    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Losing faith on the S9 (treadmill & HR) latest firmware
    44 Posts 12 Posters 7.3k Views 13 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • SlaShS Offline
      SlaSh Platinum Member @Guest
      @Marcel-Baliño ohrm or belt?
      • D Offline
        Darren_M Bronze Member @nassosc
        @nassosc I can’t vouch for the treadmill distance issue you have, because I don’t use them unless injured. However, I will say that the one time I did use the watch on the treadmill it was surprisingly accurate. Interesting one from @SlaSh on the watch resetting the calibrated data after update, I never knew that.
        More importantly for me, as it doesn’t appear to be getting much air time, is the HR issue. I contacted Suunto over this issue, blaming the update, because the HR is consistently poor since then. I have seen it once or twice before, it’s every run since I updated.
        After I made first contact with Suunto support, I was asked to link moves from Movescount into the email reply so that they could be checked by the technical guys. I replied with the links from Movescount and within 24 hours a different support agent replied telling me to update to the latest firmware. I’d already explained that I had the latest fw in the original email. Therefore, I was simply receiving the big FINGER, like go away, we’re not interested! Therefore, it was time to get shirty - ending with “I’ll just get a refund then, it’s under warranty!” This provoked a 5 minute response time, with the suggestion that it was being escalated to a more technical level. Do I believe it? No! I know some on here think Suunto are a great company. However, if they go down the same route as Garmin support used to, which they just tried to do, then their name will become mud every time they come up in conversation.
        All I ask is that they look into it, acknowledge that it isn’t right and tell me if they can correct it or not! What I don’t want the have to do is repeat myself over and over again to different support agents!
        nassoscN 1 Reply Last reply Reply Quote 0
        • nassoscN Offline
          nassosc @Darren_M
          @Darren_M well today I did another treadmill run with 1km difference in a 12k run. which I believe is unacceptable. I have the same issue with the OHR but it doesnt bother me so much since I use my belt.
          I have emailed support and they also asked for my movescount link. I did send it and now waiting. I have also asked for a replacement watch but it was ignored.
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
            Dimitrios Kanellopoulos Community Manager @nassosc
            @nassosc I am sorry to say but if you expect a wrist based device to give you the same results from a threadmill then I would suggest to sell the watch and get somtbing else or a brand that let’s you calibrate via treadmill etc.
            Suunto devices calibrate via GPS and are mainly used for outdoor distance.
            The treadmill already shows you the distance and pace why bother?
            As another example, another user can complain about the rowing distance not being correct.
            That said I do know that even expensive pods don’t match all threadmills.
            To blame the device that is not build for this purpose I am sorry but come on.
            Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
            • nassoscN Offline
              nassosc
              @Dimitrios-Kanellopoulos i use the treadmill distance meter when i run on the treadmill. the whole issue came to my attention after an update. till then the watch and the treadmill were almost the same. So when the difference was more thatn “normal” (what is normal?) I made the post. I would prefer it if it was similar to the watch for logging the runs correctly. no other reason.
              The GPS works wonderfully (and all out door features) and that is why I use this watch and have been choosing Suunto watches for years, running and diving. I love my S9 and dont want to change it to garmin, to apple or anything else. Only suunto 10 🙂
              Im aware there can be issues especially when buying anything tech related on the first day it is released and I can leave with it.
              My opinion is though that if the feature is supported it should work, or at least be consistent.
              I also mentioned it here not to complain but maybe find a solution to this problem, a workaround or a more technical solution.
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
                @nassosc tha case is that afaik we did not change anything to the calibration of the accelerometer, just that it resets that factor eventually. I do understand that it’s not convenient for this to happen, once it works good, but atm we cannot do anything as this factor should come from a GPS distance.
                I can open a request to let the user set a distance calibration such as the S3 does but what I understand treadmills are not good to get a watch/pod/etc to be calibrated with. I ll take this further.
                nassoscN D 2 Replies Last reply Reply Quote 1
                • nassoscN Offline
                  nassosc @Dimitrios Kanellopoulos
                  @Dimitrios-Kanellopoulos i dont want to mess up other things for a treadmill calibration issue. As mentioned this is an outdoor watch that works perfectly fine in that field. Not familiar with how the S3 works.
                  I’m not a fan of treadmills and dont trust them much. The reason for trusting theses ones more than the S9 is that my coach insists that they are calibrated.
                  I think this issue has been exhausted and can now be closed.
                  • D Offline
                    Darren_M Bronze Member @Dimitrios Kanellopoulos
                    @Dimitrios-Kanellopoulos It would be nice to see some kind of calibration field that one could set to line the rowing machine up with the watch in a similar way. I always do a km warm up in the gym according to the machine, but consistently get 0.20 km from the watch. I’m not sure how much work that is, but it sounds to me like a relatively simple field where one can input a multiplication factor. Although this would be nice, it’s not something that bugs me, as my indoor rowing is just a warm up, yet I guess someone who treats that activity more seriously might appreciate it.
