    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto Race 2 – Display stays on during activity + excessive battery drain
    Scheduled Pinned Locked Moved Suunto Race 2
    9 Posts 6 Posters 176 Views 6 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      stefanstraeter
      Hi everyone,
      I’m a trail runner and I’m having an issue with the display on my Suunto Race 2. During an activity, I have the following display settings:
      Brightness: Low
      Always-on display: Off
      Raise to wake: Off
      However, the display does not turn off during the activity. It stays on continuously.
      I usually have navigation running in the background because I’m following a route, but I’m not on the map screen. I’m on the standard data screen.
      Could the navigation be causing the display to stay on, even though Always-on Display is disabled? I’ve already tried resetting the watch, but the problem still occurs.
      I’m currently running the latest software version, 2.56.18.
      I’m also using an external heart rate sensor, so the watch is not using wrist-based heart rate measurement during my activities.
      I’m also concerned about the battery life. A while ago, I started a long trail run on the Karwendel Höhenweg in Austria with 79% battery. After around 9 hours on the trails, the watch was completely dead.
      That seems way too much battery consumption for the Race 2. I would expect significantly more than 9 hours of recording time, especially with the display set to Always-on Off.
      Has anyone else experienced the same issue with the display staying on when navigation is active? And is this kind of battery drain normal for the Race 2, or could there be a software/firmware issue?
      Thanks!
      L G 2 Replies Last reply Reply Quote 0
      • L Offline
        larrybbaker @stefanstraeter
        @stefanstraeter with Raise to Wake = OFF wouldn’t that keep the screen on continuously?
        I have Race 2 and do not see this issue.
        Vertical Ti Solar
        Vertical 2
        Race 2
        iPhone 17 Pro
        SquirrelS 1 Reply Last reply Reply Quote 1
        • SquirrelS Offline
          Squirrel Silver Members @larrybbaker
          It shouldn’t. Display would only turn on with button press, ignoring the gesture.
          Race S
          • G Offline
            Gunnar Bronze Member @stefanstraeter
            @stefanstraeter please check your display settings in the trainings options. They can be different to the general settings.
            1 Reply Last reply Reply Quote 4
            • S Offline
              stefanstraeter
              @Gunnar
              Hi Gunnar,
              both display settings (general & training options) are:
              Brightness: Low
              Raise to wake: Off
              So weird how my Suunto acts.
              • S Offline
                stefanstraeter @Squirrel
                @Squirrel
                Yes, I turned “Raise to Wake” to OFF. The Display didn’t turn off.
                J 1 Reply Last reply Reply Quote 0
                • J Offline
                  johann.fuehrer Bronze Member @stefanstraeter
                  @stefanstraeter You need to turn raise to wake “ON”, then the display turns off and “wakes when raised”. That’s the meaning of this option.
                  • EgikaE Offline
                    Egika Platinum Member @johann.fuehrer
                    @johann.fuehrer erm. Yes, with raise to wake = on, it will turn on with raising your watch.
                    I understood the TO wanted the display to be fully off until he presses a button.
                    So AOD=off and RTW=off are the correct settings for this.
                    My watch goes dimmed after 5s and switches the screen off after a few more seconds.
                    Regardless of any navigation settings.
                    @stefanstraeter: please try a soft reset and then again - it should work as you want it
                    J 1 Reply Last reply Reply Quote 1
                    • J Offline
                      johann.fuehrer Bronze Member @Egika
                      @Egika ah - I understand, my misunderstanding as I use it a bit different. For me raise to wake on configuration uses 6-7% battery a day (Vertical 2). This was the best I could get (OX measurement off, 24h HR on). That gives me without training about two weeks. Then after each charging I need to do the soft reset, otherwise battery-drain is awful.
                      Register Login
                      • First post
                        Last post
                      Suunto Terms | Privacy Policy
