Suunto Race Titanium
              • pilleusP Offline
                @JANTIKAINEN the Strava connection is okay? Is Ghostracer listed in Strava’s settings - My Apps?
                • pilleusP Offline
                  pilleus
                  Creating cycling routes with Naviki
                  A great app to create routes (A->B, loop) for road bike, mountain bike or all day usage. The calculated route can be exported as gpx file for usage in your preferred app on the S7 (or SA, hopefully for usage in the Suunto wear app in the near future).
                  Here one of 8 calculated loops for mounting biking with a length of 40 km from my home back to my home. 👍
                  giulioG 1 Reply Last reply Reply Quote 1
                  • giulioG Offline
                    giulio @pilleus
                    I ask you this thing, maybe it happens to you too … often the gps remains active on suunto 7 and also on the phone, as if an app remains active and drains my battery quickly. all with suunto watchface or that do not need gps, I suspect it is the Altimeter app that continues to search for the position, even at home. how can I do? apart from restarting the 7?
                    • pilleusP Offline
                      pilleus @giulio
                      Altimeter app
                      Which one?
                      giulioG 1 Reply Last reply Reply Quote 0
                      • giulioG Offline
                        giulio @pilleus
                        @pilleus
                        Wear altimeter of appfour.
                        Setting : gps by phone ,barometric altimeter
                        giulioG pilleusP 2 Replies Last reply Reply Quote 0
                        • giulioG Offline
                          giulio @giulio
                          in my opinion suunto should equip the watch with proprietary apps like altimeter at least and maybe compass and atmospheric pressure and not having to rely on third party apps that don’t work or work badly
                          1 Reply Last reply Reply Quote 3
                          • MO92119M Offline
                            MO92119
                            I also installed some appfour apps (Altimeter, Compass, Speedometer). However, when I checked the battery consumption in the Wear OS app (on the phone), I saw that Altimeter and Speedometer were using battery, even though I hadn’t opened the apps! It was only 1% per app, but apps like those should not use battery in the background IMO.
                            -> I uninstalled the apps…
                              JANTIKAINEN Bronze Member @MO92119
                              @MO92119
                              I had Wear Mail app by Appfour and it was draining the battery a lot.
                              It seems that some apps by Appfour are killing the battery.
                              Samsung Galaxy S24
                              • pilleusP Offline
                                pilleus @giulio
                                @pilleus
                                I deactivated all options. The app uses then the barometer of the S7 for the altitude and not the GPS based altitude from the phone. 😎
                                hqvkamilH 1 Reply Last reply Reply Quote 1
                                • hqvkamilH Offline
                                  hqvkamil @pilleus
                                  @pilleus
                                  I cant make any changes. When I want to deactivate I have only screen with full version to buy.
                                  Sunnto 7 Graphite Copper
                                  isaziI pilleusP 2 Replies Last reply Reply Quote 0
                                  • isaziI Offline
                                    isazi Moderator @hqvkamil
                                    @hqvkamil you need the paid version to disable phone GPS.
                                    Blog: isazi's home
                                    • pilleusP Offline
                                      pilleus @hqvkamil
                                      @hqvkamil sorry, but I have the appfour flat rate and therefore my answer. 🙏
                                      isaziI 1 Reply Last reply Reply Quote 0
                                      • isaziI Offline
                                        isazi Moderator @pilleus
                                        @pilleus are you getting good results with the appfour altimeter? I get reasonable results recording activities with the Suunto app, but the appfour altimeter seems always very wrong.
                                        Blog: isazi's home
                                        pilleusP Stephan_74S 2 Replies Last reply Reply Quote 0
                                        • pilleusP Offline
                                          pilleus @isazi
                                          @isazi I have the actual altitude with the appfour altimeter. No problems and not more than 3 meters offset to the correct altitude. 👍
                                            Are any of you using Wear Message app by Appfour?
                                            Do you see also pictures in Whatsapp messages in S7?
                                            Mine doesn’t show pics even though I have also Wear Photos app where also Whatsapp pictures show.
                                            I don’t know what I’m doing wrong and Appfour can’t help me.
                                            Also Whatsapp group conversations are a big mess. They don’t show all the messages and some of them appear twice and also conversation is sometimes split to few conversations.
                                            I was thinking if there is some better message app for Wear OS than Wear Messages?
                                            Samsung Galaxy S24
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
