    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9, night lighting
    12 Posts 8 Posters 1.5k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Daniel HaeberliD Offline
      Daniel Haeberli
      Good morning, I have my watch that looks like a flashlight at night, it lights up more than during the day.
      I haven’t found a setting to fix my problem.
      does anyone have an idea?
      happy new year
      Suunto 9, v.2.16.26
      Tapio VäättänenT Brad_OlwinB 2 Replies Last reply Reply Quote 2
      • Tapio VäättänenT Offline
        Tapio Väättänen @Daniel Haeberli
        @Daniel-Haeberli
        If you set “do not disturb” through night time the watch goes of o standby and light is dim even when active.
        • Brad_OlwinB Offline
          Brad_Olwin Moderator @Daniel Haeberli
          @Daniel-Haeberli A reading of the manual or a search of the manual can help. Also, we need to know which watch you have. Here is the relevant section for the Suunto 9
          Vector/T6c/Vertical 2 Ti
            Daniel Haeberli
            @Brad_Olwin I already have the options set as you described and it’s the same thing.
            Suunto 9, v.2.16.26
              @Daniel-Haeberli said in Suunto 9, night lighting:
              What percent backlight do you have set? Do you use DND? Are you using the Standby mode?
              • synner88S Offline
                synner88
                Yep, I aslo want more granular control over the backlight:
                ▷ Spartan 9 - More options for the Standby Backlight @ Suunto Forum
                Regarding the Do-not-Disturb Feature, I have to set that manually each day/night! 😞
                Suunto 9 Baro + Android
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Offline
                  isazi Moderator @synner88
                  @synner88 why manually? You can enable automatic DND for the night.
                  Blog: isazi's home
                  • ? Offline
                    A Former User
                    Interesting. My Suunto 9 doesn’t light up at night at all even though I don’t use DND and don’t change any settings at all. I just put it in nightstand next to me. After a short time the screen goes black and remains black until I put the watch on next morning.
                    I wonder what the difference is?
                      Brad_Olwin Moderator @Guest
                      @silentvoyager said in Suunto 9, night lighting:
                      When the watch is not moving i.e. not on your wrist the screen will sleep. If you wear it for sleep tracking and have DND enabled, the screen will also go black unless Standby is on! Unfortunately, with Standby on, the backlight will remain on at a low level even if you enable DND. I have asked and wish this would change as I would like DND on to toggle Standby off.
                      1 Reply Last reply Reply Quote 5
                      • Bogdan1921B Offline
                        Bogdan1921 Silver Members Bronze Member
                        In this morning, the screen was black at my S9 Baro, without the posibility to see what it’s the time, and when I’ve moved my hand, nothing was happened. The alarm was ringing, the sleep was recorded, but the screen had no reaction. After a soft reset, from the top button, my watch had reaction again and now it’s work good. What do you think that it was?
                        Suunto Race
                        Polar H10
                        Iphone 14 Pro
                        Suunto 9 Baro [sold]
                        isaziI Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 1
                        • isaziI Offline
                          isazi Moderator @Bogdan1921
                          @Chindris-Bogdan unfortunately it’s not possible to remotely debug what happened to you. If it was a one off bug it’ll never happen again, otherwise you’ll better contact support. And if you find a way to reproduce that behavior it would be better.
                          Blog: isazi's home
                          • Dimitrios KanellopoulosD Online
                            Dimitrios Kanellopoulos Community Manager @Bogdan1921
                            @Chindris-Bogdan I had that. Sometimes I have seen people having it worse, the watch not using the screen at all. Solution was / is to drain the watch battery or turn it off
                            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
