    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto race problème de batterie
    Scheduled Pinned Locked Moved Suunto Race
    15 Posts 9 Posters 1.0k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Pierre MatelskiP Offline
      Pierre Matelski
      Bonjour,
      Ma batterie se vide très rapidement à partir du moment ou elle atteint 30%.
      Je n’ai rien changé à ma config.
      Est-ce un problème de batterie ou de logiciel?
      Merci d’avance
      G Marcelo MönchM R 3 Replies Last reply Reply Quote 0
      • G Offline
        Geoffwilli @Pierre Matelski
        @Pierre-Matelski
        I have the exact same problem. Within 30minutes my battery can go from 35% to 10%.
        I’ve also had issues with battery drain for 6+months, and it feels like the battery is draining as quickly in standby mode as it does in a full GPS activity. It now needs charging every 2/3 days.
        Steven LimmerS 1 Reply Last reply Reply Quote 0
        • Marcelo MönchM Offline
          Marcelo Mönch @Pierre Matelski
          @Pierre-Matelski If you want the battery to last as long as possible during everyday use (outside of workouts), make these adjustments in the Settings menu:
          • Display > Always-on: Turn this option off. Let the screen wake only when you look at the watch.
          • Display > Brightness: Set it to Auto or reduce it to Low.
          • Connectivity > Media Controls: Turn this off if you don’t usually control music playing on your iPhone from the watch, as it keeps Bluetooth active and uses more battery.
          • Backlight with Button Press: Turn this feature on so the backlight only comes on when you press a button, preventing the display from lighting up by itself at night while you’re in bed.
          • R Offline
            Rinbo71 @Pierre Matelski
            @Pierre-Matelski
            Même chose pour moi. Il y a 6 mois, ma batterie tenait plus de 2 semaines avec environ 5-6h d’activité gps. J’avais déjà optimisé pas mal de truc pour qu’elle tienne le plus possible (pas de FC H24, pas de raise to wake, pas de suivi de sommeil).
            Désormais je suis à moins de 2 semaines et je passe de 30 à 10% en 2 jours. Ça reste convenable car j’ai tout optimisé, mais si j’utilisais toutes les fonctionnalités, je serais à moins d’une semaine.
            Je me demande aussi si ça ne vient pas de la grosse MAJ qu’il y a eu après la sortie de la Race 2.
            • Steven LimmerS Offline
              Steven Limmer @Geoffwilli
              @Geoffwilli I can also confirm I have this issue. Charged my watch fully on Saturday, went for a long bike ride (3.5 hours). Battery was at 50% after (which was unusually low). I’ve woken up this morning and the battery is at 20%
              Equipment: Suunto Race Titanium
              SA: Android (Beta)
              J 1 Reply Last reply Reply Quote 0
              • J Away
                johann.fuehrer Bronze Member @Steven Limmer
                @Steven-Limmer Charge until full and then do a Soft Reset. For me this solves this. Needs to be done after each charging … I hope it’s fixed in the next FW update
                Steven LimmerS E 2 Replies Last reply Reply Quote 1
                • B Offline
                  brettacher
                  Same here. Since installing v. 2.53.42, I have a much shorter battery life than before, especially when the battery SoC is below 40%. You can then watch the battery deplete at about 1% per hour. Even with only sporadic usage in activities, I’m down to 4 days max. until I need to recharge. Before v. 2.53.42, I got more than a week of battery life easily. Looks like a bug in the firmware to me.
                    Steven Limmer @johann.fuehrer
                    @johann.fuehrer I’ve done this twice. It seems to slow the drain down, but it’s still bad. I’m getting about 2 days max
                    SA: Android (Beta)
                    • J Away
                      @Steven-Limmer That’s strange … 😞 can you check in connections if Wireless Network is turned of, this is a huge battery burner. Do you have “Always On Display” enabled. I have also lowest brightness level (which is still to bright for me, even on daylight).
                      • E Online
                        elbee @johann.fuehrer
                        Did you report the problem at suunto support? Without knowing Suunto isn’t fixing anything in some future firmware (that is, if there will be a new firmware for the race).
                        I reposted a nightly battery drain once for my race s. Most of the time, with my ussage, I get 3 to 5 days max out of oled watches. (Oled is a lousy technique for hardcore sportwatches. My last mips watch lasted initially 2 weeks with about the same usage).
                        Have to say, I didn’t do any follow up on the battery issue. I have a bigger issue with Bluetooth that I want Suunto to fix. If there will be a new firmware update for my race s, that is.
                        Suunto t3c | Suunto Ambit 3 sport | Tomtom runner 2 | Garmin forerunner 935 | Garmin forerunner 965 | Suunto race s
                        Stryd | Bryton Gardia R300L | Polar H9 | Polar oh1+ | Wahoo bolt v2 | 4iiii precision 3
                        • J Away
                          johann.fuehrer Bronze Member @elbee
                          @elbee I did right now, but as I have seen that this topic is around for some years on different watches and also on the V2 I assumed this was already reported.(never assume someone did it, just do it by yourself - I forgot about this all overall known wisdom). So let’s see…
                            @johann.fuehrer just checked, wireless was on - I had it turned on to download maps a few weeks back and forgot to turn it off. I’ll see how this goes
                            SA: Android (Beta)
                            E 1 Reply Last reply Reply Quote 0
                            • E Online
                              elbee @Steven Limmer
                              @Steven-Limmer
                              As far as I know and understand correctly, wifi isn’t always on when that option is enabled. It is only turned on for firmware updates and map downloads. It’s not even used to sync workouts (garmins do use wifi for workout syncs. Quite convenient because you don’t have to have the app running in the background)
                              So I doubt that disabling that option will make an impact. But it’s good to check, there might be a bug that causes wifi to be turned on u necessarily without the user noticing.
                              SquirrelS 1 Reply Last reply Reply Quote 0
                              • SquirrelS Offline
                                Squirrel Silver Members @elbee
                                From what I observed, the firmware is downloaded over Bluetooth.
                                WiFi is used for map downloads and also overnight for GNSS file downloads.
                                So having “Wireless network” disabled, will prevent WiFi wake up at night looking for network. Although I don’t know the scheduling.
                                Race S
                                • E Online
                                  elbee @Squirrel
                                  @Squirrel
                                  I can only tell what I observe. The gnss data is synced right when your watch is connected to the suunto app on the phone. At least, at some point the sync process is saying it is syncing gps data.
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
