    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    V2 bike use on handlebars
    Scheduled Pinned Locked Moved Suunto Vertical 2
    bikevertical2routedisplaynavigationrace 2
    12 Posts 7 Posters 1.5k Views 7 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • matteo_000M Offline
      matteo_000
      Last weekend I used for the first time my new SV2 (I had SV1…) on handlebar of my MTB. I have notice that the SV2 has a problem to show clear the maps on the display (use without route) .
      When you select the map the display, after around 8 sec, it decreses the brightness; again after around 8 sec the display goes in standby mode (or dark mode of the map) and is impossible to see the map while you ride 😕 . You can show the map clear only to touch or push the botton but when you ride is not easy.
      To solve the problem I think that they could develop an option on the SPORT MODE for the bike activity, that doesn’t permit to go in stand by mode (maps all dark). Sure the the battery consumation will increse but we can choose what we need with the option.
      Otherwise using the map (in sport mode activity) on handlebar bike use is very difficult and not useful. Someone has had the same problem???
      I hope in the future fw upgrade for all the bikers. 😊
      SV2 All Black - Italy
      Tomas5T 1 Reply Last reply Reply Quote 2
      • Tomas5T Offline
        Tomas5 Gold Members @matteo_000
        @matteo_000 you can enable AOD in sport mode settings. Than it works. But battery is drained faster at least on Race 2.
        Suunto Ambit 2 > Suunto 5 > Suunto Race 2
        matteo_000M AudaxjoeA 2 Replies Last reply Reply Quote 1
          matteo_000 @Tomas5
          @Tomas5 I have try but with display set in sport mode activity
          • brightness: ! HIGH
          • display: ALWAYS ON
            after around 8 sec + 8 sec the map goes dark.
          I know that the battery drain would be faster but if I need (sometime during the ride…) to see the map for the correct route now is impossible especially for MTB use.
          I think that a specific option would be the solution; maybe to stop the display brightness to the first step after 8 sec. will be the best.
          Tomas5T 1 Reply Last reply Reply Quote 0
          • Tomas5T Offline
            @matteo_000 than it is one more reason to miss MIP displays
            • AudaxjoeA Offline
              Audaxjoe @Tomas5
              @Tomas5 it still goes very dull and hard to read with AOD. I’d happily loose battery power for the option of being able to see map clearer.
              Certainly is the case where the V1 is much better.
              I prefer the V2 in every other area!
              Suunto Vertical
              Suunto 9 BARO
              Garmin Fenix 3, 5
              Suunto Vector
              matteo_000M 1 Reply Last reply Reply Quote 1
                matteo_000 @Audaxjoe
                @Audaxjoe I agree with you. The best would be choose one option in the setting menù of activity.
                Like this for the handlebar bike/mtb use insn’t usefull.
                One compromise would be to choose (with option) to stop the darkness display to the first step after 8 sec without AOD. 🙂
                Would be a solution for bike activity where you use the watch on handelbar.
                S 1 Reply Last reply Reply Quote 1
                • S Offline
                  slaine @matteo_000
                  @matteo_000
                  I am also a little upset by this behavior after my first spring ride with the new Vertical 2 ☹️ Special display/map setting for bike would definitely be very beneficial.
                  • M Offline
                    matus69
                    hi, is this fixed or still an issue? Owning Vertical and now about to purchase V2, but I bike 30% of time and almost always with the map… thanks
                    M matteo_000M 2 Replies Last reply Reply Quote 0
                    • M Offline
                      maszop Bronze Member @matus69
                      @matus69 Vertical 2 will be much worse, and it’s not just about AOD, but also about rain. In the Vertical 2, you can’t currently disable the touchscreen on the map screen. Good luck using the watch with the map if there are even a few drops of water on the screen.
                      • EgikaE Offline
                        Egika Platinum Member @maszop
                        @maszop said in V2 bike use on handlebars:
                        this will also change with the next FW update. Then you will be able to fully disable touch for Vertical 2
                        M 1 Reply Last reply Reply Quote 5
                          matteo_000 @matus69
                          @matus69 said in V2 bike use on handlebars:
                          I hope …for all bike users 😞 🤞 🤞 🤞
                          • M Offline
                            matus69 @Egika
                            thank you all for your replies.
                            Register Login
                            • First post
                              Last post
                            Suunto Terms | Privacy Policy
