How to view POWER data in SA?
@paul870
Did you already try to wipe cache and data ? It looks like this works for other people.Can you list your configuration here, for quick reference ?
app version
watch fw
phone model
android version
stryd fwand everything that can help
@sartoric SSS is at home, so will check and add that later.
No I have not wiped the cache / data will do that tonight.app version: 4.17.4
watch fw: all up to date, will add later.
phone: Sony Xperia Z3 model D6603
Android version: 6.0.1
Stryd fw: 1.2.0 model no: 13 software version: 3 -
Hi all I created a bug about this . Hold on
@paul870 hi Paul,
I cannot open that link. Did you delete the activity? Can you make that public if not?
We cannot solve the issue if we don’t have acess. Thanks
@Dimitrios-Kanellopoulos sorry about that seems it was set to private. changed now to public and another link below… https://www.suunto.com/move/paulheywood870/5e4d8b310117d52691c1712d
hope that will do it.
thanks,
Paul -
@paul870 cannot open that as well
@Dimitrios-Kanellopoulos why? any ideas what i can do?
@paul870
Hi Paul,
All your public activities are there.
https://www.sports-tracker.com/view_profile/paulheywood870
The one you share may not be public, is it? -
@Mff73 i made sure this was public, i will check again.
@Dimitrios-Kanellopoulos as @Mff73 said below, you could use any run under paulheywood870 if that helps, I have never seen any run with the power graph, so feel free to look at any of them.
@paul870 are you syncing with the Suunto app? your activities have strange data
@Dimitrios-Kanellopoulos i sync to MC then that syncs to ST which forwards onto SA
bit confusing but has been working for a year now.
@paul870 well that is the problem here. ST doesn’t support power data. SA does. SA is not ST
@paul870 MC will stop working for this soon as well. Why not just use SA?
@Dimitrios-Kanellopoulos said in How to view POWER data in SA?:
Dear Dimitrios, is there any hope for a fix of my case?
Directly uploading from watch to SA via bluetooth, no Power is shown there.
(see: https://www.suunto.com/de-de/move/michael430691/5e7a38122b80bf35a8cad981 )
However, Power is shown in the same activity on MC.
(see: http://www.movescount.com/de/moves/move331743453 )Watch: Ambit3 Vertical
Powermeter: Stryd Pioneer, chest mounted, connected with watch as PowerPOD
Powerdata on watch while running: yesSA Version 1.15.1 (7929) on iOS 13.3.1 (Iphone SE)
I’ve been reporting this for quite a while.
The watch has been superb for my needs and I only bought it in summer 2019.I’d really appreciate, if you can have a look into this.
kind regards
Michael -
@Brad_Olwin I use my Ambit3 50% of the time, so when that gets sorted then maybe I will change.
Some things I just find it hard to live without, like TAG’s and routes with POI’s and all the history of my TAG’s is the real killer, I cannot look at a previous training plan, sadly I have a touch of OCD and tagged everything in the past so that I can compare the same 3 month training plan with the previous one so I can really see where I improved or got worse, what injuries have done to me etc… how can I do that in SA?I know the answer is to port all that information over to Runalyze or TP or similar, but that’s work that well I would rather be running or other things.
regards,
Paul -
@Dimitrios-Kanellopoulos Oh… well that’s the answer.
thanks for all the help… at least that make sense.
@paul870 If you have all your data on MC you can do the history import to SA and that should have ok data
@paul870 You can export all of your routes and POIs, I have done that. For Tags, I miss them too. TP is my primary source for data so everything in MC is in TP for me. I will miss MC though, it was great!
@mzungu said in How to view POWER data in SA?:
kind regards
Michaeljust a quick note:
I recently purchased a Stryd v4. Still didn’t show power in SA after a Running workout with A3V.I also purchased a Suunto Spartan Ultra - Power was shown properly in SA App. (both Stryd, old and new)
Register Login
