    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    S9 Baro Wishlist
    227 Posts 62 Posters 76.9k Views 62 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Guest
      @silentvoyager lol really?
      Creator of quantified-self.io — a next gen training dashboard with MCP access, cross-service activity and route sync
      • freeheelerF Offline
        freeheeler @Fenr1r
        @Fenr1r
        now since I’m trying to reach the miraculous 0.25%/h battery consumption and therefore have switched off everything incl BT by activating flight mode I absolutely understand your sync button request.
        I don’t use an active BT connection at all and rather “waste” battery capacity for 24/7 HR than frequent sync triggered by aproaching watch to phone… I use sync once before an activity for the agps update and once after an activity for uploading.
        when I recall the middle-age when I owned a Fenix 3, I remember that I pressed a button to sync thru wifi at home… (the BT device in the watch was somehow damaged and BT to phone took like half a night to sync)
        living sideways
          freeheeler
          while I’m thinking about a sync button it would be nice to have a shortcut button that opens up a customizable shortcut list.
          one needs quick access to dnd, watch faces and light settings… another one prefers to toggle touch activation, alarm clock and flightmode…
          living sideways
          • Fenr1rF Offline
            Fenr1r
            @Durri deserves credit for suggesting that: I merely paraphrased and seconded. But good to know you’ve seen the (10% back-)light on occasionally maximising battery potential. Good luck with the 0.25%/h goal; is that an officially specified capability?
            As for the shortcuts, customisable “master” modes would be nice: each including a set of configurable button/touch assignments, etc.
            isaziI 1 Reply Last reply Reply Quote 1
            • isaziI Offline
              isazi Moderator @Fenr1r
              @Fenr1r said in S9 Baro Wishlist:
              Sounds slightly over optimistic. Suunto states that the 9 can get to 14 days in time mode (so I guess without HR and sleep tracking, and not connected to SA all the time), and 0.25/hr means over 16 days (almost 17).
              A reasonable number would be close to 0.3/hr.
              Blog: isazi's home
              freeheelerF 1 Reply Last reply Reply Quote 1
                freeheeler @isazi
                @isazi
                I quote @silentvoyager observation
                “S9B consumed 13% of battery in 44 hours, including 35 minutes of GPS activity without HR and 1 hour of gym activity with chest HR while syncing only to MC. That is about 0.23-0.25%/hour or 5.5-6% per day.”
                From my experience Suunto promised the batterylife for A3PS to be 20h with best GPS and HR but overachieved as I tested once with my older used A3P black. Hence there are expectations 🙂
                What worries me a bit is that I don’t use notification whatsoever and no sleeptracking at all and I know for sure that my watch does sync only few times a day. And I don’t even get close to 14 days. When I disable BT the numbers don’t change much…
                I would like to learn what uses battery and how much. I will do some tests regarding this. I will not go crazy about that and will not discuss 3 decimals… but some learnings would be nice, just to know ☺
                living sideways
                J 1 Reply Last reply Reply Quote 0
                • B Offline
                  bbx100 Bronze Member @Guest
                  @silentvoyager said in S9 Baro Wishlist:
                  @TELE-HO Because Garmin is a smartwatch. And Suunto 9 is less “smart watch” than Ambit. It is trying its best to be a fitness tracker though.
                  What’s wrong with smart watch? Suuunto 9 and Spartan line could easily be smart watches. This can only raise up functionalities of the watch and increase selling. I personally wear my spartan baro all day, it tracks my steps and so on while I’m not exercising. Actually I exercise only few hours per week and other 99% I wear watch as a smartwatch? So I don’t see any contradiction between being smart watch and fitness watch. Actually suunto 9 and spartan lines are big enough to be smart watches too…
                  • ? Offline
                    A Former User @bbx100
                    @bbx100 said in S9 Baro Wishlist:
                    A true smartwatch is a watch that can run an arbitrary application that you can load on it. Apple iWatch is a smartwatch. Garmins are to some degree. Modern Suuntos are not, although they might become with SuuntoPlus. Currently they are just fitness watches - their functionality, with exception of notifications, is limited to a very small set of fitness tracking functions.
                    • DurriD Offline
                      Durri
                      What is incomprehensible to me is why I have must to turn off my watch from economy mode when I want to use BT, while turning off flight mode . Wouldn’t it just be enough to turn off flight mode? Why so complicated?
                      I use my watch in economy mode and flight mode on. I work out three times a week and still have an incredible amount of clicks to turn on / off features.
                      • isaziI Offline
                        isazi Moderator @Durri
                        @Durri if you mean power save by economy, that should include turning off all external communication (Bluetooth), so having also flight mode is redundant.
                        Blog: isazi's home
                        DurriD 3 Replies Last reply Reply Quote 0
                        • DurriD Offline
                          Durri @isazi
                          @isazi Yes, but I don’t understand the logic when flight mode is off I can pair devices only when the battery saver mode is off.
                          • DurriD Offline
                            Durri @isazi
                            This post is deleted!
                            • DurriD Offline
                              Durri @isazi
                              @isazi Now I have tested: Battery saving off, flight mode on. Unable to sync! Flight mode must be off. Unnecessarily complicated.
                              isaziI 1 Reply Last reply Reply Quote 0
                              • isaziI Offline
                                @Durri sounds logic to me, how could you connect to external devices in flight mode? Think mathematically as two sets, one including the other. Power saving mode includes airplane mode, while the other direction does not hold, and this is quite logic. The two modes have different use cases, and are both useful. You should simply not select both, as one implies the other. However, the fact that a user can select both at the same time is some kind of UI failure. Best approach would be for power saving to shadow airplane mode, so you can’t select both.
                                Blog: isazi's home
                                DurriD 1 Reply Last reply Reply Quote 4
                                • DurriD Offline
                                  Durri @isazi
                                  @isazi I understand what you are writing, they should fix it.
                                    One thing!
                                    Power saving mode is automatically disabled when you start and activity and that is the big diff here.
                                    With power saving you can keep the watch in a low power state and it will enable all preferences before you go to run meaning connections to sensors etc, while flight mode is flight mode.
                                    Flight mode disables ONLY connections for All time.
                                    Power saving disables more than that including 24/7 HR and so on.
                                    You can put both on top because they can easily overlap the use case scenario.
                                    • B Offline
                                      be1t0n Bronze Member
                                      Main feature that I would like is the ability to lock buttons apart from retaining the ability to activate the backlight or change zoom level on navigation like on the Ambit. Apologies if this is mentioned somewhere above…or if there is a way that I’ve missed.
                                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                                        Dimitrios Kanellopoulos Community Manager @be1t0n
                                        @be1t0n for the zoom thingy its not possible yet.
                                        You can though lock the buttons with lower button hold, and then use the middle button to light up (or any button)
                                        B 1 Reply Last reply Reply Quote 0
                                        • B Offline
                                          be1t0n Bronze Member @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos Doesn’t pressing the middle button just cycle through screens though? Not much help if you’re navigating a track and need to check. On the Ambit you could press the lower right button and the light would activate without the “screen locked” alert popping up. Would just be a nice option to have. I find the "zoom thingy is a bit more of an annoying one as it requires an unlock before you can do anything.
                                            @be1t0n you can do that as well. (press lower button)
                                            You can also hold a little the middle and wont switch screens.
                                            Since the buttons are locked you can also use the upper or lower to light the screen up right?
                                            freeheelerF 1 Reply Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
