    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Alpine skiing downhill
    Scheduled Pinned Locked Moved Suunto Race 2
    64 Posts 25 Posters 10.4k Views 23 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • MdzOttM Offline
      MdzOtt @tomahawk5000
      @tomahawk5000 it works for me designed. All downhill parameters show correctly. Mind you, I have customised all of my activities, including alpine skiing. I show total descent, max speed, number if runs, and activity duration. I don’t remember when this problem went away, but I think, it was around mid-January.
      Another data point: quite often I don’t do two consecutive alpine skiing activities in a row. Usually, I have another activity in-between. This means that alpine skiing needs to be reloaded.
      R2
      S9 Baro
      SA on Android
      Ambit 3 Peak
      Ambit 2 Sapphire
      • MdzOttM Offline
        @tomahawk5000 mine is showing zero, as well, but I wonder if this is relevant or not. I’ll have to analyze it further if that is really the first run or if that is a “ghost run” (walking from the lodge to the lift etc.) - this is like it looks like. It shows (in my case) zero time, as well. When you check the number if runs, it shows the correct number (one less than what is displayed in the analysis). So that 1st run of zero length and duration does not count.
        R2
        S9 Baro
        SA on Android
        Ambit 3 Peak
        Ambit 2 Sapphire
        T 1 Reply Last reply Reply Quote 0
        • T Offline
          tomahawk5000 @MdzOtt
          @MdzOtt my brother in law because of this issue had a few kilometres less than this friend who has Garmin that’s why I’m asking
          This February I had a chance to skiing and this March mybbrothe in law bowh we had same issue his for snowboard and I for alpine skiing. That’s sad
          Kind regards,
          Tomek
          Suunto 9 baro -> Vertical 2
          MdzOttM 1 Reply Last reply Reply Quote 0
          • MdzOttM Offline
            @tomahawk5000 my vertical shows correctly (if anything, a bit high; Strava adjusts it down). I don’t track distance in alpine skiing (I find irrelevant), only vertical (descent).
            R2
            S9 Baro
            SA on Android
            Ambit 3 Peak
            Ambit 2 Sapphire
            Register Login
            • First post
              Last post
            Suunto Terms | Privacy Policy
