    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Charging base
    Scheduled Pinned Locked Moved Suunto Race S
    7 Posts 7 Posters 431 Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      sindavide
      I find the Suunto Race S’s magnetic charging base really bad. I need to position it more and more times before it starts charging. Sometimes it interrupts charging even though at first contact the lightning icon appears.
      Anyone with this bad experience?
      V SquirrelS G LazyjonesL JebClydeNCJ 5 Replies Last reply Reply Quote 2
      • V Offline
        vinc14 Bronze Member @sindavide
        @sindavide
        yes me too!!!
        • Suunto Vertical 1, Steel solar All Black and Made in Finnland
        • Suunto Smart Heart Rate Belt
        • Suunto Zoop
        Android APP: 4.100.4
        Linux (Debian) Laptop (No Windows)
        • SquirrelS Offline
          Squirrel Silver Members @sindavide
          @sindavide Yes, the magnets are not strong enough for the base to just perfectly snap in place. But you can put the charging base on a flat surface, then place the watch on top. It is easier to align the crown/middle button with base cable, although it will charge the other way around as well.
          You can also monitor the charging progress in the Suunto app, especially if you don’t charge to 100%.
          Race S
          • G Offline
            grego @sindavide
            @sindavide I have the same bad experinence as you.
            • LazyjonesL Offline
              Lazyjones Bronze Member @sindavide
              @sindavide Yes it sucks. I’ve bought cheap backup and it works better than original one. Stronger magnets.
              Stefano M64S 1 Reply Last reply Reply Quote 0
              • JebClydeNCJ Offline
                JebClydeNC @sindavide
                @sindavide I’ve had somewhat similar problems at times (intermittent charging, or worse, intermittent data connection with computer, with my Suunto Run). One big solution has been to clean the watch contacts, as oils from skin can buildup on the metal, making for a poor connection quality to the cable. Cleaning is as simple as a quick scrub of the contacts with a damp (warm water) cotton swab and drying THOROUGHLY before connecting to power. Using hand soap in that process helps every so often too. Definitely been a better experience since I started doing that…
                • Stefano M64S Offline
                  Stefano M64 Silver Members @Lazyjones
                  @Lazyjones said in Charging base:
                  I read in this forum that the magnet of the original chargers is intentionally weak to not damage the watches
                  Suunto Vector . Vector HR . Core . Race & Race S
                  1 Reply Last reply Reply Quote 4
                  Register Login
                  • First post
                    Last post
                  Suunto Terms | Privacy Policy
