    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 OHR readings
    43 Posts 19 Posters 8.7k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • plopes73P Offline
      plopes73
      Hi,
      I just added this :
      https://forum.suunto.com/topic/2374/heart-rate/6
      Cheers
      S9 Peak 2.18.18
      Vertical
      Android 10
      Suunto App 4.45.5
      • zadowZ Offline
        zadow
        Hi Guys,
        Did you know that Suunto knows all these tips and tricks and there is whole blog on Suunto web site about this? And especially about warm-up before activity. Not only warm up for your body, but warm up for Heart Rate sensor as well šŸ™‚
        *If your watch shows inaccurate heart rate readings at the start of your exercises, a warm up may solve the issue:
        Warm up for yourself: The quality of wrist-based HR measurement heavily depends on the blood flow to your arms and hands. A proper warm up for 10-15 minutes increases the blood flow and improves the quality of WHR readings.
        AND
        Warm up for the heart rate sensor: The sensor needs some time (several minutes) to lock on your heart rate. To give the sensor time to warm up, we recommend opening the exercise start screen already while getting ready for your workout (e.g. when changing clothes).*
        https://www.suunto.com/cs-cz/Content-pages/what-should-you-know-about-wrist-heart-rate2/
        Suunto Race
        Suunto S9 Baro Titanium, Ironman l.e. (607/1406)
        Suunto Smart Sensor
        Wahoo Tickr FIT
        Hammerhead Karoo 2
        Swim Ride Run Rest Repeat
        1 Reply Last reply Reply Quote 4
        • pilleusP Offline
          pilleus
          I tested a Suunto 9 and a Spartan Sport WHR Baro for cycling. Both gave me bad OHR values. I used all tips and tricks given from Suunto.
          Then I placed the watches on my right arm/wrist and was astonished to have usable values immediately. Not only once, but ongoing.
          May be this is worth trying for other people too.
          https://www.instagram.com/moves.are.life/
          Suunto Vertical Black Lime
          Suunto 9 Peak Pro Black
          Suunto Spartan Ultra Stealth Titanium
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            Dimitrios Kanellopoulos Community Manager @pilleus
            @pilleus this ?
            Creator of quantified-self.io - sync Garmin and COROS activities to Suunto, import Suunto routes, deliver Suunto routes to Garmin courses, and analyze training data in one private dashboard.
            pilleusP 1 Reply Last reply Reply Quote 1
            • pilleusP Offline
              pilleus @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos said in Suunto 9 OHR readings:
              this ?
              Ah, okay, I didn’t read it before.
              Yes, I can confirm this. The same 2 - 3 cm behind the wrist, the same width of the strap, just the other (right) arm.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
                @pilleus Perhaps we need to make a poll about this ?
                jsr184J 1 Reply Last reply Reply Quote 0
                • jsr184J Offline
                  jsr184 Bronze Member @Dimitrios Kanellopoulos
                  For me, with Spartan Sport WHR Baro OHR doesn’t work no matter what I do. I didn’t try yet to jump on my right foot during the full moon spitting behind my left shoulder šŸ˜‰ Usually, I use the chest strap and whenever I forget it or for some reason it won’t connect ( this week I totally forgot that I left the watch in airplane mode and used OHR during cycling accidentally ) the HR I get is rubbish. In my case it’s a lot lower than if should be, almost near my resting HR recording values 50-60bpm during activities like cycling, running or HIIT circuit. Sometimes it elevates 100-130 just to drop down again and in some cases I am not able to re-adjust my watch every few seconds measuring 2 inches from my wrist etc. Considering other devices I have been using, OHR in Suunto is the worst I have experienced so far. If not that I can pair it with the chest strap I would probably switch already to something else.
                  ? 1 Reply Last reply Reply Quote 1
                  • ? Offline
                    A Former User @jsr184
                    @jsr184 Same for me. I avoid using OHR as much as possible. But yesterday I had issues with my Polar H10 and had to use OHR for a short warmup on treadmill. OHR was correct in the beginning of the warm-up, but once I picked up the pace it shot up to 185, and then to 200+. I am pretty sure my actual HR at that moment was in upper 150s or lower 160s.
