    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Strava export not correctly recording pauses
    Scheduled Pinned Locked Moved Suunto app and other software services
    77 Posts 11 Posters 17.4k Views 12 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Jack DavisJ Offline
      Jack Davis
      I would like to flag this as an issue as well and I don’t believe it’s ‘Just how Strava works’. My partner has a Garmin watch and if she pauses her watch her split on Strava only shows the moving time whereas if I pause my Suunto run it incorperates the pause into my split on Strava.
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @Jack Davis
        @Jack-Davis hi Jack this issue is about splits not the total moving time. I own a garmin as well and it does work as Strava explains it here:
        https://support.strava.com/hc/en-us/articles/115001188684-Moving-Time-Calculations
        When uploading runs Strava relies on the recorded “timer time” which is the time the app or device was unpaused to determine moving time. As long as your device is recording conventional pauses, Strava will respect any pauses recorded in the file whether your device pauses automatically or you manually hit the pause button. It’s important to keep in mind is that if you choose to pause you must do so consistently. If there are any pause events in your activity file our server will not remove any additional resting time. If you do not pause at all our server will calculate moving time based on the recorded GPS data. Again, even though elapsed time may be the same, Strava may calculate moving time differently than other platforms.
        Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
        Jonathan NewbyJ 1 Reply Last reply Reply Quote 1
        • Jonathan NewbyJ Offline
          Jonathan Newby @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos you own a garmin🤭🙃
            Dimitrios Kanellopoulos Community Manager @Jonathan Newby
            @Jonathan-Newby I test competitor watches. I am a fieldtester 😄
            You can ask me anything about it
            • Šón ČestrŠ Offline
              Šón Čestr
              Here’s another strange, related sample:
              https://www.strava.com/activities/2459472037/overview
              https://app.suunto.com/move/seanchester/5d0894c88bfe5dc4be4e4aec
              This activity contains no pauses. However, Strava (the Suunto export) and my watch both report 320 metres longer than does the Suunto app. In Strava, the pace goes wonky in those last 300m, and it reports a personal fastest 1km time when I was just jogging. GPS reception was spotty in the middle of the run (despite open skies), but I take speed/distance off the Stryd footpod. I had FusedTrack enabled.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                Dimitrios Kanellopoulos Community Manager @Šón Čestr
                @Šón-Čestr Fused track did that for sure. Strava does not like fused track. A workarround for this is to export the Strava GPX and reupload it.
                REgarding splits we are testing the fix. IF you like to participate on the test of the fix for the split times and paused data @Šón-Čestr (We talked about it the drops when paused in the traffic light) I can be providing you manually the fit files to upload to strava if you give me the Suunto app links .
                Šón ČestrŠ 1 Reply Last reply Reply Quote 1
                  Šón Čestr @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos Thanks, I will avoid FusedTrack for now then.
                  As for the splits fix, yep, I’d be happy to test it. I might be a bit slow to report back, though, as I’m travelling these days. I will reply to this message with the Suunto app links when I get a chance.
                    @Šón-Čestr Top thanks!
                    Y 1 Reply Last reply Reply Quote 0
                    • Y Offline
                      Yurgo @Dimitrios Kanellopoulos
                      @Dimitrios-Kanellopoulos, thanks for fix! But ive got something strange after update. There are no any info about pulse and zones of activities if to check it on watches. It was lost after update! Before device has been updated i can check target pulse and assigned zones of just saved training directly on watches. After update this info is unavailable there.
                        Dimitrios Kanellopoulos Community Manager @Yurgo
                        @Yurgo after the update all prev activities are compressed so these stuff are wiped out. You can check those via the app.
                        On new activities after the update it will be fine to check them via the watch as well.
                        • G Offline
                          GD628
                          Hello,
                          now i did the update on my watch and did a swim and i saw some diffrents but i´m not satisfied!
                          You can see it on the picture!
                          • movement time wrong so the calculate pace wrong
                          • too many rounds
                          I think only the manuel round have to import to the Strava not a mix.
                          Maybe same problem at run and bike, i will test it after my holidays.
                          On the Suunto app everythink is right! (i hope😀 )
                          Hope that it has not already been described in the previous contributions.
                          More issue but not in this post!
                          Suunto App really slow!!! 😴
                          In the Suunto app not all possible to make all settings like in Movescount!
                          GPS quality is bad! 😕
                          I will confirm it and open a seperate Post!
                            Hi we have deployed the fix for the paused records in Strava.
                            You split should be fine now. Please do give feedback here about this!
                            Its for newly synced activities
                            Swimming is a separate subject, let’s keep it scoped there. However, those pause records are also removed from swimming.
                            Šón ČestrŠ 2 Replies Last reply Reply Quote 1
                              @Dimitrios-Kanellopoulos Great, thanks guys! this first upload today looks much better: run had a lot of pauses, up to 10 minutes long (stretches/drills), and the data looks very clean on Strava now.
                                @Dimitrios-Kanellopoulos not sure if you want a new thread opened for this? But I had a very bad Strava export today after a fartlek run. The data looks quite appropriate in Suunto App, but the Strava activity has spikes reaching 45 km/hr:
                                https://app.suunto.com/move/seanchester/5d37ac7617683a5924ecafe3
                                https://www.strava.com/activities/2557972773/overview
                                  Looks like it lost GPS ?
                                  Šón ČestrŠ 1 Reply Last reply Reply Quote 0
                                    @Dimitrios-Kanellopoulos Yep! But the pace/distance data is coming from the Stryd footpod and looks fine in both Stryd Power Center and Suunto App. Only Strava appears affected (except, of course, for the gps trace).
                                      @Šón-Čestr hmmm. IS it sure that Pace on Strava is from Stryd? I am not sure about that. Just to understand on TP is it ok?
                                        @Dimitrios-Kanellopoulos I don’t see any instantaneous velocity faster than about 3’56/mi (downhill) on TrainingPeaks:
                                        http://tpks.ws/36ICQZJU6AL5JSYJIILU4465OA
                                          Šón Čestr @Šón Čestr
                                          @Dimitrios-Kanellopoulos okay, it looks like you’re right. Here’s the data from Stryd:
                                          https://www.stryd.com/powercenter/run/6416472546017280
                                          (I see now the peaks in TP and the errors in SA: I’m not accustomed to either interface.)
                                          So this implies that I’m still getting speed/distance from gps/wrist acceleration? It’s very frustrating both how hard it is:
                                          a) to set up the S9 to take pace/distance only from Stryd; and
                                          b) to know what is the data source that the watch is currently using.
                                          I’ve been trying to get these settings correct since I upgraded from the A3P several months ago. 😢
                                            @Šón-Čestr let me help. Its easy.
                                            1. Repair Stryd as a footpod. The moment you do it go on the watch to the paired devices list, find the footpod and turn off immediately the autocalibration. That will make the watch take pace ONLY from stryd and the track will be recorded as well.
                                            2. That it.
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
