    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 GPS accuracy compared to Garmin
    11 Posts 5 Posters 1.5k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      Eduardohood97
      Hi,
      I am training for a marathon, I would like a GPS watch to record my runs, I am not interested in heart rate or activity tracking. I am interested in GPS accuracy outdoor, speed etc. How accurate is the Suunto 9 in performance battery mode compared to Garmin? I red that the Suunto 9 battery drains fast in performance mode, is this true? How accurate is the Suunto 9 gps in performance mode in rugged terrain compared to Garmin Fenix 5 for example?
      Best Regards
      isaziI fejkerF 2 Replies Last reply Reply Quote 0
      • isaziI Online
        isazi Moderator @Eduardohood97
        @Eduardohood97 to be honest, GPS depends on so many factors that comparisons are very difficult. Which Garmin watch are you comparing with? Check dcrainmaker on Google and look for comparisons there, but be aware that Suunto 9 got GPS updates on the past months and performance are better now. Also check this forum for threads about comparing S9 GPS accuracy to other devices.
        Blog: isazi's home
        freeheelerF 1 Reply Last reply Reply Quote 0
        • freeheelerF Offline
          freeheeler @isazi
          @isazi
          and regarding the “drain fast” question… my opinion: no, it does not drain fast.
          I would say you can run 4-5 marathons within one battery charge. I don’t know Fenix 5, but with Fenix 3 I’ve certainly had a bigger battery drain than with S9
          living sideways
          E isaziI 2 Replies Last reply Reply Quote 2
          • E Offline
            Eduardohood97 @freeheeler
            @TELE-HO said in Suunto 9 GPS accuracy compared to Garmin:
            @isazi
            And which battery mode can I use on the Suunto 9 to run 4-5 marathons? On performance where the gps fix rate is the highest?
            isaziI 1 Reply Last reply Reply Quote 0
            • E Offline
              Eduardohood97
              How long can the Suunto 9 last? How many years?
                freeheeler @Eduardohood97
                @Eduardohood97 said in Suunto 9 GPS accuracy compared to Garmin:
                🤷 depends how you treat it…
                when I use performancemode with chest HR strap I get up to 32h predicted batterylife.
                this is reduced to around 25h if you use OHR and of course if you use backlight for nightruns and additionally GLONASS or Galileo it will be less (as usual, with more features activated it becomes less batterylife)
                living sideways
                • isaziI Online
                  @Eduardohood97 you get 25 hours in performance mode, so I believe you can run multiple marathons with that.
                  Blog: isazi's home
                  • isaziI Online
                    isazi Moderator @freeheeler
                    @TELE-HO I would talk about battery life, not drain, as I don’t know exactly how much energy is stored in each watch battery, but my F3 and F5 both topped at around 12 hours of battery life.
                    Blog: isazi's home
                    freeheelerF 1 Reply Last reply Reply Quote 1
                      freeheeler @isazi
                      @isazi
                      you’re right, drain is the unwanted excessive consumption
                      living sideways
                      • fejkerF Offline
                        fejker Gold Members @Eduardohood97
                        @Eduardohood97 for example, the Spartan Ultra has worse battery life than the S9/S9-baro and it is still capable of about 12-15h of battery life with all bells and whistles turned on (yes, navigation too), so I think you’re good in the battery department as far as marathons go.
                        SHUT UP LEGS!
                        -Jens Voigt
                        • S Offline
                          Shrek3k
                          Not quite sure if this is the perfect place to - once more - wonder about the GPS-performance of the (= my !) Suunto 9.
                          The GPS-performance (for me GPS+Galileo) for me in a regular running area with some challenges like trees and/or buildings is mostly acceptable, in the worst case mediocre due to some really annoying short but heavy ‘fluctuations’.
                          BUT whenever there is a firmware update (as the hotfix) - or a soft-reset - than suddenly the GPS-performance is significantly improved … in the same area as described before … and obviously slightly deteriorating after some days until it is (see above) … no longer really good.
                          @Dimitrios-Kanellopoulos … might this be connected to something like a ‘not perfect’ storage ‘cleaning’ referring to A-GPS, so that only at the first start(s) after a reset the performance is good, or is only at the first runs after a reset that the GPS-1second-rhythm is really kept? Just wondering … and hoping for an improvement… or higher consistency.
                          using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                          OS - Android 16/Pixel Pro 7
                          Register Login
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
