    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Suunto 2.50.26 – Q4 2025 Release Notes
    Scheduled Pinned Locked Moved Watches
    422 Posts 115 Posters 75.2k Views 114 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
      Dimitrios Kanellopoulos Community Manager @Zdeněk Hruška
      @Zdeněk-Hruška yes have reports of stryd 5 . Working onthis
      Creator of quantified-self.io a portal that allows you to analyze your data from various providers, upload fit activity files to Suunto app, gpx routes and more…
      1 Reply Last reply Reply Quote 3
      • DrSilverthornD Offline
        DrSilverthorn @Zdeněk Hruška
        @Zdeněk-Hruška There is similar behavior withy verity sense - the sensor shows as being connected, but there is no heart rate data.
        Suunto Race Ti, Vertical Ti, Vertical 2 Ti, Garmin Enduro 1/2, Polar VV2
        • thanasisT Offline
          thanasis Bronze Member @Dimitrios Kanellopoulos
          @Dimitrios-Kanellopoulos coming back to the battery drain issue.
          This is the second full charge cycle I am running (so not yet a full 2 cycle calibration) .
          It seems the drain is there in my case - although I shall wait for the second cycle iteration. Unless I have faulty device (which is something I need to assess btw), I get 5% drain on activity without GPS (Indoor Tennis for instance) with a HR belt connected and like 5% on a 1hour run with GPS and HR Belt . This is exceptionally high compared to where it was like 6 months ago (with previous firmwares) . Resetting the device after the activity seems to stabilize the drain percentage to another 5% for the rest of the day if worn on the wrist.
          I will continue reporting on that
          Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 1
            Dimitrios Kanellopoulos Community Manager @thanasis
            @thanasis said in Suunto 2.50.26 – Q4 2025 Release Notes:
            why would you need to wait ?
            Its I think very difficult to conduct the test you are doing with so close buckets. Meaning is its 5.2% to 4,4% ? etc.
            Also I see you are trying to test battery life with so small activites that eventually have the overhead of ie connecting to sensors etc.
            Not really sure why you have to bother so much to be honest and without being disrespectful but I have the strong feeling that:
            • Either your v1 is getting old ?
            • Either we are all ghosted by battery life issues.
            I could say easily: Continue the tests , but on a personal note, I ll say just let it rest man and enjoy your trainings.
            NOTE: we did have a battery “kinda” drain but that was on time mode it was minor and it was on first connect of the sensor. This is how the whole story began I think, or am I wrong?
            Also if there is a really battery life issue we will kinda find out sooner or later.
            thanasisT D 2 Replies Last reply Reply Quote 8
            • thanasisT Offline
              @Dimitrios-Kanellopoulos thanks . Indeed . I need to forget about it
              btw: those are not the only the excercises I did ,or measured . I just wanted to indicate the indoor tennis (no gps) and outdoor running (gps + map etc) did drain a similar (as seen on the watch) battery percentage
              Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 0
              • D Offline
                duffman19 @Dimitrios Kanellopoulos
                @Dimitrios-Kanellopoulos There will be significant battery drain if the backlight stays on after starting an activity, as has been reported by a number of us.
                @thanasis Perhaps this is also the cause of your observed behavior?
                Vertical Ti / S9PP Ti / S9P Ti
                • Bigb0zzB Online
                  Bigb0zz
                  Suunto Vertical 2 - System crash during workout . (Latest FW)
                    @thanasis well not completely. Let’s let a little time pass. I’ll prepare Also some tools
                    • atoponceA Offline
                      atoponce @Zdeněk Hruška
                      @Zdeněk-Hruška This has been a long-standing bug with Suunto watches. If GPS is locked, the watch will source pace and distance from GPS, not from Stryd. If GPS is not locked, such as running on the treadmill, then Suunto will use Stryd for pace and distance.
                      I’ve raised bug this with Suunto support a few times, so hopefully it gets fixed.
                      Suunto Race S / 9 Baro / Ambit 3 Peak / Observer
                      Polar H10 / Verity Sense / OH1
                      Stryd Duo / Wind
                      r/suunto mod
                      Dimitrios KanellopoulosD 1 Reply Last reply Reply Quote 2
                        Dimitrios Kanellopoulos Community Manager @atoponce
                        @atoponce nope I don’t think it works like so.
                        atoponceA 1 Reply Last reply Reply Quote 0
                        • atoponceA Offline
                          atoponce @Dimitrios Kanellopoulos
                          @Dimitrios-Kanellopoulos That’s what I’ve observed. Here is a recent outdoor 5K race with the Stryd Next Gen pod paired to my Race S. The paces differ:
                          Here is a treadmill workout. The paces perfectly agree:
                          This is reproducible on every run I do outdoors versus indoor. When GPS is locked, the paces with Stryd disagrees. When GPS is not locked, the paces are in agreement.
