    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 9 OHR readings
    43 Posts 19 Posters 9.0k Views 20 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • valdis830V Offline
      valdis830
      I have observed that if I activate instant HR measurment in watch mode about 5 minutes before activity, then initial readings at the start of activity are much faster and more precise. It’s like take time for soaking HR. Is it my perception or does it really work this way?
      More tricks to improve reading? BTW in my wrist seems works well, with common errors like low spikes.
      D J Jessica MonkJ 3 Replies Last reply Reply Quote 2
        Dimitrios Kanellopoulos Community Manager
        wow ! That is a nice discovery!
        Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
        • D Offline
          Droro @valdis830
          @valdis830 interesting, because on spartan trainer there is a spike to about 200bpm in first 5 minutes of running. Lots of posts about this online.
          Dimitrios KanellopoulosD valdis830V 2 Replies Last reply Reply Quote 1
            Dimitrios Kanellopoulos Community Manager @Droro
            @Droro yeah same here !
            D 1 Reply Last reply Reply Quote 1
            • D Offline
              Droro @Dimitrios Kanellopoulos
              @Dimitrios-Kanellopoulos sounds like a firmware issue because the ohr does work OK in general. (well enough for me)
                valdis830 @Droro
                @Droro I have had them like that, but I have tried in this way and it seems to improve. Then I only wait about 20-30 seconds until the reading is fixed.
                • sartoricS Offline
                  sartoric Moderator
                  @valdis830
                  Do you have 24/7 enabled ?
                  SVTS - 2.50.28
                  SSSWHR BARO Amber - 2.8.32
                  Samsung A5 2016 - Android 7.0
                  Suunto App Android 6.11.12 beta
                  valdis830V 1 Reply Last reply Reply Quote 0
                    this warmup issue is known. Unfortunately it is a vallencell side story (their FW).
                    I have communicated this right now to Suunto.
                    Please keep me posted on this thread if that also solves other people’s issues (the suggestion of @valdis830 )
                    valdis830V 1 Reply Last reply Reply Quote 3
                      valdis830 @sartoric
                      @sartoric I’ve never used 24/7
                        valdis830 @Dimitrios Kanellopoulos
                        @Dimitrios-Kanellopoulos It would be great if it were solution. For this I have shared my experience 😉
                        • sartoricS Offline
                          sartoric Moderator
                          @valdis830
                          OK. It was just to check if you’ve seen improvements running the “instant” measurement additionally to 24/7
                          I have 24/7 enabled and usually “HR locking” takes (most of the times) less than 20 seconds and it is accurate enough from the beginning.
                          SVTS - 2.50.28
                          J 1 Reply Last reply Reply Quote 1
                          • J Offline
                            jsuarez Bronze Member @sartoric
                            @sartoric I use 24/7 and it gives me good results specially during sleep. However, OHR for running really works bad for me, so I always use a belt. My watch is Spartan Sport WHR Baro.
                            It was funny one day that I forgot the belt and trained with OHR to find that I was supposedly warming up at 196bpm… 😂
                            • Brad_OlwinB Online
                              Brad_Olwin Moderator
                              I tried this long ago and for me OHR just does not work well…unless I run on pavement and it is relatively flat. I found out at a conference that OHR is good to great if run on pavement and am not running steep hills. But on trails it just doesn’t work. This is variable as for some it works well. Hopefully more work will get it functioning better!
                              Vector/T6c/Vertical 2 Ti
                              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 5
                                Dimitrios Kanellopoulos Community Manager @Brad_Olwin
                                @Brad_Olwin same experience . I would add also treadmill.
                                However, I have tattoos and really slim arms
                                • J Offline
                                  jw cou Silver Members @valdis830
                                  @valdis830 thanks a million for this!!
                                  I gave it a try today (=while preparing for my run, I activated the heart rate reading from the main menu of the watch - I don’t use 24/7 hr), and see the difference below! Same track/pace/weather/absence of warmup.
                                  Without your trick:
                                  With:
                                  J 1 Reply Last reply Reply Quote 2
                                  • J Offline
                                    jsuarez Bronze Member @jw cou
                                    @jean-william-cousin Those look like pretty good readings!
                                    • SlaShS Offline
                                      SlaSh Platinum Member
                                      Funny thing that Farmin acting the same, if you turn HR reading before workout it is way more accurate 🙂
                                        Keep the posts coming here people
                                        D 1 Reply Last reply Reply Quote 0
                                        • D Offline
                                          @Dimitrios-Kanellopoulos tried it, didn’t work, still unrealistic hr for first 10 min.
                                          • Jessica MonkJ Offline
                                            Jessica Monk Bronze Member @valdis830
                                            @valdis830 said in Suunto 9 OHR readings:
                                            Use a chest strap 🙂
                                            Suunto OHR has never worked for me (consistently 40bpm higher than actual). Chest strap fixes this for me. Can’t blame 'em, tattoos don’t play nice with OHR readings!
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
