    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Will OpenSuuntoPlus be coming to Suunto Run?
    Scheduled Pinned Locked Moved Suunto Run
    19 Posts 11 Posters 2.2k Views 10 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ? Offline
      A Former User
      Hello,
      Does anyone know if Suunto plans to introduce OpenSuuntoPlus to the Suunto Run? I don’t think it’s an option, and it leaves this device behind in any future updates, so I’m considering replacing it with a compatible one. Does anyone know anything about this?
      Thanks!
      • Brad_OlwinB Offline
        Brad_Olwin Moderator @Guest
        @isaac.net The Suunto Run does not support Suunto+, I doubt that this will change and I would not plan on using Suunto Run with Suunto+ apps.
        Vector/T6c/Vertical 2 Ti
        JebClydeNCJ 1 Reply Last reply Reply Quote 2
        • JebClydeNCJ Offline
          JebClydeNC @Brad_Olwin
          @Brad_Olwin To be perfectly honest, I’m happy to hear that: its one of the main reasons I got the Run over the other offerings, as it makes it impossible to lose an app-store based feature if the app store is ever unavailable (server/internet outage, etc.) or (as happened in 2019 to the Traverse/Ambit lines) is cancelled outright in a change of ownership or something.
          I realize differing opinions are out there on it all, but having a non-app-driven GNSS watch is a rarity in the industry now, so I for one won’t be complaining if the Run gets to keep that distinction🙂. Here’s to Suunto, keeping the Core (“off grid” in their own words) and Run as not-so-niche options the “other guys” have ignored!
          thanasisT 1 Reply Last reply Reply Quote 1
          • thanasisT Do not disturb
            thanasis Bronze Member @JebClydeNC
            @JebClydeNC I don’t follow your rationale … You cannot be arguing that you lose something by having additional options … on the contrary, not having options means you lose the option of having something
            ravenR Brad_OlwinB 2 Replies Last reply Reply Quote 2
            • M Offline
              Mi_chael Bronze Member
              It will be great if Suunto plan to add a compability between Suunto Run and My Plan for syncing it.
              • BokiRunB Offline
                BokiRun Bronze Member
                I have been using suunto run for a long time. From the beginning of October 2025. I have run almost 1800 km and nothing is missing from the watch.
                1 Reply Last reply Reply Quote 4
                • ravenR Offline
                  raven Bronze Member @thanasis
                  @thanasis said in Will OpenSuuntoPlus be coming to Suunto Run?:
                  I also don’t get Jeb’s reasoning. As someone with a Race S, I have access to the Suunto+ store, but I can simply ignore it if I wish.
                  The Run has access to different watch faces, yes? In my eyes, these are similar capabilities. You need to go to the Suunto app and “add on” either an additional watch face or a Suunto+ app, but there’s never any requirement to do either. One can ignore both capabilities if one wishes.
                    Brad_Olwin Moderator @thanasis
                    Well, I see @jebclydenc point. The Run has many S+ features built into the watch so fewer S+ features would be used. Second, if future S+ features require more memory that an older watch does not have that could be problematic.
                    I personally like the Run a lot, it has dramatically improved since I started testing for Suunto. I typically don’t need maps when following a route and often will check my phone anyway. I would likely use two watches from Suunto, the Run and Vertical2. I would use the Run for daily and most of my workouts and the V2 for SkiMo and mountain workouts where I need a map.
                    ravenR 1 Reply Last reply Reply Quote 2
                    • ravenR Offline
                      raven Bronze Member @Brad_Olwin
                      @Brad_Olwin said in Will OpenSuuntoPlus be coming to Suunto Run?:
                      Theoretically, couldn’t Suunto have a setup where an app that has a demanding requirement not show up for Run users but only for those who meet the requirements? Feels like this objective is a QA user more than anything else. Alternatively, if someone on any watch downloads a S+ app and finds it “problematic” then they can remove that app (and ideally, report it as bugged to Suunto).
                      I don’t have a quarrel with the Run for its lack of S+ ability, as I think that makes for a clear line showing why one might pay for for a Race, etc. However, it also means S+ isn’t a “core experience”.
                      I do think the limited sport modes is silly in comparison. People will just end up tagging some sessions with a slightly less useful tag in most cases. Now if there is a limitation of how many modes a watch can “hold” then have a core set and let people select from a list what secondaries they have — I think maybe Polar does something like this?
                      Finally, while I’m here, I’ll repeat I think it was silly for Suunto to give the Run the ability to do offline music playback but not include it further up the line. People say that’s due to limitations of the older watches, but Race 2 came out after Run and still doesn’t have it.
                      Yes, I realize the Run has its own OS and that’s probably part of the reason, but I think it’s kind of dumb they rolled a new OS for just one thing. Mostly though, I think it makes purchasing decisions sillier than they need to be. If I want both maps and offline music, there’s no Suunto solution for that, even though they have watches that offer either solution. This makes Suunto feel more like Garmin in my mind, giving an impression of being more fragmented with different teams on different watches not paying attention to what the other team is doing.
                      • Iraklis MarkelisI Offline
                        Iraklis Markelis
                        As a software engineer I wish I could have the opportunity to develop apps for Suunto Run. I don’t understand why Suunto Run isn’t included in programmable watches.
