    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Bungee Strap is too short for winter diving
    Scheduled Pinned Locked Moved Nautic
    2 Posts 2 Posters 235 Views 3 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • N Offline
      Niels-Søren Bøgh
      Just a thing, water temp is now below 0 C i our place.
      So, some extra undergarment is needed under the drysuit… 😉
      But, then the Bungee Strap becomes too short…!
      • Pascal RoyP Offline
        Pascal Roy
        Hi everyone, quick tip for the Suunto Nautic bungee attachment/strap setup:
        You don’t need to attach both pull tabs to the retainer loop on the strap.
        With both tabs attached, it fits perfectly snug on my arm over a 3 mm wetsuit.
        With my 7 mm wetsuit, it’s way too tight, so I only attach one tab. That leaves it a tad too slack on its own, so I added a small bungee D-loop extension (just a short extra piece of bungee cord), and now it’s spot-on perfect.
        On a drysuit, I imagine attaching only one tab would give a great fit without any extra tweaks.
        Another option if you need even more length/flexibility for thicker suits (or just prefer it): you could swap the entire bungee cord for a longer one. The Nautic bungee is adjustable via knots, but replacing it with a custom longer piece (or aftermarket equivalent) is a straightforward way to dial in the perfect fit for your setup.
        This makes the whole thing super comfortable and adaptable depending on your suit thickness. Hope it helps anyone fine-tuning their Nautic strap!
        • First post
          Last post
        Suunto Terms | Privacy Policy
