    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Ambit3 Peak display begins to striped
    Scheduled Pinned Locked Moved Digital service transition
    8 Posts 6 Posters 1.7k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • L Offline
      lkovari
      Re: Ambit 3 Peak Support
      Hi All,
      I would like to ask you, what does that mean if the display of Ambit3 Peak begins to stipped.
      This watch bought in the year 2014. I don’t know when manufactured. The SN#1438108362
      Thank you in advance.
      freeheelerF 1 Reply Last reply Reply Quote 0
      • freeheelerF Offline
        freeheeler @lkovari
        @lkovari
        it means it’s time for a suunto 9 upgrade 😉
        … just kidding… I suggest you request a service repair at Suunto.
        from far (it’s a bit blurry) it looks like in my friend’s old graphic calculator with broken display
        living sideways
        • zhang965Z Offline
          zhang965
          Hi dude,
          What else you could beg a 5 years old electronic watch to give?
          Go get a s9
          Winners Wear Winners
          • M Offline
            margusl
            I guess you already tried adjusting screen contrast? Sometimes Ambit screen artefacts go along with barometer issues, are baro & temp readings OK?
            • ianshowalterI Offline
              ianshowalter
              I’m no expert at this sort of thing at all, but I looked at that picture and had to wonder whether there’s a chance a tiny bit of water vapor might have somehow gotten in somewhere. It might be worth sitting it in a tub of rice in a dry place for a day or two and seeing if that takes care of it.
              Watch: SSU, FW 2.8.32
              App: 4.22.3 beta
              Phone: Motorola Moto G6
              Android 9
              HRM: Polar OH1
                freeheeler @ianshowalter
                @ianshowalter
                … this would help if there’s a leak in the watch but not in case he pressed a button while the watch was under water.
                if it is moisture, i don’t see this clearly, it would be worth a trial
                living sideways
                • B Offline
                  BKtoo Bronze Member
                  press lap and start the buttons and enter the service menu. There you will find display test. If it does not show errors, try resetting the clock
                  • L Offline
                    lkovari
                    Hi,
                    Thank you for your suggestions advices.
                    Unfortunately, the contrast settings not helped, the display test was fine in the service menu, I consulted with the service center, he told, later or sooner should be replace the display, therefore:
                    I bought a brand new Ambit3 Peak HR black again.
                    The price-value ratio is very good, I have two years warranty.
                    At last but not least the accuracy is also very good of the built-in positioning system. (GPS)
                    The following writings perfectly represent it:
                    https://the5krunner.com/2016/11/05/test-route-for-gps-devices/
                    Thank you.
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
