    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Fusedalti during climbing
    11 Posts 5 Posters 951 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      This post is deleted!
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @Guest
        @mountainChris Hi, what do you reffer to as steep terrain? Eg climbing with a rope vertical or a 20%-40% grade ?
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        ? 2 Replies Last reply Reply Quote 0
        • ? Offline
          A Former User @Dimitrios Kanellopoulos
            @mountainChris correct. You can give it a try. If that fails, meaning that fused alti + GPS goes wonky , my suggestion would be to use a mode that does not have fused alti. That would be a mode with no GPS or just turning off the GPS.
            Just for the reference:
            • If you climb a wall (rope) I understand that the GPS can be wondering off
              However, the GPS altitude is not calculated via the “same” way and I am sure it should work much better, not destroying so much the fused altitude calculations.
            But I have not tested this personally so I do still hold my doubts.
            • ? Offline
              • ? Offline
                • General_WittG Offline
                  General_Witt
                  Yesterday I summited a peak with a very steep trail just before the highest point. This mount is 1616 meters high, but the watch (Suunto 9 Baro) got 1669 meters as the highest point reached. How is it even possible to miss the correct altitude for 50+ meters? It was a very clear sunny day and I was partially covered by some big trees. Could it be the trees?
                  • W Offline
                    WEM_t
                    Hey!
                    It seems fused alti does correct altitude only if a “certain” GPS accuracy is reached.
                    I often use the watch in difficult terrain. If the altitude is calibrated corrected before entering a route the climbing piches are recorded corrected and only the effects of barometric influence are visible.
                    This is a workout where I’ve climbed single pitch routes in an icefall in a small canyon. As you can see… perfect results:
                    So I see no issue here
                    (Used watch: Suunto Spartan Ulta)
                    • ? Offline
                      A Former User @WEM_t
                      • ? Offline
                        A Former User @General_Witt
                        • Brad_OlwinB Offline
                          Brad_Olwin Moderator
                          I do no manual corrections and FusedAlti works extremely well. Here is a link to last Sunday’s climb/SkiMo in another forum. Some of our climb was quite steep 50°
                          Vector/T6c/Vertical 2 Ti
                          • First post
                            Last post
                          Suunto Terms | Privacy Policy
