Cycling Power Estimator
I should maybe raise the average window from 3 to 10s, to smooth that grade variation (especially in descents).
My guess is that 0 is probably closer to the real value than 450W (at + 5/7% grade, I am between 200 and 350W). I agree, you probably won’t get heuristics that works in all cases. -
@bubuche Check with the latest update, I’ve re-done the logic.
Now if there is no cadence sensor, power is always computed on the difference between actual speed and terminal velocity.
Terminal velocity is still subject to grade smoothing. The altimeter looks at altitude in 20cm chunks apparently, so you need several metres to compute a useful grade reliably.This is computationally more expensive but may not make much difference overall.
I’m just hoping for no unexpected regressions. -
@mickywickyftw thanks for the update, I’ll try this week hopefully (on the same road, to compare).
One suggestion could be to wait for a few more seconds when the slope reduces before using standard formula (I totally ignore if there are mathematics models behind this, just intuition and probably hard to calibrate). I mean we are still fast for a while when the grade drops from -4% to -2% for example. -
I’ve pushed a few new builds, tweaking the algo until I’m more or less happy with it.
Outstanding items:- Speed and cadence sensors have approx. 3-second latency. If you add another 2-3 seconds on top, that increases the latency between you starting a climb, and the power displaying. No problem for later analysis.
- Given that it is an estimate, using 3-second power might not be that useful - maybe make 5- or 10-second averages the default.
- Occasional crashes trying to load the app on my watch with “maximum number of Suuntoplus apps reached”, which seem completely independent of what the app does. Restarting the watch always fixes it. Waiting a while also does, but not sure how long - 5 minutes to 2 hours from what I’ve seen.
- Once I trust it enough, retrieve the rider’s weight from the watch settings once again as it used to - but I suspected that of causing the error mentioned above.
- Grade calculation is a pain - the altimeter only knows 20 cm increments. On say, 8 metres, that’s 2.5% grade over 1-2 seconds riding reasonably fast - this will cause false and/or jumpy readings at any speeds below 35 kph. I’m curious to see how Suunto’s running power or NGP take grade into account.
@mickywickyftw I owe you a feedback on previous changes (not the 13th July one): far better in descents. They are still some spikes (above 450W), when the road suddenly changes (from negative to positive grade for example). I still used 3s for the power average. I’ll switch to 10s for next moves.
@mickywickyftw unfortunately, there are regressions in the last update. My feeling is that power is overestimated in descents (and is now almost as high as power in ascents). Just my feeling, as I do not have a real power meter to validate this. I would say that power should somehow be related to heart rate.
The power estimator calculates the mechanical force required to move at a given speed on a given slope (with weight, terrain, etc. taken into account).
Heart rate correlates with power over longer efforts but diverges significantly in short bursts (because it reacts more slowly) on descents (because you don’t have to push as hard to produce the same acceleration), and in heat (for obvious reasons). The power model doesn’t see fatigue, cardiac drift, or how hard your legs feel. But that is not its purpose either.The spikes are a known issue caused by the grade estimation model. They happen at grade transitions, e.g. when the road flips from downhill to uphill. Grade snaps from the descent average to the ascent average in a single second, simultaneously with the acceleration that naturally occurs there. That combination can briefly produce very high values. Difficult to work around for now, and given the altimeter’s 20cm granularity, it may not be achievable, but I’m still looking.
Descent overestimation: I thought this might be the case. Without a cadence sensor the model has no way to detect coasting, since it cannot tell whether you’re pedalling or freewheeling. So it has to assume by comparing your speed to terminal velocity, which is calculated using… the grade estimation. So we’re back to that limitation.
On the topic of the grade estimation used by Suunto for NGP, that algo seems to suffer the same issues.
@mickywickyftw I’m aware that the model has some limitations (especially due to grade variations and without cadence sensor), but getting the same power estimation (~ 220/250W) in both a 10 minutes descent and ascent is quite unexpected (at 100bpm and 140bpm, respectively). Same position on bike. As far as I remember, I did not observe this on previous versions (I switched to 10s window today though, so not exactly same settings).
@bubuche 200-250W is very high for a descent, true. Too high for the model as it should be I think.
Can you help narrow it down, as I have not observed this myself?
Zoom in on the downhill section, and note:- % grade
- distance
- start and end elevation
- Avg power
- Avg speed
- Your total weight as configured in the settings (bike + rider + pack)
If you can zoom to just that section, overlay speed and power, that might give us a clue.
I think I’ve worked it out - it was a typo! Please try the latest build.
It meant that terminal velocity was ignored when going downhill without a sensor - resulting in those high power readings.
Let me know, as I cannot test this for a couple of weeks now. -
Ok, I’ll try in a few days
Changing a + to à - helped a lot
This is far better in descents.In a previous post, you requested the avg speed and power on a section. How? I can only get this for segments of 1/5/10 km.
@bubuche I would use Runalyze or another external platform for that.
Now I‘ve been using the latest updates for a bit, I think we‘re there.
I thought about using predicted wind from the weather app, but you end up losing accuracy as soon as buildings are involved.
I will look at using the accelerometer perhaps, but felt it was overkill when I started with this app. It might solve the grade latency issue though. I‘ll play around with it at some point. -
Hello,
Does this app work on Suunto 9 baro?
I tried but I only get a black screen and back to the main menu after a while. -
@phck9b It works in the simulator, but I don’t have a S9 Baro device to test. It may be crashing due to low memory, I refactored it once to make it fit in the Vertical 1’s runtime, so that’s likely.
If you have VS Code, maybe you can share the watch’s log file. -
@phck9b I had a freeze on 9PP at the first time I tried to enable it with live-tracking in parallel. After restarting the watch both do work now. So maybe just use one app and restart the watch before.
@Ecki-D. Thank you very much! I’ll try next time
@mickywickyftw
Thank you, but I haven’t VS Code. I wiil try the solution given by Ecki d (next post). -
New version pushed with one change to use a median of 3 rule on the acceleration - ignores single-sample spikes and should smooth out the power readings.
I’ve also added text in the description to say that so far I only know of 9PP and above watches being able to run it.
@phck9b let me know how you get on with your S9B.
Register Login
