    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Wrong HR during skitouring
    Scheduled Pinned Locked Moved Suunto Vertical
    16 Posts 5 Posters 987 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • G Offline
      giuliosq
      Hi, did someone experienced a totally wrong HR on the vertical during an activity lately? I was skitourign and my apple watch was correct signing 146 bpm while my vertcial was always wrong like signing 86 or something… the watch was obviously well positioned. it never happened before
      thanks
      M M 2 Replies Last reply Reply Quote 0
      • M Online
        Matúš Bronze Member @giuliosq
        @giuliosq, hi, considering that you wrote:
        @giuliosq said in Wrong HR during skitouring:
        I’m assuming that you’re relying on the optical HR measurement. It’s a common issue that with cold weather (less blood flow) and using poles (sort of sensor cadence locking) the OHR measurement fails, even if the watch is well positioned over the wrist. If you care about HR data, go with HR belt.
        Suunto 9 Peak Pro Titanium Slate
        Suunto Spartan Sport
        #swatt
        G M 2 Replies Last reply Reply Quote 3
        • G Offline
          giuliosq @Matúš
          @Matúš thanks very much! now I get it, that goes exactly according to my kind of sport actually… HR belt BTW I read that could cause some wrong interactions with the avalanche sensor I have to carry on my chest when doing these kinds of activities
          M 1 Reply Last reply Reply Quote 1
          • M Online
            @giuliosq, I know about avalanche transceivers but, since I’m not a skimo guy, I don’t know what’s the interaction between these devices.
            There are here some users that practice skimo so, maybe, they will share their experience!🤞 🙂
            #swatt
            • M Offline
              MRRUN @Matúš
              @Matúš But why can the Apple Watch, which also uses photoplethysmography (PPG) heart rate monitoring, provide accurate results, while Suunto’s readings are incorrect? Thank you.
              • M Offline
                MRRUN @giuliosq
                @giuliosq But I also want to ask about my Vertical — why is it that the Apple Watch, which also uses optical heart rate monitoring, can give accurate results? I’ve done tests, and during interval runs and strength training, the Apple Watch is always correct, while the Vertical is consistently wrong.
                Thank You.
                G 1 Reply Last reply Reply Quote 0
                • EgikaE Offline
                  Egika Platinum Member @Matúš
                  @Matúš said in Wrong HR during skitouring:
                  I am a mountain and ski touring guide, and maybe can shed some light on this:
                  Yes, avalanche transceivers could interfere with other wireless devices. It is advised to keep them apart.
                  The international MountainSafety.info (MSi) board has shared information on proper wearing of avalanche transceivers.
                  Basically there are two ways: using the supplied harness, or in a zippered pocket.
                  When the harness is used, this has a couple of disadvantages: There must always be a layer of clothing above the transceiver. This is difficult in spring conditions when you just wear a shirt. Plus it is more difficult to reach the device if you need to take it out from under your clothes in emergency.
                  This is why me and most other mountain guides wear the transceiver in a zip pocket (zip must be closed). This way it is also far enough away from the BLE chest strap.
                  G 2 Replies Last reply Reply Quote 2
                  • G Offline
                    giuliosq @MRRUN
                    @MRRUN thanks! my same issue I always think about. Beacause even on the threadmill indoor running the apple watch is always correct on the pace (even without tuning) and the vertical (having it tuned more than once according to the pace of the treadmill) keeps on being wrong. The aplle watch HR in this last ski tour was totally totally perfect., on point And I paid it 1/3 of the vertical… being it BTW a second hand aple watch, from four years ago… the vertical should be way better for the price we pay for it. I have the same issue with the mumber of lengths swam in the pool for example…
                    • G Offline
                      giuliosq @Egika
                      @Egika Thanks very much for the clarification. I always tend not to have many stuff blutooth or wifi stuff around the tranceiver
                      • G Offline
                        giuliosq @Egika
                        @Egika I Lately BTW started using it in the leg pocket of my bib
                        • M Online
                          Matúš Bronze Member @MRRUN
                          @MRRUN, hi, actually, I don’t know the reason. What I wrote above is based on my experience on the field and on what I read on this forum in the years.
                          #swatt
                          • EgikaE Offline
                            Egika Platinum Member @giuliosq
                            @giuliosq wrist heart rate is highly personal.
                            Your experience will be different from others and depends on many factors.
                            The use in the cold and walking with poles add to the complexity of the task the watch has.
                            Good that the AW handles this well for you. And bad that the Vertical does not…
                            In general I think you are correct in saying that the OHR sensor of the Vertical in inferior to the AW.
                            That’s why it was changed with Vertical 2.
                            • G Offline
                              giuliosq @Egika
                              @Egika Thanks!
                              The only thing I keep on not understadnign is: how is it possible to have all these kind of variablity on a high end sport watch that should be doing exaclty these kind of stuff. It is still hard to me to grasp the idea that if I walk with poles or if its cold (it should be cold in the mountins…) the vertical does not do what I paid for… whereas a second hand apple watch I bought for 70€ does it perfectly… I cant keep on buyng suunto watches waiting for the next model where something has been improved (somethign so basic like a functioning HR sensor)
                              • EgikaE Offline
                                @giuliosq Wrist heart rate is highly individual.
                                What works for you does not work for others and vice versa in all conditions.
                                A car is designed to drive around a corner. Yet it does not what it is designed for if you try it on an icy surface.
                                • G Offline
                                  giuliosq @Egika
                                  @Egika Alright but a multi sport sport watch designed expecially for the use in the mountains -called “vertical”- shold be programmed to properly read HR while doing sport activities like walking with poles… I dont think other users find this wrond data suitable for them… Im not asking for it to elaborate crazy datas, simply asking for HR while walking in the cold. Anyways, thanks a million
                                  2 1 Reply Last reply Reply Quote 0
                                  • 2 Offline
                                    2b2bff Silver Members @giuliosq
                                    @giuliosq the Vertical 2 has a way advanced sensor and might do what you want from it. The first gen Vertical and Race both have sensors that work for some, but most speak badly about them…
                                    Race S
                                    • First post
                                      Last post
                                    Suunto Terms | Privacy Policy
