    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HR broadcast to Wahoo not working?
    Scheduled Pinned Locked Moved Suunto Vertical 2
    25 Posts 11 Posters 2.3k Views 11 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      gkaempfer Bronze Member
      I have a Vertical 2 with the latest update that includes HR Broadcast. I connected it to my Wahoo Elemnt Bolt v2. It gets correctly identified as an HR sensor by the Wahoo. However, BPM readings never appear on the device (remains N/A). Has anyone successfully connected to a Wahoo device? I tried this with the default Mountain Bike activity (no customization on the V2)
      R Mads Hintz-MadsenM S 3 Replies Last reply Reply Quote 1
      • UjcoCZU Offline
        UjcoCZ
        I think the HR transmission feature doesn’t work the same way here as it does on Garmin. On Garmin, you just select “Transmit HR” in the menu, and the activity is recorded on an external device; the watch functions solely as a heart rate sensor. With Suunto, HR transmission is linked to activity tracking, so its usefulness will be fairly limited—perhaps for a treadmill?
        Vertical 2 Ti
        Hammerhead Karoo 3
        4iiii Precision 3+
        Elementum Terra N
        G 1 Reply Last reply Reply Quote 0
        • G Offline
          gkaempfer Bronze Member @UjcoCZ
          @UjcoCZ I’m talking about broadcast during an activity. Nothing got registered on my Wahoo when both the V2 and the Wahoo were in activity.
          UjcoCZU AudaxjoeA 2 Replies Last reply Reply Quote 0
          • UjcoCZU Offline
            UjcoCZ @gkaempfer
            @gkaempfer I see. Why are you recording the same activity on two devices at the same time? Does Wahoo not send all metrics to the Suunto app, just like my Hammerhead?
            Vertical 2 Ti
            Hammerhead Karoo 3
            4iiii Precision 3+
            Elementum Terra N
            • R Offline
              runyx17 @gkaempfer
              @gkaempfer I confirm, same problem for me. Vertical 2 and Bolt 2.
              Suunto: Ambit 3, Spartan, Vertical 2
              Garmin: FR 405, 935, 970 , Fenix 3, 6X, Epix2 Pro
              • AudaxjoeA Offline
                Audaxjoe @gkaempfer
                @gkaempfer I just checked this on a Wahoo Ace. The Wahoo recognised the broadcast but when I started the activity it showed no HR.
                Suunto Vertical
                Suunto 9 BARO
                Garmin Fenix 3, 5
                Suunto Vector
                • G Offline
                  @UjcoCZ I record on both devices. During biking, I navigate with the Wahoo (can’t use the V2 because the screen turns off). I would like to see my HR on the screen in front of me. Eventually I normally upload to Strava and delete the Wahoo recording. I don’t think I can send the Wahoo recording directly to Suunto and I probably won’t because it’s a backup in case something goes wrong with Suunto (never happened to me).
                  • Mads Hintz-MadsenM Offline
                    Mads Hintz-Madsen Silver Members @gkaempfer
                    @gkaempfer Not working for me either with Roam v3. It pairs fine but HR is never shown on the Wahoo device. We need a fix, Suunto!
                    G 1 Reply Last reply Reply Quote 2
                    • G Offline
                      gkaempfer Bronze Member @Mads Hintz-Madsen
                      Apparently works with Garmin 1050 (see https://forum.suunto.com/post/189434). All the above Wahoo devices support ANT+ so that isn’t the issue. There is some other compatibility issue.
                      UjcoCZU Mff73M 2 Replies Last reply Reply Quote 0
                      • UjcoCZU Offline
                        UjcoCZ @gkaempfer
                        @gkaempfer Suunto transmits via Bluetooth, not ANT+. There’s no issue with the Hammerhead, just FYI. I still don’t understand why you wouldn’t just use a heart rate strap and log everything on Wahoo, then transfer it to the Suunto app if needed. Yes, there’s still an issue with power zones and heart rate zones—specifically, their graphical display. But the data is transferred.
                        Vertical 2 Ti
                        Hammerhead Karoo 3
                        4iiii Precision 3+
                        Elementum Terra N
                        G AudaxjoeA 2 Replies Last reply Reply Quote 1
                        • HonzaSH Offline
                          HonzaS
                          Vertical 2 shouldn’t have ANT+. My Roam2 shows and connect it as ANT+ and doesn’t show any HR.
                          On phone, it’s visible in BT devices but OnelapFit doesn’t see anything.
                          Suunto Vertical 2
                          • Mff73M Offline
                            Mff73 @gkaempfer
                            @gkaempfer
                            The HR broadcast is using Bluetooth and not AnT+.
                            Normal that you didn’t see data if you try to use that Ant+protocol.
