Map lag
For some time I am experiencing laggy maps. When I move around or when I zoom in/out, there is a very noticeable lag/delay. This was not the case when I got the watch, and reboot doesn’t fit that. I am the only one? I will try to record a video next time.
@OutdoorMan I have not seen that issue. I’ll check this weekend on my next longer run.
@OutdoorMan if that isn’t you, you are not the only one:
https://www.reddit.com/r/Suunto/comments/1s59wli/map_on_suunto_race_2/ -
@OutdoorMan in what area? Video of the lag would be useful
@2b2bff that is not me and that’s exactly what I experience.
@pavel.samokha basically what @2b2bff posted, but I will try to record it next time. -
Maybe many small buildings can contribute to render lag
@pavel.samokha in the woods, with no buildings, but same behaviour.
@OutdoorMan it doesn’t sound normal, video and location would be welcome next time to test
@pavel.samokha Did you figure it out? I’m having the same problem with my new Race 2… My Suunto Race 1 used to run much more smoothly
Edit: It seems to be “fused direction”, which uses compass when stationary and GPS while above ~ 2 km/h.
Register Login
