    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Multi tracks on GPX
    Scheduled Pinned Locked Moved Suunto app and other software services
    15 Posts 7 Posters 2.3k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • AudaxjoeA Offline
      Audaxjoe
      Hi when I plan a GPX I am inclined to break it down into legs on one file. When I load this one file with say 4 legs onto SA then sync with my Suunto 9 it only shows leg A. Am I doing something wrong or do I need to save every individual leg into a separate GPX?
      Suunto Vertical
      Suunto 9 BARO
      Garmin Fenix 3, 5
      Suunto Vector
      remibR 1 Reply Last reply Reply Quote 0
      • sartoricS Offline
        sartoric Moderator
        What do you use to plan the route ?
        SVTS - 2.50.28
        SSSWHR BARO Amber - 2.8.32
        Samsung A5 2016 - Android 7.0
        Suunto App Android 6.10.7 beta
        • AudaxjoeA Offline
          Audaxjoe
          Various, the one I am trying to load now is from QMapshack. I tried to load one the other day from Garmin Basecamp and that behaved the same.
          Suunto Vertical
          Suunto 9 BARO
          Garmin Fenix 3, 5
          Suunto Vector
          • sartoricS Offline
            sartoric Moderator
            I guess multi track is not a “standard” GPX format
            Maybe you should check if there is a way to save a merged version or you can create multiple gpx
            SVTS - 2.50.28
            • AudaxjoeA Offline
              Audaxjoe
              It works perfectly well on a that other brand starting with G! I generally just cut the GPX at controls or major landmarks. I am having the same issue with a friends Wahoo only recognising the 1st leg on a multi track GPX.
              I really don’t want to save a merged version (I can do that easy enough and normally work in reverse from one GPX and cut it) I actually want the GPX cut into legs. I guess I just need to save a route/track as several separate tracks.
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
                Dimitrios Kanellopoulos Community Manager
                I ll report a use case for this. At the moment most providers as you said wahoo only look at the first trkseg I beleive.
                Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
                • AudaxjoeA Offline
                  Audaxjoe
                  Thank you Dimitrios. I’m not sure if most it accurate however, some maybe 😉
                  Suunto Vertical
                  Suunto 9 BARO
                  Garmin Fenix 3, 5
                  Suunto Vector
                  • AudaxjoeA Offline
                    Audaxjoe
                    Should add I have to do this with units like the Garmin 1000 if they are long or it crashes or freezes on anything over around a 100 miles…
                    Suunto Vertical
                    Suunto 9 BARO
                    Garmin Fenix 3, 5
                    Suunto Vector
                    • Brad_OlwinB Online
                      Brad_Olwin Moderator @Audaxjoe
                      @Audaxjoe said in Multi tracks on GPX:
                      I load 100 miles or longer into my S9 and did with Ambit as well as SSU. No issues! Works great!
                      Vector/T6c/Vertical 2 Ti
                      • AudaxjoeA Offline
                        Audaxjoe
                        Indeed. I just don’t like looking down and the unit says distance to end is a long way away. Much easier broken into chunks. Just personal preference I guess. Also it is good if say a control is ahead as you know when it is coming. I guess you could also use waypoints for this.
                        Suunto Vertical
                        Suunto 9 BARO
                        Garmin Fenix 3, 5
                        Suunto Vector
                        • ? Offline
                          A Former User @Audaxjoe
                          @Audaxjoe I used waypoints in a similar situation when doing a 50 mile race recently. It worked fine and I was getting distance to each next aid station and ETE (estimated time to get there). Although a route with waypoints can be edited only in Movescount.
                          • Tim4cT Offline
                            Tim4c Silver Members
                            @Audaxjoe How did you save the GPX file? Have you tried right click and “Save as GPX 1.1 w/o ext…” ? Maybe it can solve this issue. i haven’t give a try for now…
                            Suunto Spartan WHRB, iPhone XR, Suunto App beta, almost always on the last update.
                            AudaxjoeA 1 Reply Last reply Reply Quote 0
                            • Tim4cT Offline
                              @Audaxjoe You can also merge multiple segments in a single track.
                              “ctrl or cmd + click” on each segment you want to combine, then right click and “Combine tracks”.
                              • remibR Offline
                                remib @Audaxjoe
                                I guess you’re not doing anything wrong since It happens the same for me with an Ambit3 peak. I guess at the moment, Suunto is not able to deal with those GPX files which, by the way, are standard.
                                For the reckon, a standard GPX file can hold all in one file multiple tracks (with many legs), routes, and waypoints.
                                It might have been some simplified deal since gps watches are small but I plus the fact it should be managed in an other way.
                                • AudaxjoeA Offline
                                  Audaxjoe @Tim4c
                                  @Tim4c yes it isn’t an issue, it would just be easier to save one file with multiple legs then have each leg as a file in its own right.
                                  @remib I know, all GPS I have had for the last 20 years have coped with legs. I noticed the Wahoo of a friends doesn’t. It isn’t a problem but even loading the track to SA needs to be done x amounts of times instead of once.
                                  Suunto Vertical
                                  Suunto 9 BARO
                                  Garmin Fenix 3, 5
                                  Suunto Vector
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
