    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Altitude issue on Suunto9 Baro.
    8 Posts 3 Posters 920 Views 4 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • valdis830V Offline
      valdis830
      Hi guys, lately I observe anomalies in altimeter measurments after activities. Is this a known issue in Suunto9 Baro (FW v_2.5.18.)? It works perfectly all time except after activities. Altimeter doesn´t recognize altitude changes.
        Dimitrios Kanellopoulos Community Manager
        No issue from 3 S9’s here.
        Question:
        How do you see that the altimeter does not change? For example how much should it change?
        Also what happens if you eg drive to work etc.
        Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
        valdis830V 1 Reply Last reply Reply Quote 0
          valdis830 @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos Works like a charm rest of time. It´s only after activity. Difference between two points is 50m and descent -5m.
          It does not mark it when i go down, but when I go back to the previous point it adds 5 m to the previous known altitude. 173 - 5 (doesn´t go down) then 173 + 5 (yes it goes up) = 183 at the same point where I was 3 minutes ago. Stange!
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            Dimitrios Kanellopoulos Community Manager @valdis830
            @valdis830 Interesting. Maybe 5m is not the correct threshold?
            What would happen after you stop if you go down more than 5m ?
            Did this happen also before the update or with the SSU ?
              @Dimitrios-Kanellopoulos said in Altitude issue on Suunto9 Baro.:
              Threshold is correct. It works very well after, but already with this altitude error.
              I not tried to decend more, I will try it next time.
              I remember that the day I left to train with 2 watches in SSU did not happen this. It goes down -5m correctly
                @valdis830 Thanks please check if it’s some threshold or so and I can perhaps try to create a case about this .
                  Thanks to you too, I will post you☺
                  • Brad_OlwinB Offline
                    Brad_Olwin Moderator
                    Mine will frequently have a different altitude for home prior to and following an activity. This is almost always due to pressure changes and will correct with the next activity. I suggest you do an altitude calibration on the watch, this can be done from the Nav menu. I do not think that this is necessarily a bug.
                    Unless after reading your post, is this during an activity?
                    Vector/T6c/Vertical 2 Ti
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
