    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Make firmware for Ambit 3 opensource
    Scheduled Pinned Locked Moved Ambit
    6 Posts 4 Posters 380 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • JMOppenheimJ Offline
      JMOppenheim
      Hi Suunto. Since Ambit 3 is starting to fall out of support (limited Suunto App features, etc), can you think about releasing the firmware code to the public so that we may have a crack at customising it?
      1 Reply Last reply Reply Quote 6
      • B Offline
        BobMiles Bronze Member
        I think that there is a project called openambit with which you can at least pull the fit files…
          JMOppenheim
          Thanks BobMiles! Ill check it out!
          • André FariaA Offline
            André Faria
            with the advent of AI and the ambit being so outdated, any chance of reconsediring this? or the communication protocols?
            Keen on loosing some time to maybe try to update openambit.
            Suunto Race S | Ambit 3 Peak Sapphire | Kailash | Hammerhead Karoo 3
            Garmin Edge 1040 Solar
            Ze StuartZ 1 Reply Last reply Reply Quote 0
            • Ze StuartZ Offline
              Ze Stuart Gold Members @André Faria
              @André-Faria if all you want is a phone/computer side client to perform the sync, it’s a pretty straightforward process with Claude Code to build your own. Concept as follows:
              1. Set up a bluetooth packet capture.
              2. Perform the functions you want your app to be able to do.
              3. Hand that to Claude Code and tell it to build an app that does that.
              This, at least solves the communication protocols part. I’d love the firmware, but I bet there’s IP in there around FusedAlti that Suunto wouldn’t want to open source, even if it’s probably just a well-adapted Kalman filter. I’m going to assume the recovery functions of that watch are considered IP as well, which continues down my path of legal blockers to OS Ambit firmware.
              https://zulusierra.co
              André FariaA 1 Reply Last reply Reply Quote 1
              • isaziI isazi moved this topic from Feature Suggestions
                André Faria @Ze Stuart
                @Ze-Stuart thanks for the input. Due to your suggestion it has been a long 2 week low sleep work to built an ambit app with claude ahahh
                Lot’s of reverse engineering. Not easy.
                I am missing just some points that if someone can help (I believe from Suunto would be easier, @pavel.samokha @dimitrios-kanellopoulos @isazi )
                1. How does the firmware decide a rule is a browsable WORKOUT (listed in the WORKOUT menu)
                  vs a normal pinned display app?
                  Is it purely that the rule is wired to the
                  PID_RUNNER_GPS_TEMPLATE_GUIDANCE display template, or is there another marker
                  (a rule flag, a CustomModes tag, an EXERCISE_MODES_RULE field beyond the 6 bytes
                  [RuleIdx][UseRule][LogRule] we see, an Apps-entry field, …)?
                2. What bytecode/data does the guidance graph consume to draw a segment (segment count,
                  per-segment duration/distance/lap end, upper/lower target, target metric)? i.e. what is the
                  .Binary a Category:"guidance" rule compiled to — its structure, or the App-Zone/VM
                  primitives it uses that a generic app does not?
                3. Is the guidance .Binary a different bytecode dialect than a normal App-Zone app, or the
                  same VM with specific built-ins/opcodes for segments/targets? (If the latter, the live
                  community compiler might be able to emit it with the right source.)
                Full claude recap here.
                These features that were lost in the movescount transition, and I am trying to get them back to the community.
                Register Login
                • First post
                  Last post
                Suunto Terms | Privacy Policy
