    • Recent
    • Tags
    • Popular
    • Users
    • Groups
    • Register
    • Login
    Alpine skiing downhill
    Scheduled Pinned Locked Moved Suunto Race 2
    64 Posts 25 Posters 10.5k Views 23 Watching
    Loading More Posts
    • Oldest to Newest
    • Newest to Oldest
    • Most Votes
    Reply
    • Reply as topic
    Log in to reply
    • E Offline
      espiadimonis
      Hi. I got a problem in my race 2 with alpine skiing downhill. During the exercise, no data is showed on the watch display, all data fields show a zero except for the activity duration. And also no data showed on the laps display. However, when i syncronize my watch, in the app i can see all the information of the exercise but the data showed doesn’t include number of downhill runs or downhill distance (it only shows total distance). Soft 2.48.16. Any thoughts? Anyone with the same problem? Thanks!
      Stoke80S LazyjonesL Lukas RotreklL 3 Replies Last reply Reply Quote 1
      • Stoke80S Online
        Stoke80 @espiadimonis
        @espiadimonis
        Yes, same issuer here.
        I recorded my first Alpine Skiing session with the Race 2 watch on Saturday.
        Unfortunately it does not show the number of runs, either on the watch itself, nor on the Suunto App.
        On the other side, the Suunto App shows me stats like steps cadence for steps and cycling?
        And it also gives me recovery time of 51 hours. Although I am pretty sure I did not do the Lauberhorn downhill race 4 times in a row 😃
        Suunto Quest / Suunto Ambit 3 Peak / Sununto Spartan Sport Wrist HR / Suunto 9 Baro / Suunto 9 Peak Pro / Suunto Vertical / Suunto Race S / Suunto Race 2
        M 1 Reply Last reply Reply Quote 0
        • EgikaE Offline
          Egika Platinum Member
          Now we have this in two threads…
          I’d like to file a bug for this.
          If it happens again, that neither watch nor app shows the # of runs, can you please send logs from the settings of the app as soon as possible after the activity?
          Then please let me know your app user name in private message and the date and time, when you sent the logs.
          Thank you!
          Stoke80S E Twan LangeT 3 Replies Last reply Reply Quote 0
          • Stoke80S Online
            Stoke80 @Egika
            @Egika
            Yes, I know and I am sorry for that. But as this is a specific thread for this topic only, I thought I will continue here.
            I will try to remember when I go skiing the next. Time. Due to the current weather in my area (rain up to 2000 meters and freaking warm), please give me some time
            • E Offline
              espiadimonis @Egika
              @Egika
              Tried again today. It didn’t work the first run (same as yesterday, no data on the display). I ended the exercise and reset (power off and power on again). I started the exercise again and… it worked as expected! Everything ok. I ended the exercise. I started a new exercise and… it didn’t work. Reset. I started a new exercise and worked as expected. So, i reset just before the exercise, everything works fine but if i not reset, it doesn’t work. I will send you my log. Thanks.
              MdzOttM 1 Reply Last reply Reply Quote 2
              • Twan LangeT Offline
                Twan Lange @Egika
                @Egika Hi there. Just wanted to get in touch to say this is a common issue, it seems. A few people close to me are currently on a skiing holiday with their original Vertical. All three of them are having the same issue with up-to-date software (v2.48.16.). Got any advice? Happy to provide more data if needed.
                • MdzOttM Offline
                  MdzOtt @espiadimonis
                  @espiadimonis when you “reset”, did you use the “power off/power on” or soft reset (15 s press on the upper button)?
                  R2
                  S9 Baro
                  SA on Android
                  Ambit 3 Peak
                  Ambit 2 Sapphire
                  E 1 Reply Last reply Reply Quote 0
                  • E Offline
                    espiadimonis @MdzOtt
                    @MdzOtt , power off, power on.
                    • LazyjonesL Offline
                      Lazyjones Bronze Member @espiadimonis
                      @espiadimonis Really annoying. For me it only worked first time daily, or first time after soft reset. Weird bug.
                      • EgikaE Offline
                        it’s reported.
                        I hope for a fix in the Q4 release too.
                        Turo JantunenT 1 Reply Last reply Reply Quote 0
                        • Turo JantunenT Offline
                          Turo Jantunen @Egika
                          @Egika Where you are able to see that there will be release in Q4 still?
                          • M Offline
                            mm_si @Stoke80
                            @Stoke80 same with my Vertical. Just returned from the Dolomites. Last year it worked perfect, this year zero info on display and zero downhill runs count…
                            • K Offline
                              Kaiphi
                              Thanks for the post, had same problem but forgot 😊 We were 4 suunto users (ocean, vertical 1 and 2x race s) and on day 1 everything worked. On the second day on the track we had the above problem with the ocean, Vertical 1 and one race s. What I think is that it has nothing to do with the model but with the software.
                              Suunto 9 Peak Pro
                              Suunto Vertical Titanium Solar
                              2 1 Reply Last reply Reply Quote 0
                              • 2 Offline
                                2b2bff Gold Members @Kaiphi
                                @Kaiphi Interesting to hear about the Ocean, as it is usually a bit behind software wise…
                                Suunto Race S
                                Garmin Epix Pro
                                K 1 Reply Last reply Reply Quote 0
                                • K Offline
                                  Kaiphi @2b2bff
                                  @2b2bff I don’t think it has anything to do with the current firmware. In the past, this has already happened with bikepark mode. Egika know this to good 😉
                                  Suunto 9 Peak Pro
                                  • Lukas RotreklL Offline
                                    Lukas Rotrekl @espiadimonis
                                    @espiadimonis A I have the same problem on 9 Peak Pro, on last weekend I have “fixed” it by reset watch (in my case hold upper button for 12s).
                                    I hope someone reported it to Suunto, I will do it too, Or is here enybody from Suunto, who will see it?
                                    I am new on forum.
                                    • EgikaE Offline
                                      correct. We had a similar issue with downhill MTB.
                                      I am not sure if it is the same underlying issue.
                                      There will be a Q4 FW release - just not sure if it arrives in December or early January because of the holidays.
                                      • MdzOttM Offline
                                        MdzOtt
                                        I had this problem before (the first few alpine skiing days). I did power off/power on routine and it started working. I had 3 sessions this week (one full-ish day (5 h, 8000+ m vertical) and a couple short days (2-3 h)) and the problem has not reoccurred. The watch reports runs correctly (while in activity) and the SA reports the number of runs correctly. I didn’t touch the watch since the power off/on last week.
                                        Btw. (And this is a completely different matter), the watch does not sync after a few sessions. I need to force stop the SA and then it works for a few days.
                                        R2
                                        S9 Baro
                                        SA on Android
                                        Ambit 3 Peak
                                        Ambit 2 Sapphire
                                        • K Offline
                                          Kaiphi
                                          Was back on the slopes today and it didn’t show me anything again. It is also annoying that the distance is then not displayed for the descents, but the one with lift
                                          Suunto 9 Peak Pro
                                          MdzOttM 1 Reply Last reply Reply Quote 0
                                          • MdzOttM Offline
                                            MdzOtt @Kaiphi
                                            @Kaiphi Try resetting the watch. I have a Race 2, so it is a different watch, but powering it off an on works.
                                            R2
                                            S9 Baro
                                            SA on Android
                                            Ambit 3 Peak
                                            Ambit 2 Sapphire
                                            Register Login
                                            • First post
                                              Last post
                                            Suunto Terms | Privacy Policy
