    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    GPS Signal lost
    33 Posts 6 Posters 4.3k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • F Offline
      Frederic Bronze Member
      Not sure where to post that in the forum but since people mentioned it in this section, I am adding it here too :
      Since the watch firmware update (2.8.24), I have been experiencing from time to time the same issue reported here (https://forums.watchuseek.com/f233/suunto-9-a-4720025-56.html#post49395195)
      As an example, I was doing the Tour du Mt Blanc, full sunny day, up in the mountains with no tree cover or any cover what so ever and my S9 lost GPS signal literally every day for more than 10 mins……
      Has anyone experienced that ?
      I understand that one needs to sync their watch but for a watch designed for “explorers” (you know, the people that are not every day within wifi access…), it’s hard to read that syncing before any activity is recommended.
      I am sad to have paid $599 for a new watch that is worse than my unbeatable Ambit2 that is being deprecated.
      PS I am using GPS setting and not GLONASS or GALILEO. I am not using GLONASS because that link mentions that : With GLONASS enabled, your watch consumes more battery life./suunto_spartan_ultra/suunto_spartan_ultra/features/glonass/
      Suunto Vertical
      My Suunto Workflow
      MyTourbook - First Steps
      Questions or bugs ?
      • zhang965Z Offline
        zhang965
        1, Try 12s-upper-button reboot the watch
        2, try to reset the watch
        3, try to active the recording 10m after the flash turns green.
        4, use GPS performance mode,
        5, use GPS/Glonass or GPS/Galileo
        Winners Wear Winners
        F 1 Reply Last reply Reply Quote 1
        • F Offline
          Frederic Bronze Member @zhang965
          @zhang965 said in GPS Signal lost:
          I’ve done 1), 2), for 4), i always use performance mode and for 5), as I’ve said before, I don’t want to use Glonass or Galileo as it is said by the official doc that it consumed more battery (the reason why I bought the S9 was to have more battery, not less…)
          As for 3), can you explain, i don’t understand…
          Thanks!
          Suunto Vertical
          My Suunto Workflow
          Questions or bugs ?
          • zhang965Z Offline
            zhang965
            my bad, it’s an arrow:
            for the 3), you should hold-on little bit after the arrow turns green to make sure your watch get more satellites,
            of course, Glonass and galileo will take off more battery, it’s your time to take your choice: a longer battery with poor GPS or …?
            • zhang965Z Offline
              zhang965
              https://forum.suunto.com/topic/2700/2-8-24-update
              Your AGPS is up to date as well?
              F 1 Reply Last reply Reply Quote 0
              • F Offline
                Yes, I have waited more than 20min for the green arrow but it never appeared.
                Huh, I would take better GPS than battery any day but the issue is that the suunto 9 was and is still advertised as great gps with great battery, if I had known the truth, trust me, i would have kept me trusty Ambit 2…
                Suunto Vertical
                My Suunto Workflow
                Questions or bugs ?
                freeheelerF 1 Reply Last reply Reply Quote 0
                • F Offline
                  My AGPS says 2019-09-29T00:00:00Z
                  I went on a run yesterday, full sun, no tree cover AT ALL and still the gps signal was lost.
                  Suunto Vertical
                  My Suunto Workflow
                  Questions or bugs ?
                  • freeheelerF Offline
                    freeheeler @Frederic
                    @Frederic
                    but it should be logic that more accuracy with more satellites that make the watch calculate more will result in more power consumption, no?
                    I assume for mont blanc you carry a small powerbank, then you can recharge and use gps+glonass AND performance setting 👍
                    living sideways
                    • F Offline
                      Frederic Bronze Member @freeheeler
                      @TELE-HO said in GPS Signal lost:
                      @Frederic
                      I wouldn’t mind trying to use GLONASS but I don’t run in urban areas, only in the mountains and here is what the official doc says.:
                      . Particularly in urban areas with tall buildings, GLONASS can improve track accuracy. In other areas, it is typically best to leave GLONASS disabled.
                      So based on this, it doesn’t seem that it will fix my issue, will it?
                      Suunto Vertical
                      My Suunto Workflow
                      Questions or bugs ?
                      • zhang965Z Offline
                        zhang965
                        it depends, you should have a try,
                        Glonass is RU, Galileo is EU,
                        in France, GPS+Galileo has better performance than GPS+Glonass,
                        in URK, it seems GPS+Glonass is better.
                        F freeheelerF 2 Replies Last reply Reply Quote 1
                        • F Offline
                          I guess I will try that before getting a new watch.
                          Thanks
                          Suunto Vertical
                          My Suunto Workflow
                          Questions or bugs ?
                            @Frederic
                            until now I used ambit3ps with gps only and had quite good signals with best gps settings… yesterday I first tried gps on s9b and decided to try gps+glonass next time. I think in the mountains, when you are at a rockface or between seracs gps signal could be not excellent… maybe glonass could still help here? I’ll get my experience during winter in that kind of topography…
                            but maybe your watch needs a forced firmware update or something? loosing signal sounds strange
                            living sideways
                              freeheeler @zhang965
                              @zhang965
                              they all call it something with G because of global, no? not only russia and europe 😉
                              but who knows with all the crazy politicians how it will be in the next year’s…
                              living sideways
                              • zhang965Z Offline
                                zhang965
                                ok, good luck,
                                I never had problem when my S9 on Montblanc
                                freeheelerF F 2 Replies Last reply Reply Quote 1
                                • F Offline
                                  @TELE-HO I will definitely try GLONASS but it is strange that I loose signals in places where I have been before with my Ambit 2 and didn’t have ANY issues. As a matter of fact, sometimes my wife is with me with her ambit2 and she doesn’t lose GPS.
                                  The other strange thing, like I mentioned in my original post is that this issue didn’t happen before 2.8.24
                                  Suunto Vertical
                                  My Suunto Workflow
                                  Questions or bugs ?
                                    living sideways
                                    • F Offline
                                      @zhang965 HA!👏
                                      Suunto Vertical
                                      My Suunto Workflow
                                      Questions or bugs ?
                                        @Frederic
                                        maybe flashing helps? I read that sometimes in other threads when the watch does not behave how it should …
                                        living sideways
                                        • F Offline
                                          @Frederic
                                          Do you have a link to the instructions ?
                                          Thanks
                                          Suunto Vertical
                                          My Suunto Workflow
                                          Questions or bugs ?
                                          • zhang965Z Offline
                                            zhang965
                                            Glonass seems better in higher latitudes zones,
                                            Galileo in mid-latitudes zones gets better
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
