    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    HRV recording consistently scoring 26...
    Scheduled Pinned Locked Moved Suunto Race 2
    34 Posts 13 Posters 4.4k Views 15 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • ChrisAC Offline
      ChrisA Platinum Member @TED77
      @TED77 said in HRV recording consistently scoring 26...:
      @maszop said in HRV recording consistently scoring 26...:
      @TED77 You’re measuring and comparing two different things. Hence the discrepancies.
      Instead of wasting time on pointless comparisons, read up on how (and what) is measured and displayed in both apps.
      Please explain your rationale of how they are completely different things? I’m very aware of what hrv is so no need for your patronising approach.
      Just my two cents: You can “block” users, so you don’t waste time on rude and arrogant answers
      Currently Race I
      G 1 Reply Last reply Reply Quote 2
      • G Offline
        Gunnar Bronze Member @ChrisA
        @ChrisA but unfortunately you see the comments of blocked users when they are quoted…
        ChrisAC 1 Reply Last reply Reply Quote 1
        • ChrisAC Offline
          ChrisA Platinum Member @Gunnar
          @Gunnar that’s true - but at least it’s a bit less distracting
          Currently Race I
          • amko34A Offline
            amko34 @Neil McElroy
            @Neil-McElroy My range is given as 72-85ms. I guess on average I get a 80,81 but obviously with some variation. Recently, after having couple of drinks, I got a 53ms in that night.
            Couple of days before, I was feeling like I was about to get sick. When I checked HRV for the night before, I had 71ms. Arguably, it’s not that much below the minimum of the range but as I scored usually 80s I thought it matches the bad feeling I had on that day (might be confirmation bias).
            Race 2
            • C Offline
              cheetah694 Bronze Member @Mads Hintz-Madsen
              @Mads-Hintz-Madsen That’s good to know. However the true rMSSD value in milliseconds is still shown in the app. That’s the big difference with what sport watches are doing. Elite HRV is fully transparent as to the data it records.
              Suunto 9 Peak Pro
              M 1 Reply Last reply Reply Quote -1
              • M Offline
                maszop Bronze Member @cheetah694
                @cheetah694 https://forum.suunto.com/topic/10018/hrv-overnight-readings-thoughts
                T 1 Reply Last reply Reply Quote 0
                • T Offline
                  TED77 @maszop
                  @maszop actually quite a useful thread there. Highlights the challenge comparing different methods. Indeed in elitehrv u can see the rmssd value which in theory should be the most relevant comparison to suunto. Again I believe the best option would be for suunto to enable users to take their own measurements through an app, allowing us to take a morning test ourselves. I’m a bit sceptical about overnight readings for a number of reasons but a chest strap measurement through the watch would be a really useful feature.
                  @maszop I get your point about comparing suunto and elitehrv score and u r quite right that they r different metrics, however the elite rmssd is a useful metric to use. I’m a bit embarrassed to admit, I did not realise elitehrv was shifting the measurement into their own scale for their score. So I learnt something new!
                  M 1 Reply Last reply Reply Quote 0
                  • M Offline
                    maszop Bronze Member @TED77
                    @TED77 But generally, the number itself doesn’t matter, nor do these types of comparisons.
                    If the trend or graph is more or less the same in both tools, the difference in numerical values ​​can simply be ignored.
                    • Joseph FoxJ Offline
                      Joseph Fox @Neil McElroy
                      @Neil-McElroy - Neil did you ever find a resolution here? Did readings normalize? Jut got a new Suunto and since using have had 3 identical readings in a row.
                      EgikaE Manuel ExtremeM 2 Replies Last reply Reply Quote 0
                      • EgikaE Offline
                        Egika Platinum Member @Joseph Fox
                        @Joseph-Fox get drunk and check again next morning 🙂
                        1 Reply Last reply Reply Quote 6
                        • Manuel ExtremeM Offline
                          Manuel Extreme Silver Members @Joseph Fox
                          @Joseph-Fox For the past 3 months I’ve been sleeping every night with Garmin Fenix 8 and Suunto Vertical 2 (which has the same sensor as the Suunto Race 2).
                          In absolute terms there’s a 4–5 point difference, but the trend is practically identical.
                          If your value is always flat, the device might be bugged.
                          Vertical 2 v2.56.18
                          https://milestone.sportacademy.zone/about
                          Joseph FoxJ 2 Replies Last reply Reply Quote 1
                            Joseph Fox @Manuel Extreme
                            @Manuel-Extreme - yeah mine is Vertical 2 as well actually. Just stumbled upon this thread when trying to research the issue. It’s only 3 days old, so it’s only been three nights, but it is definitely completely flat, 48 MS every night so far. Gonna give it a night or two more and if it doesn’t start showing some variation might do factory reset, if that doesn’t work, probably getting returned.
                              @Manuel-Extreme - yeah I have the vertical 2 as well. its only been about 3 nights of the flat data ( only had the watch for 3 days)… going to give it a few more days to see if I can get some variation. If not, going to try a factory reset. may even return if that doesn’t work, which would be shame because I love the watch.
                              • EgikaE Offline
                                @Joseph-Fox why would you think the value should differ? Just because you get the same reading, is not an indication of this function not working. I’d say it is just the same reading.
                                Register Login
                                • First post
                                  Last post
                                Suunto Terms | Privacy Policy