                          Stryd Duo / Wind
                          r/suunto mod
                          atoponceA 1 Reply Last reply Reply Quote 2
                          • atoponceA Offline
                            atoponce @atoponce
                            This is a 5K race that alerted me to the problem. Suunto reported the distance as 5.19 km when the the course was actually short at 4.63 km, which Stryd correctly calculated. Note that Suunto’s pace is consistently higher than Stryd’s, and thus for the duration, resulted in a longer distance.
                            Stryd Duo / Wind
                            r/suunto mod
                              @atoponce afaik you should turn off auto calibration but this was long time ago for me with stryd. I’ll ask internally
                              Zdeněk HruškaZ atoponceA 2 Replies Last reply Reply Quote 1
                              • Zdeněk HruškaZ Offline
                                Zdeněk Hruška Bronze Member @Dimitrios Kanellopoulos
                                @Dimitrios-Kanellopoulos that doesn’t work unfortunately. I have all Stryd data turned on and calibration turned off and if I am lucky I will get a power from the pod. But the pace is always from the watch (I tested with different settings and hand movements). Maybe I am wrong but it seems like that’s really the case and it shouldn’t be.
                                • atoponceA Offline
                                  @Dimitrios-Kanellopoulos Thanks for raising this internally. Auto-calibration is disabled, but auto-calibration is a new feature with the release of this firmware. I’ve checked several runs going back to January 2025 when I purchased the watch. This bug has been present since at least that point.
                                  Stryd Duo / Wind
                                  r/suunto mod
                                  • M Offline
                                    Mi bueri
                                    Hello,
                                    I had the following problem today (similar to 3 months ago):
                                    31% battery in the morning
                                    30% training start trail running: battery mode endurance
                                    19% at training stop after 3:42 h (!6.30h)
                                    Door unlocked, toilet, alarm 9% (16.35h)
                                    1% 16.45h
                                    Battery usage since the last full charge:
                                    Jan 11: 100%, 12.30h
                                    Jan 11: 95%, 3.25 h training (endurance mode) 16.30h
                                    Jan 12: 92%, 10h
                                    Jan 12: 86%, 3h training (endurance mode) 16.30h
                                    Jan 13: 84% 10.15h
                                    Jan 13: 77% 3.5 h training (endurance mode) 17.15h
                                    Jan 14: 74% 11h (no training)
                                    Jan 15: 68% 10h
                                    Jan 15: 60% 3h training (endurance mode) 17h
                                    Jan 16: 50% 10h
                                    Jan 16: 40% 3.5 h training (endurance mode) 17h
                                    Jan 17: 31% 10h
                                    Jan 17: 19% 3.75 h training (endurance mode) 16.30h
                                    Jan 17: 1% 16.45h
                                    Until Jan 15 everything was great, then a 10% drop overnight is not good, and going from 19% to 1% in 15 minutes is unacceptable. I normally charge the watch once a week at about 20%, I bought it in October 2023. I had this jump from 19% or 18% to 1% about 3-4 weeks ago as well, but without any training beforehand.
                                    What is going on? Ideas?
                                      @atoponce auto calibration was there before as well. Back when I was using stryd I vaguely remember this setting. I’ll get back to you guys about this.
                                      Zdeněk HruškaZ herlasH 2 Replies Last reply Reply Quote 1
                                        @Dimitrios-Kanellopoulos thank you very much. I think there are more threads regarding the Stryd not working properly with Suunto in this forum as well as on Reddit for example (especially about pace and distance not coming from the pod). I haven’t used Stryd for a few years. I remember that it worked flawlessly before. There are definitely some issues now. And it seems to be the case that on the treadmill it works as it should while on the gps profiles watch seems to prefer gps data. At least from my experience and testing.
                                        Thanks for all the help!
                                        Edit: Also there was a pairing issue with the new 5.0 Stryd but that one had been sorted out by the Stryd update.
                                        SquirrelS Dimitrios KanellopoulosD 2 Replies Last reply Reply Quote 2
                                        • herlasH Offline
                                          herlas Silver Members @Dimitrios Kanellopoulos
                                          @Dimitrios-Kanellopoulos toggle for auto calibration was there the whole time as you said, but it did dissappear at least for Stryd when we got the first firmware version that introduced ability to pair multiple sensors of same type.
                                          Then we just got it back on latest 2.50.26 firmware
                                          SRS Ti
                                          SRun (primarily road runner so testing SRun is a must ;))
                                          A3P (drill mode for pool swimming 🤦🤷)
                                          Galaxy Z Flip 3 / Galaxy S24+
                                          • SquirrelS Offline
                                            Squirrel Silver Members @Zdeněk Hruška
                                            @Zdeněk-Hruška said in Suunto 2.50.26 – Q4 2025 Release Notes:
                                            Thanks for the info.
                                            @herlas said in Suunto 2.50.26 – Q4 2025 Release Notes:
                                            Right, disappeared due to Q3 2025 update bug.
                                            Race S
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
