    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Elevation issue Suunto 9 baro (MC and Suunto App)
    Scheduled Pinned Locked Moved Suunto app and other software services
    4 Posts 2 Posters 443 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • jacovdboschJ Offline
      jacovdbosch
      fullsizeoutput_344d.jpeg fullsizeoutput_344c.jpeg Hello,
      I have a issue with the elevation measurements registered in MC and the the Suunto app. When I do a run: the elevation should be just fine by the fused altitude option (by default it’s on in sports mode?), but it isn’t. In the example it’s a really flat area. Elevation about +2,0 m. The watch seems to register the wrong elevation and it’s searching to the correct value. But it never comes near the good elevation…! In the summary gives wrong values also/. Total descent: 3 m, highest point + 1,0 m, lowest point -17 m (descent should be 18 m). It doesn’t make sense.
      Does anybody has the same experience? Maybe I make a mistake?
      Jaco van den Bosch
      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
        Dimitrios Kanellopoulos Community Manager @jacovdbosch
        @jacovdbosch no mistakes there.
        First the ascent / descent is calculated with a ±3m filter. That means that if you don’t climb for example 3m in 12minutes you dont get ascent.
        The FusedAlti should have not produced this, that looks more like is affected by pressure change.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        jacovdboschJ 1 Reply Last reply Reply Quote 0
          jacovdbosch @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos thank you for the explanation of the 3 meter filter. But fused Alto should correct the barometric airpresure difference? Or am i wrong?
            @jacovdbosch it should but it can fail. If you are using movescount thay i see try to set the profile to auto
            • First post
              Last post
            Suunto Terms | Privacy Policy
