    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 7 - Tips and tricks, apps and watch faces
    Scheduled Pinned Locked Moved Suunto 7
    296 Posts 37 Posters 103.2k Views 41 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • giulioG Offline
      giulio @pilleus
      @pilleus
      I try ghostracer…
      It will surprise me…
      I followed a gpx track in ambient mode with map dowloaded,ohr active,for 1 hour and the battery goes down only 8 %…
      Incredible…
      Map was in 3d and always on but in ambient mode…
      How is possible so low consumption?
      giulioG 1 Reply Last reply Reply Quote 0
      • giulioG Offline
        giulio @pilleus
        @pilleus
        Wear standalone maps which map does it use?
        For outdoor use or only for urban/street use?
        • giulioG Offline
          giulio @giulio
          Ghostracer Seems to use same battery as suunto app with 100 % screen off…
          Activity: walking
          But with display on ambient mode (dark with route visible)
          pilleusP 1 Reply Last reply Reply Quote 0
          • pilleusP Offline
            pilleus @giulio
            @giulio Ghostracer is a premium app. No doubt. Uses offline maps in various designs from mapbox or Google. Uses barometer (calibration at the start of the activity). Battery usage is quite good. 👍
            Wear standalone maps uses Google maps (road, satellite or hybrid.
            https://www.instagram.com/moves.are.life/
            Suunto Vertical Black Lime
            Suunto 9 Peak Pro Black
            Suunto Spartan Ultra Stealth Titanium
            giulioG 2 Replies Last reply Reply Quote 0
            • JorgeFDJ Offline
              JorgeFD
              i’m gving a try to ghostracer but i’m not able to use with ambient display. I had AMBIENT in screen and start an activit. If I don’t move my hand, screen turns dims for 1 sec and then turn off
              am i missing something?
              • giulioG Offline
                giulio @pilleus
                @pilleus
                For hiking need mapbox outdoor, then ghostracer is more suitable
                • giulioG Offline
                  giulio @JorgeFD
                  @jorgefd78
                  Yes…
                  You must turn on aod…
                  Then if you select ambient dimmer
                  You will have ambient on
                  JorgeFDJ 1 Reply Last reply Reply Quote 0
                  • JorgeFDJ Offline
                    JorgeFD @giulio
                    @giulio working right now. Thank you!
                    • giulioG Offline
                      giulio @pilleus
                      @pilleus
                      In ghostracer how can i get altimeter calibration in the activity?
                      • pilleusP Offline
                        pilleus @giulio
                        @giulio said in Suunto 7 - Tips and tricks, apps and watch faces:
                        @pilleus
                        On the S7 in Ghostracer swipe left, go to sensors, activate barometer and a screen to adjust the altitude will appear when you swipe back to the recording screen. Sometimes you have to repeat it to make it work.
                        • giulioG Offline
                          giulio @pilleus
                          @pilleus
                          👍👍i will try!!
                          Thanks
                          • pilleusP Offline
                            pilleus
                            Ghostracer - gpx routing only without recording the activity
                            On the smartphone: import a gpx file, copied to Ghostracer directory before with a file manager, add it as ghost, click the ghost to open it, click the three buttons at the top on the right side, edit and choose guide only,save and close, activate the ghost with the slider
                            On the S7: open Ghostracer, choose standalone mode, set screen to ambient dim (your display should be set to AOD before), choose the ghost you edited on the smartphone, wait for the GPS fix and you can follow the route without starting the recording of the activity.
                            Screenshot_2020-04-17-12-21-31-566_com.bravetheskies.ghostracer.jpg Screenshot_2020-04-17-12-21-47-364_com.bravetheskies.ghostracer.jpg Screenshot_2020-04-17-12-22-05-251_com.bravetheskies.ghostracer.jpg
                            • giulioG Offline
                              giulio @pilleus
                              @pilleus
                              Refresh of gps/screen?
                              Every 5 seconds?
                              • giulioG Offline
                                giulio @giulio
                                On mine i leave 5 second refresh ambient screen
                                • pilleusP Offline
                                  pilleus @giulio
                                  @giulio I use 60 (hiking), 5 (mountain bike) or 2 (road bike) seconds.
                                  • JANTIKAINENJ Offline
                                    JANTIKAINEN Bronze Member
                                    How do you see the map on S7?
                                    I have downloaded a map on the S7 but I don’t have the option to swipe to the 3rd tile where the map should be seen?
                                    Samsung Galaxy S24
                                    Suunto Race Titanium
                                    • giulioG Offline
                                      giulio @pilleus
                                      @pilleus
                                      I noticed that if in paired mode it consumes less battery than the gps alone mode…but in the ambient screen it is always late on the map and does not rotate immediately…I hope so much suunto will bring us navigation routes as soon as possible
                                      • giulioG Offline
                                        giulio @giulio
                                        I speak about ghostracer…
                                        at this point I don’t know which is better between ghostracer and viewranger … for outdoor use … both have big limits, non-ruotable maps and not optimal consumption
                                        • giulioG Offline
                                          giulio @JANTIKAINEN
                                          @JANTIKAINEN
                                          See in option in ghostracer app on phone,there’s the option on what you will see in s7…
                                          JANTIKAINENJ 1 Reply Last reply Reply Quote 0
                                            JANTIKAINEN Bronze Member @giulio
                                            @giulio Thanks found it.
                                            I created a route in Strava and tried to import it from Add Ghost --> Strava Routes but can’t get it to work.
                                            It looks like it’s trying but nothing happen.
                                            Have anybody been successful with that?
                                            Samsung Galaxy S24
                                            giulioG pilleusP 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
