    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto race 2 e Suunto spark
    Scheduled Pinned Locked Moved Suunto Race 2
    4 Posts 3 Posters 261 Views 2 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • massimo trinchieriM Offline
      massimo trinchieri
      Ciao, ho un problema di connessione tra il Suunto race 2 e le cuffie Suunto spark, le cuffie non registrano all’interno dell’attività corsa i dati di cadenza, oscillazione verticale etc.
      Ho un iphone e volevo chiedere a qualcuno che ha la stessa configurazione i passaggi da eseguire per una connessione tra i due.
      Grazie a chi vuole rispondere.
      Kraisun TuntaK 1 Reply Last reply Reply Quote 0
      • Kraisun TuntaK Offline
        Kraisun Tunta @massimo trinchieri
        @massimo-trinchieri
        Hi, As far as I know, when using Suunto Spark together with the Suunto Race 2, the running dynamics data (cadence, vertical oscillation, ground contact time, etc.) are not recorded in the workout summary if the activity is started directly from the watch.
        If you want to collect and view the running dynamics data from the Suunto Spark, you may need to start the activity from the Suunto mobile app instead of the Race 2.
        It seems to be a current limitation of the integration rather than a connection issue.
        In the meantime, just enjoy the music! The 3D audio effect is really impressive and the sound quality is excellent.
        Hopefully Suunto will improve the running dynamics integration in a future firmware update.
        Suunto Journey:
        9 Baro → 9 Peak Pro → Vertical Solar → Race → Race 2 → Run → Vertical 2+Suunto spark
        2 1 Reply Last reply Reply Quote 0
        • 2 Offline
          2b2bff Silver Members @Kraisun Tunta
          Isn’t the watch not able to record those itself? I thought it has been added with an update last year…
          Race S
            Kraisun Tunta @2b2bff
            @2b2bff
            I think there may be some confusion between the standard running dynamics already available on the watch and the additional metrics provided by the Suunto Spark.
            The Race series can already record metrics such as cadence and some running dynamics. However, one of the new metrics provided by the Suunto Spark is Ground Contact Time Balance (left/right balance), which shows how evenly you load your left and right foot while running.
            As far as I know, this specific metric is currently only supported within the Suunto ecosystem when using the Suunto Run. I have not seen it being recorded or displayed in the activity summary on the Race 2 yet.
            So if Ground Contact Time Balance is the data you’re looking for, that may be the reason it is missing rather than a connection problem between the Race 2 and the Spark.
            Suunto Journey:
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