                    Again, Suunto watches are outdoor kit mostly. However, imagine how much extra interest they could receive if the data produces from indoor activities was accurate? I reckon they’re missing a trick here!
                    • ? Offline
                      A Former User
                      It would be great if Suunto added ability to manually calibrate the watch - just let me enter the actual distance at the end of the run. I know at least some Garmins allow that. My S9 always measures about 20% long on treadmills. The problem is that most of my runs outside are quite different than treadmills runs, so the automatic calibration simply doesn’t work. My runs outside are either with my dog which affects the wrist movement or trail runs with a lot of elevation changes, which means my cadence tends to be slower outside. My treadmill runs tend to be on the faster side and with higher cadence, so that is probably the reason the watch overestimates the distance and the pace.
                        Dimitrios Kanellopoulos Community Manager @Guest
                        @silentvoyager And S3’s do that 😉
                        • SlaShS Offline
                          If you about the correct values for treadmill I would use foot pod for that and all your suffering is ended 😉 none of whatches gave me exact values and none of treadmill in casual gym is calibrated, so foot pod is the best solution for you all 😉
                          S ? 2 Replies Last reply Reply Quote 2
                          • S Offline
                            Shrek3k @SlaSh
                            For me the SSSWHR does a decent job on a treadmill, not perfect, but decent as in sufficient for me and my use.
                            But I am disappointed while using it on a crosstrainer. I do not expect perfection at all, but I really wonder why the results show for today: 60:00 min of use, distance 2,55 km, with 9446 steps, or a few days ago 45:00 min of use, 2,06 km, 6947 steps. So it seems, that the number of steps has been registered correctly… but at the same time the algorithm seems to count every stride with only a “few centimeters” . So: cadence sensor seems to be good, the algorithm not.
                            And no - of course most of these values can only be seen on the watch, and not in the incredibly “not too good” SA-app.
                            And yes - I would vastly prefer to run outdoors, but have to be patient and suffer indoors due to my marvelous Achilles tendon 😕
                            using a Suunto Vertical & Suunto Wings; mostly running (AKA stomping around) and cycling through the northern german "wilderness", and wherever else I have the chance to do so
                            OS - Android 16/Pixel Pro 7
                            • ? Offline
                              A Former User @SlaSh
                              @SlaSh oHRM
                              • nassoscN Offline
                                nassosc
                                @Shrek3k I think the treadmill is no ones weapon of choice. 🙂
                                S 1 Reply Last reply Reply Quote 0
                                • S Offline
                                  Shrek3k @nassosc
                                  @nassosc said in Losing faith on the S9 (treadmill & HR) latest firmware:
                                  🙂👍🏻… so true
                                  • ? Offline
                                    A Former User @Shrek3k
                                    My treadmill run today was spot on. Run on the treadmill every blue moon though. I think it is calibrated enough from outdoor runs.
                                    • ? Offline
                                      @SlaSh I don’t care that much about accuracy on tradmills to buy a footpod. I run on a treadmill only 1-2 miles per week as a warm-up in a gym as opposed to 30-40 miles per week outside. But it would be nice for the error to be less than 20-30%. Just let me calibrate it myself as opposed to automatic calibration.
                                      • nassoscN Offline
                                        nassosc
                                        I thought not to start a new thread but yesterday from my 18k outdoor run I have all sorts of different values.
                                        Watch and app show avg bmp 146 and movescount 137. you can see the difference in the graphs. Also the first minutes are completely wrong with max heart rate. I did push towards the end so the app graph is closer to the truth although it certainly did not feel anywhere near 180+ (especially at that pace)
                                        Also my pace on the watch was 4:56 whereas on strata 4:53.
                                        I used the heart rate belt.
                                        • Brad_OlwinB Offline
                                          Brad_Olwin Moderator @nassosc
                                          @nassosc For the Strava issue, Strava filters data, removes all data where Strava thinks you are not moving so speeds will not match.
                                          For the HR, if you filter out the high reading at start with MC, do they match well? Avg HR? This is common when the belt is not getting good contact at the beginning or the belt is old or dirty.
                                          I do not know why the spike at the start did not show up in SA. How did you sync to both? MC first then SA?
                                          Vector/T6c/Vertical 2 Ti
                                          • nassoscN Offline
                                            nassosc @Brad_Olwin
                                            @Brad_Olwin
                                            the belt is new and clean. First I synced the SA and then MC.
                                            Václav KrálV Brad_OlwinB 2 Replies Last reply Reply Quote 0
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
