    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 5 - tracks don't override on edits or similar names
    Scheduled Pinned Locked Moved Suunto 5
    bugclosedfixed
    28 Posts 6 Posters 6.9k Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • sartoricS Offline
      sartoric Moderator @Mff73
      @Mff73
      and tagginator 😄
      SVTS - 2.50.28
      SSSWHR BARO Amber - 2.8.32
      Samsung A5 2016 - Android 7.0
      Suunto App Android 6.11.8 beta
      • Łukasz SzmigielŁ Offline
        Łukasz Szmigiel
        Unfortunately I had the same issue again - this time with trying to import GPX (from Strava) and save a track based on it.
        It syncs with watch instantly and it seems that the metadata is being correctly displayed (ie. elevation, name or total distance) but track thumbnail is from a recently deleted track that is either in SA’s cache or remaining in the watch memory. Since the track that was erroneously displayed was close to my home, I went to investigate and it wasn’t just the thumbnail - the watch was in fact loading older track.
        This may lead to unpleasant surprise on a race day.
        I’ve tried resetting all SA data (relogin, resync with watch, etc.) but it didn’t fix the issue. What fixed the problem was:
        1. Remove the track that failed to synchronize.
        2. Create a throwaway track and synchronize it with the watch.
        3. Confirm that a right track was synchronized by looking at track thumbnail in the watch navigation screen.
        4. If the right track was synchronized - create and synchronize the final track.
        5. If the problem persists, repeat step 2 and 3 until track thumbnail on watch matches track shape in SA.
        The steps above suggest that it’s some kind of cache issue but it’s hard for me to track it - if it’s watch or SA related. Or perhaps the bug is being triggered by saving track to SA without watch connection, etc.
        Once you know that you have to check the track shape in watch and compare it with SA it’s not a big deal but imagine that you’ve made some tweaks to an old track and they are so small that you can’t see it immediately on small screen and the watch is going to guide you through an old track.
        S9PP 2.50.28
        sartoricS 1 Reply Last reply Reply Quote 1
        • sartoricS Offline
          sartoric Moderator @Łukasz Szmigiel
          @Łukasz-Szmigiel
          As @Dimitrios-Kanellopoulos said, there was a similar issue in the past (probably I reported it) with duplicate routes and strange data mix.
          But it was, as far as I remember v3.something.
          I use routes very much, and I’ve never faced that issue again.
          Did you already try to uninstall and reinstall the last app version ?
          @Dimitrios-Kanellopoulos Maybe it could be related to Android10 or Pixel XL ?
          Edit
          Found this :https://forum.suunto.com/topic/2174/android-3-64-0-generic-comment/54
          but there was even an older similar one
          SVTS - 2.50.28
          Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 0
            Łukasz Szmigiel @sartoric
            @sartoric I didn’t reinstall the app but cleared all the data (ie. cache + data) which essentially resets it. Also, I’m on latest betas.
            It’s the first time I’ve stumbled upon this error after last time I was reporting it (September last year I think) so I thought it got fixed.
            S9PP 2.50.28
            sartoricS 1 Reply Last reply Reply Quote 0
            • sartoricS Offline
              @Łukasz-Szmigiel
              Just for testing purpose, can you try to reinstall it ? Just to avoid that for some unexplicable reason, Android do cache something
              SVTS - 2.50.28
              Łukasz SzmigielŁ 1 Reply Last reply Reply Quote 1
                @sartoric I’ll do it next time the bug occurs as it seems to be fine after I finally got the GPX based track on watch.
                S9PP 2.50.28
                  Dimitrios Kanellopoulos Community Manager
                  I have reported this, for me it happens if there is only one route. Ca n you verify this. ?
                  Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
                    Łukasz Szmigiel @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos I have several routes in SA, around half of them synchronized with the watch. There were 3 routes in watch memory when the bug occurred this time.
                    S9PP 2.50.28
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