                            SSU (retired), SV1, SV2
                            Wife : S9PP
                            SA: Always the latest beta :)
                            Android + Galaxy S205G
                            • G Offline
                              @UjcoCZ It’s really simple: I want to see my HR during my exercise on a screen I can read without hazard during a mountain bike ride (e.g. on a single track). I don’t want to lift my arm from the handlebar for that. The integration of app isn’t that important. I’m fine with the Suunto app and it uploading to Strava.
                              • G Offline
                                gkaempfer Bronze Member @Mff73
                                @Mff73 I guess that something misleads Wahoo to wrongly detect the Suunto signal as ANT+. My guess is that both Suunto and Wahoo could technically fix this. I would also guess that it’s a bug on the Suunto side given Wahoo works fine with other watches and HR sensors.
                                • AudaxjoeA Offline
                                  Audaxjoe @UjcoCZ
                                  @UjcoCZ I also record on both. I like backup of having the two devices recording and also have waypoints for say a cafe on the V2.
                                  Wahoo does not natively upload to SA.
                                  I did consider the Hammerhead but for the type of riding I do the battery isn’t good enough. And I’m on my third generation of Wahoo computers and they have all been excellent.
                                  Suunto Vertical
                                  Suunto 9 BARO
                                  Garmin Fenix 3, 5
                                  Suunto Vector
                                  UjcoCZU 1 Reply Last reply Reply Quote 1
                                  • UjcoCZU Offline
                                    UjcoCZ @Audaxjoe
                                    @Audaxjoe I understand both of you, though I prefer simplicity—having two parallel recordings isn’t exactly that.
                                    I get your love for Wahoo; I’d probably set waypoints on it and then use the RunGap app to transfer the data. It can even do it automatically.
                                    He rides single tracks, where the heart rate reading from the watch is just as bad due to vibrations, so he uses a heart rate strap. He doesn’t primarily want dual tracking to have proof for his wife of where he was :).
                                    He’s looking for a solution that doesn’t make much sense.
                                    Vertical 2 Ti
                                    Hammerhead Karoo 3
                                    4iiii Precision 3+
                                    Elementum Terra N
                                    AudaxjoeA G ravenR 3 Replies Last reply Reply Quote 0
                                    • AudaxjoeA Offline
                                      Audaxjoe @UjcoCZ
                                      @UjcoCZ luckily we are all different. I am totally happy with my setup and it good to hear you like yours 😂
                                      Suunto Vertical
                                      Suunto 9 BARO
                                      Garmin Fenix 3, 5
                                      Suunto Vector
                                      • G Offline
                                        @UjcoCZ 1. Your comment is irrelevant. HR broadcast to a bike computer makes sense. Wahoo has popular bike computers. Suunto should work with them.
                                        2. I don’t use a HR strap. My V2 works fine for me since the latest updates and HR is very reliable even when doing some rough biking.
                                        • ravenR Offline
                                          raven Bronze Member @UjcoCZ
                                          @UjcoCZ said in HR broadcast to Wahoo not working?:
                                          Two parallel recordings can have the following benefits:
                                          1. One can be a backup of the other. In the event something weird happens (device OS crash, etc.) then you have a pristine copy. While likely not worth going out and buying a second device just for this purpose, why not use it if you have it?
                                          2. Confirmation of various metrics. For example, those who wear two GPS watches on a running session can check the overall distance and paths each watch created. One will see this in testing with people like DCRainmaker, but again, people who happen to have two devices can compare accuracy.
                                          3. Some devices prefer having sessions recorded with their own devices. For example, Garmin can handle a session differently if it was imported into Garmin Connect versus recorded natively on one of its devices. Imported sessions “wouldn’t count” for some of their summary metrics. Over at Apple, sessions can show “Active Calories” versus “Total Calories” with the latter including BMR (basal metabolic rate), but imported sessions show the same value for both categories. See this article for details:
                                            https://lifehacker.com/health/active-calories-versus-total-calories
                                          4. If one wants data in multiple places, then a native recording can be simpler to accomplish that than using apps like RunGap to do the importing, or worse, doing it manually by exporting from one device then importing to another. You mention “simplicity” above — isn’t it simpler to have a Wahoo device write to Wahoo and a Suunto device write to Suunto than to have an export/import situation in-between? One can argue either side of that.
                                          I dual record with Apple and Suunto, and at one point just used Suunto, but Suunto’s export to Apple Health gave me running sessions without map data. In general, Suunto’s support for writing data to Apple Health is suboptimal. Meanwhile, if I want ZoneSense data on my runs, I need to use an external HRM with Suunto — I can’t simply import an Apple recording running session and get this. So I wear a Polar H10 chest strap which sends two bluetooth signals. One goes to Suunto and gives me ZoneSense data, and the other goes to Apple Watch, and I get session data properly written to Apple Health.
                                          • S Offline
                                            Sascha Domres Bronze Member @gkaempfer
                                            @gkaempfer Same here
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
