    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Future S9 firmware wishlist summary
    1.1k Posts 159 Posters 483.4k Views 151 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ink357I Offline
      ink357 @The_77
      @the_77 🤞🤞🤞
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel @ink357
        @ink357 oh no, please, not another metric that will haunt me and keep me forever under a certain threshold 😄
        S9PP 2.50.28
        ink357I 1 Reply Last reply Reply Quote 1
        • Brad_OlwinB Offline
          Brad_Olwin Moderator
          @ink357 said in Future S9 firmware wishlist summary:
          A nice feature would be the VO2 max for trail (like an another brand 😅) taking into account the D+ and temperature
          The S-series does supply VO2 Max from trail running. All my VO2Max is calculated this way. Already ahead of G……
          Vector/T6c/Vertical 2 Ti
            Brad_Olwin Moderator @stromdiddily
            @stromdiddily my S9 baro is at home. Will get back to ya.
              Brad_Olwin Moderator @MiniForklift
              @miniforklift I make an aid station spreadsheet, most races have aid times for a certain finish or I look up past results around my desired finish. I open the spreadsheet on the phone, hide columns I don’t need and rearrange if necessary. Then I take a screenshot and save it as a wallpaper. Works great, pull the phone out of my vest and onscreen is the info I need without unlocking so easy to do with gloves, etc.
              And I forgot. I do this in landscape mode and then lock phone orientation for the race. It doesn’t affect taking photos so I never unlock the phone.
              • BulkanB Offline
                Bulkan Moderator @ink357
                Yes they copied finally. The other brand. The s9 have it…
                Tu comunidad Suunto en Telegram: https://t.me/suuntocommunity (spanish)
                • ink357I Offline
                  ink357 @Łukasz Szmigiel
                  @łukasz-szmigiel i run only trails and my vo2 max is 37!!! I can’t go lower 🤣
                  Brad_OlwinB 1 Reply Last reply Reply Quote 1
                    Brad_Olwin Moderator @ink357
                    Do you use a belt? The OHR for me is highly inaccurate and will give very low VO2Max values. If the HR is accurate the VO2 Max should be consistent at least.
                    L ink357I 2 Replies Last reply Reply Quote 0
                    • L Offline
                      Likarnik Gold Members @Brad_Olwin
                      @brad_olwin I use the belt for all sports, but steep trails dump my score a lot. I just smashed my 8 years old PR on a steep trail (750m elevation gain in 3,4km) up an down - VO2 max dropped to 55 (it was 62.4 before). 3 days later, flat 10k in my z2 - VO2 max went back up - 58.4. Some flat runs and I will be back at 62 🙂 Not sure how accurate this is (you say that it’s quite good), but 7 points seems a lot? I’ll se when this covid cools off, I have a test in lab planned 😮
                      • ink357I Offline
                        ink357 @Brad_Olwin
                        @brad_olwin i used both. Sometimes i don’t want to take the belt, usualy when it’´s a cool ride.
                        I think it’s because the first time i use it i was walking so the based VO2 max was 30.
                        Maybe i can reset it ?
                        • Soojong MoonS Offline
                          Soojong Moon @BrunoH
                          @brunoh I think the black space is for the activity planning/calendar. AFAIK the activity schedule was displayed when I make a plan and sync with movescount website. Currently Suunto App doesn’t have this functionality but I believe this will come someday.
                          S9BT, A3P, Suunto Smart Sensor, Polar OH1
                          iPhone13 Pro Max (iOS), Windows10
                          Feature Suggestions:
                          1)Activity Planning with basic analytical function.
                          2)Basic Training Gear Management connected to Strava or Runalyze.
                          Brad_OlwinB 1 Reply Last reply Reply Quote 3
                            Brad_Olwin Moderator @Soojong Moon
                            @soojong-moon said in Future S9 firmware wishlist summary:
                            I hope so!!! I used this feature a lot and liked it.
                            Soojong MoonS 1 Reply Last reply Reply Quote 2
                            • MiniForkliftM Offline
                              MiniForklift Platinum Member
                              How does is work out VO2 Max if you don’t have HR tracking enabled during training, does it just calculate it using distance & pace?
                              SV Titanium Solar Forest
                                @miniforklift said in Future S9 firmware wishlist summary:
                                VO2 Max will not be calculated without HR
                                  Soojong Moon @Brad_Olwin
                                  @brad_olwin You are right. 😉 Even simple planning function helps me to train harder. However, it would be better if Suunto can work more on this.
                                  For example,
                                  • Plan distance, pace, intensity or route which are integrated with training loads or recovery time.
                                  • Analyze my training plan and warn over or under training and suggest optimum training.
                                  • If I set the yearly target such as half marathon, Suunto app recommends specific training plan until the racing day.
                                  • People can share and import training plan each other.
                                  The above functions may be similar to the adaptive training in S3 or S5. But, integrating the watch with Suunto app would be more powerful and flexile.
                                  In reality, I just want simple planning function similar to that of movescount 🙂
                                  1 Reply Last reply Reply Quote 5
                                  • А Offline
                                    Алексей
                                    Почему я не могу обновить свои suunto 9 baro black? Программа постоянно жалуется на отсутствие соединения с интернет.
                                    isaziI 1 Reply Last reply Reply Quote 0
                                    • isaziI Offline
                                      isazi Moderator @Алексей
                                      @алексей are you using Windows 7?
                                      Blog: isazi's home
                                      А 1 Reply Last reply Reply Quote 0
                                      • А Offline
                                        Алексей @isazi
                                        @isazi Да
                                        Alexander KleymenovA 1 Reply Last reply Reply Quote 0
                                        • Alexander KleymenovA Offline
                                          Alexander Kleymenov @Алексей
                                          @алексей windows 7 not supported. you can ask Dimitrios how to deal with it.
                                          А 1 Reply Last reply Reply Quote 1
                                          • А Offline
                                            Алексей @Alexander Kleymenov
                                            @alexander-kleymenov Какого Димитриоса? Дайте ссылку пожалуйста. Раньше я обновлял часы на windows7
                                            pavel.samokhaP 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