                    By the way, a bit of off-topic - my Polar H10 HRM fully discharges battery in about 3 months. It has just gone through the second battery in about 6-7 months of usage. Is that only me who has this issue?
                    • S Offline
                      Shrek3k
                      Just to give my 2 cents … currently using a Suunto 9 and before a Spartan Sport WHR, and I am usually quote fine with the OHR with both watches.
                      Usually means: excellent results while cycling, walking, hiking and on a stationary bike, very good results on an elliptical trainer and while doing ā€œstreet runsā€ and not too rugged/technical trail runs, really acceptable while doing technical trail runs and … not so good (and I knew it before because of the movement) while rowing and during cross training / weights.
                      using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                      OS - Android 16/Pixel Pro 7
                      pilleusP 1 Reply Last reply Reply Quote 0
                      • pilleusP Offline
                        pilleus @Shrek3k
                        @Shrek3k said in Suunto 9 OHR readings:
                        On the left arm/wrist? How strong is the strap fixed? Can you show us the exact position (behind the wrist, 2 cm or 3 cm)?
                        Thanks for your advice!
                        S 1 Reply Last reply Reply Quote 0
                        • plopes73P Offline
                          plopes73
                          Hi all,
                          Just to avoid misunterstandings, In my case, I had to change the watch to my right wrist because I’m right-handed, if one is left-handed, so left wirst it’s the dominant wrist.
                          @Dimitrios-Kanellopoulos if you do a poll about this, my sugestion is to use "dominant " and "non-dominant " wrist, to keep it clear šŸ™‚
                          Cheers
                          S9 Peak 2.18.18
                          Vertical
                          Android 10
                          Suunto App 4.45.5
                          • S Offline
                            Shrek3k @pilleus
                            @pilleus said in Suunto 9 OHR readings:
                            Apologies for forgetting to mention these details: left wrist (slightly higher (approx 3 cm) and tighter than usually / during ā€œregular hoursā€ ) … more or less tighter one notch, then pushed up until it ā€œfeels good, tight, but comfortableā€, and it is my non-dominant side, as I am right-handed (not very scientific šŸ˜‡)20190503_141422.jpg
                            • pilleusP Offline
                              pilleus @Shrek3k
                              @Shrek3k thanks, my experience is the same, just on the right arm.
                              In my opinion it’s a difference between running/walking and cycling. The problems happen during cycling, never during running/walking.
                              S 1 Reply Last reply Reply Quote 1
                                BTW feel free to vote
                                https://forum.suunto.com/topic/2418/ohr-test
                                • S Offline
                                  Shrek3k @pilleus
                                  @pilleus I agree that there seems to be or is a difference between cycling and walking/running. But for me it seems to be better when cycling - as long as I avoid cobblestone and give the watch some to ā€œsoakā€ (feels like a waste of time and is rather annoying but seems to be worth the time).
                                  • S Offline
                                    Shrek3k @Dimitrios Kanellopoulos
                                    Before voting I for example need to try the other arm which I have not used with / tried for OHR as I have been able to receive acceptable results on my ā€œusualā€ arm …
                                    • NicolasPN Offline
                                      NicolasP
                                      This week on the treadmill.
                                      First 3 minutes not accurate then a jump at 206bpm 😰 then was I would say accurate.
                                      SST
                                      • ? Offline
                                        A Former User @NicolasP
                                        This post is deleted!
                                        • NicolasPN Offline
                                          NicolasP
                                          Well, mine is a Trainer, less expensive than the 9.
                                          But I would say that except some what I would call minors and exceptional issues the ohr readings are usually not that bad.
                                          SST
                                          • pilleusP Offline
                                            pilleus @NicolasP
                                            @NicolasP said in Suunto 9 OHR readings:
                                            Trainer
                                            Trainer gives me better results than the 9. No doubt.
                                            With your input, this post could be even better šŸ’—
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
