A few intermittent tank pressure dropouts
My Tank POD is only 6 months old. During my last two dives (water around 13°C,
maximum depth 18 meters), I experienced a few intermittent tank pressure dropouts. Before these last two dives, the device was working perfectly.Software version: 2.49.32
Original Suunto Tank POD
Tank POD icon remained visible
No low battery warning
Pressure indication occasionally disappeared and then came backHas anyone experienced similar behavior?
Thank you very much for your help.
@Nabil , I’m not sure about your issue but this seems exactly the same what I was seeing in one of my dives, Suunto confirmed an update is required to solve this. But to be sure, report this to support@suunto.com. Then, please read the “Mandatory Gas Time Alarm at beginning of the dive” thread carefully, I had the same on a dive where Tank Pressure was - - <null>.
If you download the json file of your dive you can analyze as described. Read:
https://forum.suunto.com/post/194823,
https://forum.suunto.com/post/194868,
https://forum.suunto.com/post/194881, https://forum.suunto.com/post/194890.
Register Login
