    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 Baro vs. Garmin Fenix 5 vs. old Garmin FR 920 on tight switchbacks
    18 Posts 8 Posters 2.1k Views 8 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      This is a snapshot from Strava Flybys from today’s trail run that I did with two friends wearing Garmins.
      Suunto 9 - pink
      Fenix 5X Plus - blue
      FR 920 - black
      I wouldn’t say that Suunto’s track is the best here. It looks more angular due to slower logging rate and clearly cuts through all left turns more than other watches. This was uphill walking on a steep slope.
      • surfboomerangS Online
        surfboomerang
        The Suunto track looks pretty awful, but the other two watches aren’t much better imo. Did you use GPS only or GPS+ GLONASS/GAL?
        Suunto Vertical Titanium Solar
        OnePlus Nord 4
        ? 1 Reply Last reply Reply Quote 2
        • ? Offline
          A Former User @surfboomerang
          @surfboomerang GPS only. I should mention that this place is fairly challenging for GPS devices. It is on a steep slope covered with tall trees.
          I should also add that the GPS was logged every 8-15 seconds here. I strongly suspect that some algorithm was involved there because the points were logged only once the distance increased 10-11 meters from the previous point. The distance between points was very consistent and on these switchbacks was never less than 10 meters. I looked directly into the FIT file.
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            Dimitrios Kanellopoulos Community Manager @Guest
            @silentvoyager if you are on Android and perhaps experimenting with the SUUNTO app you can pull the raw data. That will give you a better overview.
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            suzzloS 1 Reply Last reply Reply Quote 0
              Yes the track is aweful
              • ? Offline
                A Former User @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos said in Suunto 9 Baro vs. Garmin Fenix 5 vs. old Garmin FR 920 on tight switchbacks:
                This is a very typical track for the local Pacific Northwest mountains, not worse than usual. This particular fragment is from a steep (reaching 40-50%) slope with dense evergreen tree coverage, but so are a lot of local trails. That is the reason Ambit series watches were so popular in this area. Ambits did noticable better than other watches.
                stromdiddilyS 1 Reply Last reply Reply Quote 4
                • suzzloS Offline
                  suzzlo Moderator @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos is it done automatically or did we need to do something to get “raw data”? and what exactly is “raw data”?
                  BR
                  Suunto: Race, S9Peak, Spartan Sport Wrist
                  Garmin: FR745, Edge 530
                  SA topics:
                  • Guides - https://forum.suunto.com/tags/guides
                  Mff73M 1 Reply Last reply Reply Quote 0
                  • stromdiddilyS Offline
                    stromdiddily Gold Members @Guest
                    @silentvoyager you use GPS only around here still? Seems to me like GLONASS works at least a little bit better.
                    Always carry a flaggon of whiskey for snakebite; and furthermore, always carry a small snake.
                    User of pretty much every watch since the Ambit 3 Peak. Now back in the family w SV2 :)
                    • Mff73M Offline
                      Mff73 @suzzlo
                      @suzzlo said in Suunto 9 Baro vs. Garmin Fenix 5 vs. old Garmin FR 920 on tight switchbacks:
                      BR
                      https://forum.suunto.com/topic/520/additional-external-tools/236
                      Where to find raw data
                      And some nice future stuff eventually
                      https://forum.suunto.com/topic/3490/quantified-self-io-the-topic-for-qs-discussions/80
                      SSU (retired), SV1, SV2
                      Wife : S9PP
                      SA: Always the latest beta :)
                      Android + Galaxy S205G
                      • ? Offline
                        A Former User @stromdiddily
                        @stromdiddily said in Suunto 9 Baro vs. Garmin Fenix 5 vs. old Garmin FR 920 on tight switchbacks:
                        I have yet to try Glonass. I’ve read that Glonass may be hit or miss. It might help in some cases but occasionally it may also cause large errors.
                        freeheelerF 1 Reply Last reply Reply Quote 0
                        • freeheelerF Offline
                          freeheeler @Guest
                          @silentvoyager
                          I would really like to know how the 3 available systems work independently from each other.
                          Hope Suunto gives us a toggle to switch them on/off separately
                          living sideways
                          isaziI 1 Reply Last reply Reply Quote 0
                          • isaziI Online
                            isazi Moderator @freeheeler
                            @TELE-HO there’s plenty of research papers on the topic. For simple users like us, there is no advantage of using GLONASS or Galileo on their own, unless you want reduced accuracy. If you play a bit with coverage and positioning errors (find something online) you’ll see that without GPS they are pretty terrible.
                            Blog: isazi's home
                            freeheelerF 1 Reply Last reply Reply Quote 1
                              freeheeler @isazi
                              @isazi
                              but only beceause that’s what is today, doesn’t mean it is still like that tomorrow?
                              living sideways
                              • isaziI Online
                                @TELE-HO for the foreseeable future, GLONASS and Galileo (obviously we are not talking about military use here) are to enhance GPS. Will there be a day in which they’ll work on their own? Probably, when more satellites will be on-line and working according to specs, and more frequencies will be used, but that’s beyond the hardware and life span of the watches we are wearing today.
                                Blog: isazi's home
                                  freeheeler @isazi
                                  @isazi
                                  https://www.deingenieur.nl/artikel/after-13-years-galileo-satellite-navigation-complete-at-last
                                  living sideways
                                    I always use Galileo can you try that ?
                                    • isaziI Online
                                      @TELE-HO extract from https://berthub.eu/articles/posts/galileo-accident/
                                      “The current status of Galileo is not that great. There are 26 satellites in space, 2 of them in botched (elliptical) orbits, 2 of them unavailable, 1 unavailable until further notice. This makes for 21 functional satellites, which is less than the “healthy” number of 24. Anything below 24 causes gaps in coverage, or at least, areas where the positioning accuracy will not be good enough.”
                                      You can play, in real-time, with the coverage of different GNSS systems on http://galmon.eu
                                      Blog: isazi's home
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 3
                                        Dimitrios Kanellopoulos Community Manager @isazi
                                        @isazi 😮
                                        Register Login
                                        • First post
                                          Last post
                                        Suunto Terms | Privacy Policy
