    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    your honest thoughts
    Scheduled Pinned Locked Moved Suunto Race 2
    35 Posts 16 Posters 3.8k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • S Offline
      Stavrogin @Dieter1960
      @Dieter1960 I too have struggled with the same BT connectivity issues you re talking about. I have had zero issues with the H10 and The HRM Pro + when I leave both my iPhone and my Garmin at home. (Basically I have to run with only Suunto) If the HRM that is paired and being used for by the Vertical 2 is or has historically been used by any device (ie it recognizes the BT even though it is not paired) I will get intermittent signal. This has not always been the case and I am excited to see how the next firmware update fixes this issue. I have been super impressed with the OHR on the other hand, but I have not tried in in a VO2 max session or anything like that.
      Suunto Vertical, Race, Race 2, Race S and Run. Rocking the Vertical 2 Titanium at the moment.
      Garmin: Fenix 7X, Epix Pro 51mm, Forerunner 265.
      Coros: Pace Pro, Apex 4
      SportsfreundS 1 Reply Last reply Reply Quote 0
      • SportsfreundS Offline
        Sportsfreund Bronze Member @Stavrogin
        @Stavrogin The OHR on the Suunto V1 and V2 is really good. I’ve never had the problems that some people here are writing about.
        • S Offline
          Stavrogin @Sportsfreund
          @Sportsfreund I agree. I do have a larger wrist though and maybe that is what helps. Even though I have a large wrist the V2 is heavy and feels like it is moving during runs. Again maybe this is why some get less than ideal HR. I like a snug fit when running.
            @Stavrogin I also have large wrists, but I don’t find the V2 heavy. It’s a shame that some users are having so many problems.
            • S Offline
              @Sportsfreund I agree with you on the so many people thing. TBH my battery life is not great. I am not getting 20 days with the V2, but the GPS battery life is great. I lose about 10% a day with a 1 hour GPS and no HR activity. If they doubled that I would say okay, but…
              What wrist strap are you using with your V2? I don’t notice it unless I have my Apex 4 on. Also wrist matters. When it is on my left wrist it feels less “moving”. Having said that it hasn’t affected HR readings when I do use the OHR.
                @Stavrogin i use the original white/blue one.
                  Sportsfreund Bronze Member @Sportsfreund
                  What is the Apex 4 belt?
                  • S Offline
                    @Sportsfreund Apex 4 is a Coros watch.
                    • sky-runnerS Offline
                      sky-runner Platinum Member @sky-runner
                      said in your honest thoughts:
                      Let’s say I do have a preplanned route, but for whatever reason I have to take a quick detour while having the original route in view and merge into the original route a bit further. Again, that is not possible because as soon as I zoom out just a little bit all the trails disappear from the map. So I can no longer use the watch map as a visual reference. This is more common than you might think because detours might be needed for a number of reasons - trail closure, decommissioned trails that I didn’t know about at the time of planning, a need to refill water, etc.
                      Just one day after my comment I’ve run into the exact case I described above. Today during my trail run I’ve run into a sign that told me that the trail ahead was closed and wasn’t passable and I now had to find a way around. This is how it looked on the watch while I was trying to connect a few alternative trails and still keep an eye on the original route. I am just 150 meters from the route and already I have no help from the watch to find the way around.
                      Also, adding salt to the injury, the crown stopped working (zooming the map) shortly after I took this picture and didn’t resume working until I had finished the run. Just perfect!
                      Suunto: Ambit, Ambit 3 Peak, 9 Baro, Race S, Race Ti, Vertical 2 Ti
                      Garmin: Forerunner 210, Forerunner 610, Fenix 6X, Fenix 7X Ti
                      2 1 Reply Last reply Reply Quote 0
                      • 2 Offline
                        2b2bff Silver Members @sky-runner
                        @sky-runner it just occured to me that Garmin set the position of “here” in the lower half, so you see more of the way ahead than the way behind you. Suunto sets “here” directly in the centre. Maybe a reason why Suunto’s maps rotate fast and Garmin slow…
                        Race S
                        sky-runnerS 1 Reply Last reply Reply Quote 1
                          sky-runner Platinum Member @2b2bff
                          @2b2bff My guess, there are two reasons.
                          1. Garmin devices have weak hardware. In particular, all current Garmin devices have only 5 MB of RAM - fast access operating memory where temporary data, such as rendered map data, can be stored. My guess is that because of that Garmin can’t cache a larger rendered part of map that would be needed for the rotation. In contrast, Suunto watches have additional 32 MB of RAM for the map data.
                          2. Garmin maps are far more detailed, which makes rendering more expensive in terms of battery power use, and that is probably why Garmin doesn’t pre-render maps in background.
                          So when you try to rotate a Garmin map it likely has to pull the data from the storage and then render it, which is slow. The storage access is the likely culprit.
                          S 2 2 Replies Last reply Reply Quote 1
                          • S Offline
                            Stavrogin @sky-runner
                            @sky-runner That makes total sense. Suunto is a map with a route layer on top, Garmin is a totally different animal with real time routing and detail.
                            • S Offline
                              @Dieter1960 What a sad day today. I took the Vertical 2 out with my H10 HRM for my Tuesday intervals run. No phone, no other BT device on me, just the V2 and the H10. I was so sad to see that 10 minutes into warm up my V2 starting doing its “stuck on 125 BPM” thing. Pulled the H10 on and off and it took 3 minutes for it to start working properly. I guess I was wrong. It will randomly disconnect or get stuck on signal. I will give it another run tomorrow alone with just the HRM Pro + and see what happens. If it does the same again I think it will have to be on the shelf until the update comes and hopefully that fixes it. That after last night have no sleep data because I went to sleep a couple hours later than usual. It read “no sleep tracked” this morning.
                              D 1 Reply Last reply Reply Quote 0
                              • D Offline
                                Dieter1960 @Stavrogin
                                @Stavrogin Pour les nuits, on devrait pouvoir comme sur Garmin indiquer à la montre l’heure de coucher. Là hier je me suis couché vers 23h30 mais j’étais fatigué la soirée sur le canapé et la Suunto m’a compté une nuit commençant à 20h30. Hier matin, sortie running avec la ceinture Garmin HRM 200 et miracle pas de problème d’appairage. Ensuite, 2nde séance et là évidemment la Race 2 ne s’appairait plus à la ceinture … astuce : passer en mode trail pour que l’appairage se fasse (changer de mode). Vivement la mise à jour ! (pour le VO2max aussi). Je serai très déçu si Suunto ne fait rien.
                                • 2 Offline
                                  @sky-runner your first point even weight more if you don’t turn a map in the size of the screen, but a map that is larger than the screen, as the centre point of this “disc” is off-centre of the watch screen…
                                  IIRC Garmin just uses the RAM of the SoC and Suunto use the same SoC (at least in the Race and Race S) with additional RAM. From my memory it is 11 MB, but that doesn’t really changes the whole situation…
                                  Race S
                                  Register Login
                                  • First post
                                    Last post
                                  Suunto Terms | Privacy Policy
