    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    2.9.42 S9 GPS no connection
    gps
    9 Posts 5 Posters 1.3k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • DD Offline
      D
      Hi,
      i’ve sometimes GPS connection loss since the last update, also the GPS and compass do not have the same accuracy.
      Does someone have the same experience?
      9 Baro
      • sartoricS Offline
        sartoric Moderator
        Did you try a soft reset ?
        Check if AGPS info are up to date
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Samsung A33 2022 - Android 15 - One UI 7.0
        Suunto App Android 6.7.9 beta
        Suunto App IOs 3.8.0 (21526) beta on MBP M1 Max
        DD 1 Reply Last reply Reply Quote 0
        • DD Offline
          D @sartoric
          @sartoric
          Yes, I did a soft reset and a AGPS update. The connection is steady and after a few minutes it gets lost for about 10 -25 minutes, it makes no difference to change between GPS, GPS/GLONAS, GPS/Galileo.
          9 Baro
          • surfboomerangS Offline
            surfboomerang
            For me, GPS alone became a little more unstable after the last update, but GPS+ Glonass or Galileo improved.
            Although I will do some more tests in the future.
            Suunto Vertical Titanium Solar
            OnePlus Nord 4
            • isaziI Offline
              isazi Moderator
              Could it simply be that now, with the introduction of the “GPS lost” notification, we’re simply aware of something that did always happen but we didn’t know?
              Before the last update I’ve never seen the message, but I’m sure I did lose GPS at times.
              Blog: isazi's home
              fejkerF 1 Reply Last reply Reply Quote 0
              • fejkerF Offline
                fejker Gold Members @isazi
                @isazi The message option has been there for a long time even on SSU. I have only seen it a couple of times on the SSU, but I can’t say anything for the S9 because it uses a different GPS chip. But I’m guessing the GPS warning/message system is the same as on SSU, so there must be something different with the GPS if you’re seeing the message more often than before.
                SHUT UP LEGS!
                -Jens Voigt
                isaziI 1 Reply Last reply Reply Quote 0
                • isaziI Offline
                  isazi Moderator @fejker
                  @fejker thanks for the info, I’ve never seen it before the last update, even in tunnels where I’m sure I lost GPS reception, but I simply may have not noticed, therefore thought it was a new addition.
                  Blog: isazi's home
                  • DD Offline
                    D
                    @fejker
                    There’s a new firmware version for S9, I think there’s the Problem, not the information is the Problem, I’ve more incorrect waypoints or none.
                    9 Baro
                    • fejkerF Offline
                      fejker Gold Members @D
                      @D yes, I know. I was just making it clear that the GPS lost message was not something new introduced with this new firmware and has been there for a while.
                      SHUT UP LEGS!
                      -Jens Voigt
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
