    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 baro and climbed meters + suunto app
    Scheduled Pinned Locked Moved Suunto app and other software services
    suunto 9suunto appclimb
    10 Posts 4 Posters 1.8k Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • O Offline
      ollemelin Bronze Member
      Hello!
      As I understand suunto 9 baro does not register hills less then 2 meters (?).
      When I plot a typical track in suunto app I get total climb of 30 m in 2 km. When i run my suunto only register 15 m. I’m ok with that but I really thought suunto app would convert my activity to the right amount of meters. The map is always gonna show better data than an hand held gps-device while running
      In this case i know for sure that the total climb is 30 meters. Strava does not eather convert to the right amount of meters.
      Anyone else having the same trouble?
        Dimitrios Kanellopoulos Community Manager
        That is correct. Needs 3m to register ascent that is to remove noise as your arm swings even 1m
        Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
        O 1 Reply Last reply Reply Quote 0
        • O Offline
          ollemelin Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos said in Suunto 9 baro and climbed meters + suunto app:
          I know, but my question was really why the suunto app (and strava) does not autocorrect when they make use of the terrain model? It should be an easy implementation.
          Dimitrios KanellopoulosD Mff73M ? 3 Replies Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @ollemelin
            @ollemelin Strava can via the web but all service have filters for ±2m as it’sa too small variation.
            • Mff73M Offline
              Mff73 @ollemelin
              @ollemelin
              I would prefer trust my Baro instead of map corrections in mountain.
              Altitude correction assumes your position is really exact AND map altitude data are exact.
              SSU (retired), SV1, SV2
              Wife : S9PP
              SA: Always the latest beta :)
              Android + Galaxy S205G
              • O Offline
                Yeah, but the terrain model does not have variations. I understand the ”problem” but autocorrection with terrainmodel should really work if the numbers are off that much.
                • O Offline
                  ollemelin Bronze Member @Mff73
                  @Mff73 said in Suunto 9 baro and climbed meters + suunto app:
                  @ollemelin
                  On longer climbs the numbers are almost always correct. But on small climbs it does not work that good. Not even with 3-4 meters climb.
                  As an GIS and survey engineer I do understand the problem with measurment. But thats why er have software to manipulate data 🙂
                  But then…the terrain model can also be off
                  Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                    I think you understand the problem here, and why the decision to make such a filter.
                    On a side note, the altitude data are recorded unfiltered. So a simple parser could expose the “real” ascent, though imo at least a -=1m filter is needed. (remember arm swing)
                    • ? Offline
                      A Former User @ollemelin
                      @ollemelin said in Suunto 9 baro and climbed meters + suunto app:
                      Map auto-correction may be very inaccurate because it depends on accurate coordinates, which is often challenging on mountainous terrain.
                      Consider the following example. You traverse across a steep mountain slope on a narrow trail. Half of sky is obstructed by the mountain, so the number of GPS satellites is limited and positional accuracy isn’t great. As a result of that the GPS track can wobble 10-15 meters either way across the slope. Now, those inaccurate coordinates are fed into the elevation model, and each movement to either side may translate into a large elevation jump or drop that wasn’t actually there. That may add to a lot of extra elevation gain.
                      The model is also very inaccurate when crossing bridges or going through tonnels. Every time you cross a bridge the elevation model will have you going to the bottom and then go up again to your previous level.
                      O 1 Reply Last reply Reply Quote 1
                      • O Offline
                        ollemelin Bronze Member @Guest
                        @silentvoyager said in Suunto 9 baro and climbed meters + suunto app:
                        Yes, thats correct. But on longer climbs in the mountains its not a problem. The device is spot on.
                        My issue is with flow-tracks with small hills. I actually take a lot of meters on that kind of trails. As I live in sweden the data for terrainmodels are also very good.
                        Register Login
                        • First post
                          Last post
                        Suunto Terms | Privacy Policy
