    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Using timer at the same time as an activity
    Scheduled Pinned Locked Moved Suunto Race S
    8 Posts 6 Posters 967 Views 5 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • Anders BornstedtA Offline
      Anders Bornstedt
      Hi,
      Just started to use Race S and have a question if it is not possible to use the timer function at the same time to have an activity running?
      E.g. I am doing Calisthenics training and some exercises are 30 sec activity for which I want to use the timer function.
      Can this be done?
      T sky-runnerS SamppaPS Inge NallssonI 4 Replies Last reply Reply Quote 1
      • T Offline
        The_77 Silver Members @Anders Bornstedt
        @Anders-Bornstedt you can use the gym timer Suunto plus app, which allows you to predefine timers before you start. I think there’s also a calisthenics app too specifically for that?
        Suunto Spartan Trainer Wrist HR / 9PP Refurb
        Anders BornstedtA 1 Reply Last reply Reply Quote 0
        • sky-runnerS Offline
          sky-runner Platinum Member @Anders Bornstedt
          @Anders-Bornstedt Perhaps the easiest solution is to use the lap time which you can reset by pressing the lap button. You can create a customized activity profile in the Suunto App with the lap time shown on your main data screen.
          Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
          Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
          • SamppaPS Online
            SamppaP Silver Members @Anders Bornstedt
            @Anders-Bornstedt there is also a Suunto plus app called “stopwatch”. Haven’t tried it myself so can’t tell if it’s any good though.
            Vertical All Black
            Ambit 3 Peak
            Suunto smart sensor
            SportsfreundS 1 Reply Last reply Reply Quote 0
            • SportsfreundS Offline
              Sportsfreund Bronze Member @SamppaP
              @SamuelP Ideally, Suunto would already allow users to push an ongoing activity into the background for a while.
              In this time you can use stopwatch or timer.
              • Inge NallssonI Offline
                Inge Nallsson @Anders Bornstedt
                @Anders-Bornstedt said in Using timer at the same time as an activity:
                Since it’s 3 days since you asked the question, you probably know the answer already. But here goes:
                The ‘Timer’ widget on a Race S (Countdown/Stopwatch) can be started before an activity and run concurrently with that exercise. I tried both a dry run “Running” and a “Calisthenics” session.
                The countdown can be set to a “Custom” value (I tried 0:00:30 for 30 seconds) as well as the fixed quick options 1 min, 3 min etc. Defined, and started by the upper button, we can then leave by pressing the bottom button - and quickly launch the exercise session.
                The ‘Timer’ then throws up its screen above any other screen; starting to beep and vibrate each second 10 seconds before the end time, with the final beep being looong. Unfortunately there is no ‘Repeat’ function, so we have to “Restart” the countdown again with the upper button (exposing the underlying running exercise screen), or using the “Dismiss” function by pressing the bottom button.
                Not choosing an option while running the ‘Timer’ outside of an exercise will ultimately end the timer when the screen goes black or falls into the Always On Display. During an exercise (using the full AOD there), the ‘Timer’ screen did not exit due to inactivity - at least for the ca 1.5 minutes I waited.
                It works quite well overall, but a 30 seconds setting is rather noisy… That means 20 seconds of beeping every minute. Yikes!
                Suunto Race S
                  Anders Bornstedt @Sportsfreund
                  @Sportsfreund Agree, this should be possible but it not.
                    Anders Bornstedt @The_77
                    @The_77 said in Using timer at the same time as an activity:
                    The problem I realize that I have is that I cannot find apps that I have added.
                    The only possible apps to add are the ones that was alreday installed when I gor the watch (Burner, Climb, Ghost runner, Chalistenics).
                    Register Login
                    • First post
                      Last post
                    Suunto Terms | Privacy Policy