                        ravenR 1 Reply Last reply Reply Quote 0
                        • ravenR Offline
                          raven Bronze Member @Iraklis Markelis
                          @Iraklis-Markelis said in Will OpenSuuntoPlus be coming to Suunto Run?:
                          Technically why Run isn’t included, is because when they developed Run, they made a new OS for it; it does not share the same OS as Race/Vertical.
                          As for why Suunto did that, I suspect part of it was due to the price they wanted to set Run, low enough to attract people. However, at the same time, if the Run had the exact same feature set as the Race, and was cheaper, then why would anyone get the Race?
                          Therefore, the design of the Run was such that it would have less features than the Race and Suunto could then charge a lower price for Run while keeping some features to encourage people to spend more to get the Race.
                          SuuntoPlus is one of the main features the Race has that the Run does not.
                          G 1 Reply Last reply Reply Quote 1
                          • G Offline
                            Giorgio60 @raven
                            @raven
                            Personalmente non sono minimamente d’acordo! Sono nuovo del mondo Suunto e non ho speso 240 Euro per poi spenderne altre 490 per il Race2. Molte altre case produttrici danno accesso al loro market di applicazioni, campi dati e quadranti. Basta solamente fare una cernita dei widget, allenamenti e altre cose e magari metterle a pagamento per il Suunto Run. Ma blindare un orologio solo con le applicazioni volute mi sembra esagerato, e se fosse così, credo che sia esagerato anche il prezzo del Run. Altri orologi di base, di marche ben conosciute, hanno questa funzionalità. Per il momento resterò sicuramente con suunto Run, ma per gli allenamenti e i Coach utilizzerò i miei orologi di altre marche, che le offrono gratis. Non credo che questa sia una buona politica di marketing (IMHO).
                            Grazie
                            ravenR 1 Reply Last reply Reply Quote -3
                            • ravenR Offline
                              raven Bronze Member @Giorgio60
                              @Giorgio60 said in Will OpenSuuntoPlus be coming to Suunto Run?:
                              @raven
                              Grazie
                              No, you misunderstand. The idea is not you spend 490 after spending 240, but instead if you had done research, you’d spend the 490 instead of the 240 if the Suunto+ functionality was something you needed. It’s not that you’re supposed to buy two watches but instead the watch that meets your needs.
                              Note I wasn’t the one who made the decision on what features Run was not going to get. I’m simply making a guess at what Suunto was thinking.
                              They want the Run at an entry price point, and Race at a higher point with more features. What features do you leave off the Run to accomplish this?
                              If the Run and Race have the exact same features, then they should have the same price and there’s no need for them both to exist.
                              I do think with Suunto now encouraging more people to make S+ apps it’s weird the entry model cannot run them. If it was a “base feature” then that’s more encouragement for more people to make apps.
                              Anyway, perhaps Suunto will change their minds and add on the capability to run S+ apps from the Run, but given the Run is a separate OS, it’s not simply “putting back” something they took away but instead re-engineering the feature for that OS.
                              Finally, if you think the Run is overpriced, then what watch would you prefer instead? Perhaps Suunto was not the best fit for you to begin with.
                              G 1 Reply Last reply Reply Quote 3
                              • G Offline
                                Giorgio60 @raven
                                @raven
                                Il Suunto Race 2 per me è troppo caro. Il Run va benissimo come prezzo.
                                • ravenR Offline
                                  @raven
                                  Then it sounds like the Sunnto+ ability wasn’t worth the additional cost for you. Enjoy your Run watch!
                                  • ? Offline
                                    A Former User
                                    When the Run was released and they were talking about a new operating system, I thought it would be the beginning of something that would spread to other devices, and the low price would be the downside of being the first to use an immature system. But with the release of OpenSuuntoPlus, which excludes the Run, it seems the Run will remain an unsuccessful experiment. The feeling right now is that the purchase was a mistake and the watch won’t evolve much further. This makes me consider buying another device, possibly from a different brand to avoid these kinds of nonsensical changes, like Coros.
                                    Pep CarbonellP 1 Reply Last reply Reply Quote -1
                                    • Pep CarbonellP Offline
                                      Pep Carbonell @Guest
                                      I wouldn’t say it’s been an unsuccessful experiment, but it does seem to distance itself from the brand’s other watches, as if it were from another brand. Let’s see…
                                      A 1 Reply Last reply Reply Quote 0
                                      • A Offline
                                        aiv4r Silver Members @Pep Carbonell
                                        @Pep-Carbonell I think the idea was to have something specifically for road runners (marketing seems to agree with it) with the assumption that they will not need a lot of fancy S+ features. And it is in a way a successful experiment in my opinion, if I would only run roads I would be tempted to get more simplistic variant. But lets see 🙂
                                        Suunto Race 2 (Titanium Trail)
                                        Suunto Vertical (Titanium Solar Forest)
                                        Pep CarbonellP 1 Reply Last reply Reply Quote 2
                                          Pep Carbonell @aiv4r
                                          @aiv4r I agree, although I also use the Suunto Run for trail running. The point is, in my humble opinion, that when you open the Suunto Plus apps the game changes, it opens up many more possibilities for road and trail running.
                                          We’ll see
                                          Register Login
                                          • First post
                                            Last post
                                          Suunto Terms | Privacy Policy
